CBR 600 F3
Conzar
PostPosted: 08:57 - 31 Mar 2014    Post subject: CBR 600 F3 Reply with quote
Hi all,
Just brought one of these, first things first i want to change the REG/REC on it as I've been told they are a common problem.
Can you buy one they will simply plug in or will i have to do some soldering ?
Current ride: ZX6R 636 ------- Previous:KTM EXC 450 Supermoto --- ZX6R B1H --Hornet 600--CBR 600--SV650
11:05:35 Rob Fzs: i just wanna own an rd350 valve before they send us to war with durkadurkastan
Islander
PostPosted: 09:15 - 31 Mar 2014    Post subject: Reply with quote
If it isn't giving you any trouble, why change it? Leave it until you have a problem - if you ever do.
As for changing it, it's a simple plug and two bolts. Thumbs Up
Conzar
PostPosted: 09:51 - 31 Mar 2014    Post subject: Reply with quote
Last night as i was riding it home about 2 mins from the lights i went to pull off and at first i thought i was in 3rd because it did not want to pull off, then at the top of my road it died and when started any revs i gave it it died, got it home left it a few hours went to start it again and it was fine.
Islander
PostPosted: 10:02 - 31 Mar 2014    Post subject: Reply with quote
That doesn't sound like a reg/rec issue. To test, stick a meter across your battery terminals and read the voltage present with the engine at tick over and at 3-4k. It should read around 12.5v initially (at tick over), rising to around 14v at 3-4 k.
CaNsA
PostPosted: 12:47 - 31 Mar 2014    Post subject: Reply with quote
Update your sig
Conzar
PostPosted: 13:21 - 31 Mar 2014    Post subject: Reply with quote
Obviously another Honda one will be a strait swap, I'm on about say a GSXR or R1 rec/reg what do you need to adapt.
skatefreak
PostPosted: 14:13 - 31 Mar 2014    Post subject: Reply with quote
The reg went on the 98 cbr600 f3 I got shortly after I got my mitts on it.
I did read up on it a little and heard a lot about other brands of regs lasting a lot longer (although requiring soldering etc) but then found an F3 reg at a good price and just went for it.
However, that being said, a fried reg doesn't match the symptoms you have mentioned. If the reg is fried it will kill your battery, the bike starting fine later suggests your battery is fine Confused
Give it a test to see what's happening with the reg then it'll be clearer as to where to look.
All the best.
-Jvr
Conzar
PostPosted: 14:16 - 31 Mar 2014    Post subject: Reply with quote
All the best.
-Jvr
Think it may be due to a problem with some shitty fuel as there was a delay in power so im going to top it up and let it run and see how it is, cheers anyway Thumbs Up
CaNsA
PostPosted: 14:20 - 31 Mar 2014    Post subject: Reply with quote
Drain tank, replace fuel filter, oil change, take it on a private road and hoon it.
Conzar
PostPosted: 14:22 - 31 Mar 2014    Post subject: Reply with quote
Tar Thumbs Up
The last post was made 12 years, 186 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 70.85 Kb
