| Adamski91 |
 Adamski91 Two Stroke Sniffer
 Posted: 19:42 - 10 Apr 2014 Post subject: Urgent help with oil change... |
So I recently decided to change the oil on my 2002 Yamaha YZF R6, and having a filter on order for tomorrow I decided to drain the oil tonight.
Jump in the garage, find the right socket piece for the drain nut and start at it.
Then the drain nut and a piece of the metal snap off completely. See pics (ignore captions haha..).
Basically is my bike knackered? How could this have happened? It was twisting okay and then there was a small oil leak and it came off...
And any ideas what parts I'll need and how much this is going to cost me? Cringe.. Thanks in advance guys. ____________________ Honda CG125 -> Suzuki GSF Bandit 600 S  |
| SQL |
 SQL World Chat Champion
 Posted: 19:52 - 10 Apr 2014 Post subject: Re: Urgent help with oil change... |
That looks fucked to me
might be able to get it welded |
| Adamski91 |
 Posted: 19:57 - 10 Apr 2014 Post subject: Re: Urgent help with oil change... |
| SQL wrote: |
Yeah that was my first thought!! Haha..
After looking at it it seems to be the lower part of the engine casing(? Correct me if I'm wrong, please!) which is held on by bolts... Will ask my local MOTer and work shop what they reckon tomorrow. ____________________ Honda CG125 -> Suzuki GSF Bandit 600 S  |
| Marmalade |
 Marmalade World Chat Champion
 Posted: 20:19 - 10 Apr 2014 Post subject: |
Oh yes, thats fucked.
We're you turning it the wrong way?, the way it's broken off would lead me to say so.
You might be able to get it welded but another sump i presume would be the way to go. ____________________ Nobby the Bastard: How yo tell the difference between the actual japanese and her just screaming because she's had live fish stuck up her arse? [url=https://www.nicks-shop.co.uk/bcf-goodies-15-c.aspGet BCF stickers and things here[/url] Reflective helmet stickers - Legal requirement in france - Clicky |
| SQL |
| Nobby the Bastard |
| N cee thirty |
 N cee thirty Banned
| SQL |
| Coxyzxr |
 Coxyzxr Brolly Dolly
| kramdra |
 kramdra World Chat Champion
| Adamski91 |
 Posted: 21:07 - 10 Apr 2014 Post subject: |
Thanks for the help everyone, I'll order that piece and look out for a gasket as well.
Definitely wasn't turning it the wrong way, I'm not useless!
Expensive oil.change at any rate cheers again! Will post back how it all goes, for anyone who cares haha.
Edit - will a gasket really cost me the best part of £20?.. ____________________ Honda CG125 -> Suzuki GSF Bandit 600 S  |
| doggone |
 doggone World Chat Champion
| Islander |
 Islander World Chat Champion
 Posted: 23:19 - 10 Apr 2014 Post subject: |
| Adamski91 wrote: | Thanks for the help everyone, I'll order that piece and look out for a gasket as well.
Edit - will a gasket really cost me the best part of £20?.. |
Make your own with gasket paper or use a decent liquid gasket like Three Bond.  |
| Major Doss |
 Major Doss Traffic Copper
 Posted: 23:34 - 10 Apr 2014 Post subject: |
Sump plate +gasket, unless Yamahahaha specify Yamabond or equivalent. Thankfully the motor doesn't have to drop out. Remove and clean oil pick up filter if fitted. Torque wrench on rebuild. As stated above, righty tighty, lefty loosy when you are FACING the bolt, some chump I know forgot this once...  ____________________ Antisocial phucker. |
| davebike |
 davebike World Chat Champion
 Posted: 08:00 - 11 Apr 2014 Post subject: |
GASKET STRAINER COVER 2C013 41401 about £15 !
Don't mess about with sealant if it blocks an oil way you will be looking for another engine
Dave ____________________ Dave
NC750Xdct + others at work !
[email protected] |
| Coxyzxr |
 Posted: 19:06 - 12 Apr 2014 Post subject: |
Yes,
If I was doing it I'd get genuine part, and do it properly rather than diy gasket or sealant.
If it's worth doing then it's worth doing right on stuff like this. ____________________ **WAS FITTED "WRONG WAY ROUND" !** CANT ACCOUNT FOR THE STUPID ! |
| lihp |
 lihp World Chat Champion
| Clutchy |
 Clutchy World Chat Champion
| lihp |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 21:53 - 12 Apr 2014 Post subject: |
The joys of a steel bolt, and an alloy casing right there.
New sump required as said, so not as bad as it could have been. ____________________ My Flickr |
| Pete. |
 Pete. Super Spammer
 Posted: 22:14 - 12 Apr 2014 Post subject: |
That sump plug has definitely been heavily over-tightened. Look at the wrinkles in the sealing face and the way the corners have been wrung off in the clockwise direction. If the OP didn't mess up because the bolt is facing upwards (easily done) then the last person wrenched it up too tight and did the damage then. ____________________ a.k.a 'Geri'
| Coxyzxr |
 - Super Spammer
| YBR Ric |
 YBR Ric Spanner Monkey
 Posted: 19:29 - 13 Apr 2014 Post subject: |
Fit a Fumoto drain plug - to drain the oil you just remove the locking clip and turn a lever - never risk thread damage ever again.
If you accidentally overfill - no problem. No more hot oil on your hands or fishing for your drain plug again
Unfortunately not a suitable solution for every bike.
https://i162.photobucket.com/albums/t245/portisheadric/d0938462_zps4f6cef58.jpg |
The last post was made 12 years, 189 days ago. Instead of replying here, would creating a new thread be more useful? |
