| sidewinder |
 sidewinder World Chat Champion
 Posted: 18:36 - 19 Apr 2014 Post subject: 2002 efi fire blade high idle issues |
Hi all
Question for a mate . He own the said bike.when starting from cold manual says it should be idling at 2k then drop to 1k when warmed up.but his bike idles at 3 to 3.5k .he says he needs to keep turning it on and of until it idles at 1k .other wise it gets very hot.any ideas what can be causing this.
Thank you |
| gavbriggs |
 gavbriggs Crazy Courier
| janner_10 |
 janner_10 World Chat Champion
| Aff |
 Aff World Chat Champion
 Posted: 09:22 - 20 Apr 2014 Post subject: |
The 929 and 954 Blades have a mechanical auto choke controlled by a wax pellet which has coolant running over it. As the coolant heats up the pellet expands and moves a rod attached to the stater valves.
Tell you mate to pull this out and give it a check in some cold and hot water. It should move about 5mm. It located just above the throttle bodies.
You can also balance the starter valves on these Blades, so that may also help.
Edit:
Part No 16044-MCJ-751, number 4 here:
https://i.imgur.com/KutFsSN.png ____________________ Current Bikes:Honda 929RR Fireblade, Honda CD200 Benly (Project), Stomp Z2 140
Electric Bike Project |
| sidewinder |
 Posted: 12:06 - 20 Apr 2014 Post subject: |
Cheers for the replys guys will pass on the info when I see him later
.cant be a lot wrong with it  |
| Aff |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 12:34 - 07 May 2014 Post subject: |
My 954 idles fairly high until it gets warm. Never looked at the numbers on it, just need to be careful on tight roundabouts until it's warmed up. ____________________ My Flickr |
The last post was made 11 years, 268 days ago. Instead of replying here, would creating a new thread be more useful? |
