| Ammoman |
 Ammoman Nitrous Nuisance
 Posted: 11:59 - 26 Mar 2014 Post subject: Hayabusa Not Charging battery? |
My 2nd Gen Hayabusa is not charging the battery? Voltage of around 12.5 when running when it should be around 14v. I have replaced the Stator but still the same Any ideas people? Thanks.. ____________________ 2013 ZZR1400 & Honda CG125 1986.. |
| sabian92 |
 sabian92 World Chat Champion
| P.addy |
 P.addy Red Rocket
| Ammoman |
| P.addy |
 P.addy Red Rocket
| Pete. |
 Pete. Super Spammer
 Posted: 20:12 - 26 Mar 2014 Post subject: |
The 'busa generator should put out more than 65V AC on all three phases at 5000rpm to be declared healthy. Un-plug the genny and test with a meter across the yellow wires - all three combinations of pairs.
The battery voltage should read between 13.6V and 15.1V at 5000rpm with a fully charged battery.
If the AC test proves the genny is good, which it likely is since you swapped it with no change, then first of all follow the reg/rec wires to the loom plug these have a habit of going rotten and melting. I know of several Gen1 'busas which have the reg/rec plug chopped off and a chocolate block put in it's place.
If the plug seems ok then check out the black lead from the battery. It splits into a thicker and a thinner lead. The thinner one has a heavy spade connector on it and this can corrode causing all manner of problems including not charging. ____________________ a.k.a 'Geri'
| stuartt |
 stuartt World Chat Champion
 Posted: 22:25 - 06 Apr 2014 Post subject: |
thats my busa not charging now  |
| Pete. |
 Pete. Super Spammer
 Posted: 22:43 - 06 Apr 2014 Post subject: |
Check the plug on the reg/rec first of all. They are known to melt - my mate has had his connected by chocolate block for the last few years. Then check the loom earth spade connector which is a few inches from the battery -ve terminal. This bad boy in the attached image is what stopped mine charging. ____________________ a.k.a 'Geri'
| stuartt |
 Posted: 23:12 - 06 Apr 2014 Post subject: |
thanks pete .
the f1 light came on 2 weeks ago , i switched the bike off to see if restarting it would clear the light but the bike wouldn't start .
i bought a new battery & i thought the bike was ok .
i took it out tonight & after 5 miles the f1 light came on again !
i phoned my boy & he came & met me with the battery out of his cg125 , it did the job to get me home
i'll check the connections tomorrow , thanks again . |
| Pete. |
 Pete. Super Spammer
 Posted: 23:24 - 06 Apr 2014 Post subject: |
Yes, a very flat battery will put the FI light on, but it won't come on to tell you the bike isn't charging.
You have to remove the tailpiece to get to the reg/rec, it's fixed to the seat subframe near the left grab handle. ____________________ a.k.a 'Geri'
| stuartt |
| Busa1340R |
 Busa1340R Nova Slayer
 Posted: 23:38 - 06 Apr 2014 Post subject: |
| Quote: | You have to remove the tailpiece to get to the reg/rec, it's fixed to the seat subframe near the left grab handle. |
Not on a Gen2 it isn't (unless someone has moved it)........it's on a bracket below the front end of the swingarm.....above the rear fairing extension. 😉 ____________________ Current: 2010 Suzuki GSX1340R Hayabusa, 2013 Yamaha YP250R X-Max Sport - Previous: Triumph Sprint ST1050ABS, Honda XL600V Transalp, Honda NT650V Dullsville (don't ask!), Kawasaki ZX9R E1, Honda NX650 Dominator, Suzuki GSX1300RKZ Hayabusa, Honda CBR1000FM, Kawasaki GPZ500S, etc etc |
| stuartt |
The last post was made 12 years, 206 days ago. Instead of replying here, would creating a new thread be more useful? |
