Urgent help with oil change...
Adamski91
PostPosted: 19:42 - 10 Apr 2014    Post subject: Urgent help with oil change... Reply with quote
So I recently decided to change the oil on my 2002 Yamaha YZF R6, and having a filter on order for tomorrow I decided to drain the oil tonight.
Jump in the garage, find the right socket piece for the drain nut and start at it.
Then the drain nut and a piece of the metal snap off completely. See pics (ignore captions haha..).
Basically is my bike knackered? How could this have happened? It was twisting okay and then there was a small oil leak and it came off...
And any ideas what parts I'll need and how much this is going to cost me? Cringe.. Thanks in advance guys.
Honda CG125 -> Suzuki GSF Bandit 600 S Smile
SQL
PostPosted: 19:52 - 10 Apr 2014    Post subject: Re: Urgent help with oil change... Reply with quote
Adamski91 wrote:
stuff
That looks fucked to me
might be able to get it welded
Adamski91
PostPosted: 19:57 - 10 Apr 2014    Post subject: Re: Urgent help with oil change... Reply with quote
SQL wrote:
Adamski91 wrote:
stuff
Yeah that was my first thought!! Haha..
After looking at it it seems to be the lower part of the engine casing(? Correct me if I'm wrong, please!) which is held on by bolts... Will ask my local MOTer and work shop what they reckon tomorrow.
Marmalade
PostPosted: 20:19 - 10 Apr 2014    Post subject: Reply with quote
Oh yes, thats fucked.
We're you turning it the wrong way?, the way it's broken off would lead me to say so.
You might be able to get it welded but another sump i presume would be the way to go.
SQL
PostPosted: 20:20 - 10 Apr 2014    Post subject: Re: Urgent help with oil change... Reply with quote
If it is a engine casing then its a "cheap" fix if its on the block then welding is only option really
Nobby the Bastard
Harley Gaydar
PostPosted: 20:23 - 10 Apr 2014    Post subject: Reply with quote
Righty tighty, lefty loosey....
Triumph Sprint ST 1050
SQL
PostPosted: 20:25 - 10 Apr 2014    Post subject: Reply with quote
Ah i didn't know thw sump was removable
yea get a new sump dude
Coxyzxr
PostPosted: 20:30 - 10 Apr 2014    Post subject: Reply with quote
New sump, (and don't forget gasket), piece of piss job, relatively speaking.
Torque wrench and correct torque spec for sump bolts definitely recommended ...
**WAS FITTED "WRONG WAY ROUND" !** CANT ACCOUNT FOR THE STUPID !
kramdra
PostPosted: 20:34 - 10 Apr 2014    Post subject: Re: Urgent help with oil change... Reply with quote
It will be on the sump. 30 quid off ebay will fix it, plus a gasket.
Adamski91
PostPosted: 21:07 - 10 Apr 2014    Post subject: Reply with quote
Thanks for the help everyone, I'll order that piece and look out for a gasket as well.
Definitely wasn't turning it the wrong way, I'm not useless!
Expensive oil.change at any rate Sad cheers again! Will post back how it all goes, for anyone who cares haha.
Edit - will a gasket really cost me the best part of £20?..
doggone
PostPosted: 22:54 - 10 Apr 2014    Post subject: Reply with quote
No, just use superglue, put on all bolts too. Thumbs Up
Islander
PostPosted: 23:19 - 10 Apr 2014    Post subject: Reply with quote
Make your own with gasket paper or use a decent liquid gasket like Three Bond. Thumbs Up
Major Doss
PostPosted: 23:34 - 10 Apr 2014    Post subject: Reply with quote
Sump plate +gasket, unless Yamahahaha specify Yamabond or equivalent. Thankfully the motor doesn't have to drop out. Remove and clean oil pick up filter if fitted. Torque wrench on rebuild. As stated above, righty tighty, lefty loosy when you are FACING the bolt, some chump I know forgot this once... Embarassed
Antisocial phucker.
davebike
PostPosted: 08:00 - 11 Apr 2014    Post subject: Reply with quote
GASKET STRAINER COVER 2C013 41401 about £15 !
Don't mess about with sealant if it blocks an oil way you will be looking for another engine
Dave
Dave
NC750Xdct + others at work !
[email protected]
Coxyzxr
PostPosted: 19:06 - 12 Apr 2014    Post subject: Reply with quote
Yes,
If I was doing it I'd get genuine part, and do it properly rather than diy gasket or sealant.
If it's worth doing then it's worth doing right on stuff like this.
lihp
PostPosted: 20:10 - 12 Apr 2014    Post subject: Reply with quote
Dave
He will be looking for a new engine soon when his cylinder liner falls apart or 2nd gear dies Thumbs Up
Clutchy
PostPosted: 20:51 - 12 Apr 2014    Post subject: Reply with quote
Bearing in mind you should be twisting to the left looking up from directly underneath it?
lihp
PostPosted: 20:54 - 12 Apr 2014    Post subject: Reply with quote
So why is the bolt fully screwed in against the bit of sump you have?
PostPosted: 21:53 - 12 Apr 2014    Post subject: Reply with quote
The joys of a steel bolt, and an alloy casing right there.
New sump required as said, so not as bad as it could have been.
PostPosted: 22:14 - 12 Apr 2014    Post subject: Reply with quote
That sump plug has definitely been heavily over-tightened. Look at the wrinkles in the sealing face and the way the corners have been wrung off in the clockwise direction. If the OP didn't mess up because the bolt is facing upwards (easily done) then the last person wrenched it up too tight and did the damage then.
Coxyzxr
PostPosted: 19:02 - 13 Apr 2014    Post subject: Reply with quote
True story.
YBR Ric
PostPosted: 19:29 - 13 Apr 2014    Post subject: Reply with quote
Fit a Fumoto drain plug - to drain the oil you just remove the locking clip and turn a lever - never risk thread damage ever again.
If you accidentally overfill - no problem. No more hot oil on your hands or fishing for your drain plug again Smile
Unfortunately not a suitable solution for every bike.
https://i162.photobucket.com/albums/t245/portisheadric/d0938462_zps4f6cef58.jpg
The last post was made 12 years, 191 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.61 - MySQL Queries: 13 - Page Size: 125.16 Kb
