2002 efi fire blade high idle issues
sidewinder
PostPosted: 18:36 - 19 Apr 2014    Post subject: 2002 efi fire blade high idle issues Reply with quote
Hi all
Question for a mate Thumbs Up . He own the said bike.when starting from cold manual says it should be idling at 2k then drop to 1k when warmed up.but his bike idles at 3 to 3.5k .he says he needs to keep turning it on and of until it idles at 1k .other wise it gets very hot.any ideas what can be causing this.
Thank you
gavbriggs
PostPosted: 22:02 - 19 Apr 2014    Post subject: Reply with quote
Don't know the bike at all but if it drops the rpm when the temp reaches a certain point then I would suggest the temp sensor or wires to/from it? Check the coolant level too as this will alter the temp reading depending on where the sensor is located.
Might also be worth checking any air temp sensors if they have them, sometimes in the air box(I'm translating car knowledge here) also the lambda sensors possibly but unlikely. There will be resistance values for them somewhere, maybe the manual will have them.
janner_10
PostPosted: 08:51 - 20 Apr 2014    Post subject: Reply with quote
Must be a honda thing - my cbr had very high revs on cold start and seems to take an age to return to normal once warmed up.
Aff
PostPosted: 09:22 - 20 Apr 2014    Post subject: Reply with quote
The 929 and 954 Blades have a mechanical auto choke controlled by a wax pellet which has coolant running over it. As the coolant heats up the pellet expands and moves a rod attached to the stater valves.
Tell you mate to pull this out and give it a check in some cold and hot water. It should move about 5mm. It located just above the throttle bodies.
You can also balance the starter valves on these Blades, so that may also help.
Edit:
Part No 16044-MCJ-751, number 4 here:
https://i.imgur.com/KutFsSN.png
Electric Bike Project
sidewinder
PostPosted: 12:06 - 20 Apr 2014    Post subject: Reply with quote
Cheers for the replys guys will pass on the info when I see him later
.cant be a lot wrong with it Very Happy
Aff
PostPosted: 11:55 - 07 May 2014    Post subject: Reply with quote
Ever get to the bottom of this?
PostPosted: 12:34 - 07 May 2014    Post subject: Reply with quote
My 954 idles fairly high until it gets warm. Never looked at the numbers on it, just need to be careful on tight roundabouts until it's warmed up.
The last post was made 11 years, 264 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 52.08 Kb
