Honda Lead throttle cable snapped
dekoder
PostPosted: 15:52 - 01 Apr 2014    Post subject: Honda Lead throttle cable snapped Reply with quote
Throttle cable snapped in my Honda lead SCV 100 and I'm wondering how difficult is it to replace it by myself.
I've already ordered a replacement (10£) and been quoted 60-80£ for a mechanic to come over and replace it.
I've tried to find instructions online though only found this:
https://www.ehow.co.uk/how_7652496_replace-throttle-cable-scooter.html
Is it easy enough to replace it myself and is there anything that could go wrong?
Under which panel is the carburettor located in honda lead? (i've did a quick search online with no luck, though will try again)
Any help will be much appreciated!
Shinigami
PostPosted: 15:59 - 01 Apr 2014    Post subject: Reply with quote
imagine its the same as the bikes I've changed the throttle cable on in that just follow where the cable goes then put the new one in the same place.
dekoder
PostPosted: 16:23 - 01 Apr 2014    Post subject: Reply with quote
The cable obviously disappear into the tube, which panel should i open to find the other end? Is it easy enough job for someone doing it for the first time?
clancy
PostPosted: 16:52 - 01 Apr 2014    Post subject: Reply with quote
Would be very easy to do. Don't know where your carb is, take off all the panels if need be, there's not a lot of them and only takes 2 minutes
KLX 300r
Islander
PostPosted: 18:35 - 01 Apr 2014    Post subject: Reply with quote
Run the new cable alongside the old, connect it and then remove the old one. That way you know you've got the correct route. Thumbs Up
dekoder
PostPosted: 12:00 - 02 Apr 2014    Post subject: Reply with quote
Thanks for the helpful advises. I'm gonna get that manual, might also come of use in future.
The last post was made 12 years, 163 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 51.03 Kb
