Holts FireGum Exhaust Gasket ???
bryera
PostPosted: 21:21 - 04 Apr 2014    Post subject: Holts FireGum Exhaust Gasket ??? Reply with quote
Hay guys sorry if this has been covered before but I have just got a new exhaust and I have tried putting in the exhaust gasket seal in and I have had two now and broke them and can not be assed with them any more I was wonting to know can I us Holts FireGum.
https://reviews.halfords.com/4028/741520/reviews.htmn
and would that be just as good or do I need that gasket seal in as its the only thing stopping me from putting it on Grrr lol
Gasket seal that keeps braking
https://i208.photobucket.com/albums/bb106/bryera89/680508_10152025109358342_331437446_o_zpscf2a5952.jpg
Where I am thinking of putting FireGum
https://i208.photobucket.com/albums/bb106/bryera89/10001234_10152025110038342_14478620_o_zps572ea77e.jpg
https://i208.photobucket.com/albums/bb106/bryera89/10176047_10152025109073342_1295245258_n_zpsa02dbb10.jpg
SQL
PostPosted: 21:37 - 04 Apr 2014    Post subject: Reply with quote
use that gasket and use firegum as lube
gavbriggs
PostPosted: 22:15 - 04 Apr 2014    Post subject: Reply with quote
I will ask her indoors if she will accept fire gum as lube! Can't see that happening tbh
bryera
PostPosted: 22:41 - 04 Apr 2014    Post subject: Reply with quote
^^ Ha-ha I don't have the Gasket seal now as it fucking snapped agene lol so was just looking at using the fire gum ???
jeddy11
PostPosted: 09:42 - 05 Apr 2014    Post subject: Reply with quote
What he is saying is use the broken gasket and use the fire gum as a filler/sealer rather than using loads of fire gum .
Fuelly My Z1000SX
cbt 06/08/11 mod1 (second go) 01/08/12 mod2 21/09/12
Varadero Viking YBR125>Varadero125>ER6F>Z1000SX !!!
PostPosted: 10:24 - 05 Apr 2014    Post subject: Reply with quote
Use plumbers silicone. The clear stuff you'd seal round your bath with.
It'll cope with more heat than the average motorcycle engine can throw at it, makes a flexile seal and any excess wipes off with a cloth. If you want to remove it, it just peels off.
Fire cement is crap, brittle, a total nightmare to work with, sticks to everything but the bit you want it to and is difficult to remove when set.
Snorty
PostPosted: 10:26 - 05 Apr 2014    Post subject: Reply with quote
I was surprised to see this stuff actually does work. Used it on my GPZ once.
i.p.phrealy
PostPosted: 11:14 - 05 Apr 2014    Post subject: Reply with quote
the bodger in me wants to know if it'll work on the header pipe at the head end. Thinking
PostPosted: 11:27 - 05 Apr 2014    Post subject: Reply with quote
Yes. I've used it on the push-fit header on my Enfield and that's air-cooled.
You also get special high temperature silicone in B&Q for sealing stove flues. I just used the bog-standard plumbers stuff though.
Raffles
PostPosted: 12:49 - 05 Apr 2014    Post subject: Reply with quote
I've used that stuff in conjunction with rope hemp for sealing exhaust joints. It seals perfectly and it doesn't dry-up and crack.
Baffler186
PostPosted: 14:37 - 05 Apr 2014    Post subject: Reply with quote
Didn't work for me. Got hot, turned black, burnt down to a black oily substance that stained my stainless pipe! Holts gun gum didn't work either, after 2 weeks went brittle and it all snapped off.
If you still intend using sealant, go for the ultra heat resistant stuff, costs about 7quid a tube. By all means try normal bath sealant first, but be prepared to scrape it off and start again if it burns.
Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic
Richy CB1000
PostPosted: 14:45 - 05 Apr 2014    Post subject: Reply with quote
As they say, plus 1 for the high temp sealant. Used it on a BMW 7 series water pump, several other places over the years. Was able to get that water pump out after several years, stuff just peeled, seemed to stop rot setting in.
bryera
PostPosted: 15:21 - 05 Apr 2014    Post subject: Reply with quote
Hay guys thanks for all the advice I will be nipping to Halfords in 10 and getting some clear Gasket sealer and will be putting that rand it and the gasket seal then bike will be back on the road with any luck in this nice weather we been have lol
Thanks Guys !!!
moonzoomer
PostPosted: 18:39 - 05 Apr 2014    Post subject: Reply with quote
This is good gear, only a fiver a tube and will work up to 300 celcius, designed to seal flue pipes it works perfectly on exhaust systems, available from any plumbing /heating supplier or hardware stores.
https://uksealants.co.uk/everbuild-heatmate-high-temperature-silicone--p275.html
Raffles
PostPosted: 20:36 - 05 Apr 2014    Post subject: Reply with quote
That's the stuff that I use and it's excellent but I'm sure that I only pay £2 or £3 per tube.
bryera
PostPosted: 21:16 - 05 Apr 2014    Post subject: Reply with quote
is that stuff easy to remove if I had to remove the exhaust ??
Thanks
moonzoomer
PostPosted: 21:29 - 05 Apr 2014    Post subject: Reply with quote
Thanks
Yes, use a sharp stanley knife to break the seal then simply scrap the sealant off or just peel it of.
bladerunner
PostPosted: 00:39 - 06 Apr 2014    Post subject: Reply with quote
Another +1 for high temp silicone sealer ....which you can get from most DIY/plumber centres......don't use std clear silicone as if you have any gaps it melts and fails at temperature. The high temp stuff expands a bit with heat helping it to seal yet still has a bit of flex to help deal with expanding metal parts which is where things like fire gum just turn to dust and blow out ......use it as assembly paste and it works well
bryera
PostPosted: 13:53 - 06 Apr 2014    Post subject: Reply with quote
Thanks moonzoomer / Raffles I have just ordered that Heat Mate Resistant Silicone Sealant from this site a little cheaper
https://www.transtools.co.uk/fixings-hardwares/sealants-and-adhesives/fire-stove-and-flue-cement/everbuild-heat-mate-resistant-silicone-sealant-black-310ml
so ones it gets here I can finally get it fitted ha-ha
The last post was made 12 years, 191 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.11 - MySQL Queries: 15 - Page Size: 102.54 Kb
