How to get this part off?
DrSnoosnoo
PostPosted: 20:52 - 22 Apr 2014    Post subject: How to get this part off? Reply with quote
So I'm doing the valve clearances on the zzr600, very scary but I'm armed with the Haynes book of lies. Now I've got this stuck on my camshafts, see attached picture, How do I get it off? I undid the screws in order.
Should I try putting the other side back on and see if I can get it off then?
mentalboy
PostPosted: 20:57 - 22 Apr 2014    Post subject: Reply with quote
Assuming you mean the nice bright squarish bit (sorry haven't got the foggiest what that is Wink ) that is clamping in the right side of your camshafts?
If so, it's probably a good interference fit and will PROBABLY require a light tap with a rubber mallet to free it (Alternatively try rotating the camshafts)
Make mine a Corona.
DrSnoosnoo
PostPosted: 20:58 - 22 Apr 2014    Post subject: Reply with quote
Yeah the squarish bit I can't remember what Mr Haynes calls it. The cam chain tensioner is out now and that books says not to rotate it now or stuff might get damaged, correct me if I'm wrong though.
mentalboy
PostPosted: 21:18 - 22 Apr 2014    Post subject: Reply with quote
Another trick for freeing the camshaft and it's restraining bits and bobs would be to apply steady downward pressure on top of the camchain (between the two shafts) whilst keeping your hand on the left side to prevent it jumping out from that end.
The slight pressure should be enough to slightly move the camshaft and pop the 'thingy' on the right.
Personally I'd just be twatting it LIGHTLY' with my rubber mallet by now
Make mine a Corona.
PostPosted: 21:39 - 22 Apr 2014    Post subject: Reply with quote
I'd run those cam cap bolts down to just one turn out and use a plastic hammer. When it pops up against the bolts undo them all in sequence one turn at a time to let the cover rise evenly. It's easy to break those things, though that one looks quite strong.
WD Forte
PostPosted: 22:32 - 22 Apr 2014    Post subject: Reply with quote
Isnt it a bearing holder?
( with bit of added manifold thrown in)
I'd be trying some cautious levering/rocking to break it free
That bottom LH cam shaft looks a bit odd and reddish
and it all looks bit dry too
has it been laid up?
bikers smell of wee
DrSnoosnoo
PostPosted: 08:58 - 23 Apr 2014    Post subject: Reply with quote
Thanks Pete, so I should just tighten down that side or shall I put the other side on and screw them all in again?
These seem quote tough, quite thick metal.
I've given it a good pull and it's not budging so I'll have to try again tonight when I've finished work.
The one at the bottom is the IN cam it does look all that colour while the EX has a slight green colour to it, is it for distinguishing? I'm gonna get the verniers on them when they're out to check them over while I'm in there, don't wanna be doing all this again in a hurry!
It's not dry there is a good covering of oil over everything.
Thanks for the help so far gang. I've been taking hundreds of pictures so will hopefully write it up when I'm done to help other Valve clearance virigns.
DrSnoosnoo
PostPosted: 09:12 - 23 Apr 2014    Post subject: Reply with quote
Also, looking at these, valves, one side is covered in muck while the other is ok. What are these? The exhaust valves on 1 and 2 are too tight while 3 and 4 are fine.
https://scontent-b-lhr.xx.fbcdn.net/hphotos-frc3/t1.0-9/10308302_10154032987265258_4002090570810439075_n.jpg
PostPosted: 10:11 - 23 Apr 2014    Post subject: Reply with quote
As Pete says, you want to do that gradually because cam caps can snap and if they do, your head is scrap (the hole for the cam is through-bored with the cam cap in place, they are all slightly different).
I generally undo all the bolts one turn at a time working with diagonal opposites like you would with a cylinder head, then gently tap round the cam cap with a deadblow hammer or a piece of wood so it's resting up against the bolts. Rinse and repeat until it's free to move.
Put them back on the same way, little by little and diagonal opposites so they go down square. There is probably a tightening order in the workshop manual. I usually torque them down in two or three stages once they are all the way down.
Also make sure the cam lobes are facing away from the valves so the valvce springs aren't popping the cams up.
DrSnoosnoo
PostPosted: 10:17 - 23 Apr 2014    Post subject: Reply with quote
I did undo them bit by bit but I probably should have been knocking them to sit up with the bolt. I followed the order that's embossed over the covers, they're numbered 1 - 16 so I undid 16 to 1. I'll cut my losses, put it all back on and untighten again trying to raise it as I loosen it all up.
As for the Cam lobes, the manual told me to make it TDC so I did that.
I hope my head isn't scrap!!! Don't scare me like this!
DrSnoosnoo
PostPosted: 10:19 - 23 Apr 2014    Post subject: Reply with quote
Double post, having some weird errors form bcf today!
PostPosted: 11:03 - 23 Apr 2014    Post subject: Reply with quote
If you're getting "gateway timeout" errors. Your post will usually have been successfully added to the thread. Try opening the thread in a new tab to check before clicking back and re-posting.
Also. Sticky cam caps usually come up with a cracking noise. Gets my ringpiece going every time!
DrSnoosnoo
PostPosted: 11:43 - 23 Apr 2014    Post subject: Reply with quote
Yeah I pressed Refresh on autopilot which reposted.
Yeah I did hear a cracking the first time and shat it. Once this is out I need to get the cams out and not loose the chain and hopefully not fuck the timing. Is tipex alright to use in oil? or should I just make do with a permanent pen?
mentalboy
PostPosted: 18:33 - 23 Apr 2014    Post subject: Reply with quote
Take an old wire coat hanger. Open it out and thread it under the chain between the cams so it supports the chain across the length of the head, also stuff some clean rag down the cam chain shaft so that if you drop anything you won't be wondering how to fish it out of the depths!
Take a look at the markings on the cam chain sprockets. Observe how they are lined up - You may need to put a small something in the adjuster hole to take up the slack in the chain. Theoretically there should be a marking on each sprocket that is in line with the cylinder head - if the lower end is still in the correct position. You shouldn't need any marker pens etc Smile
Make mine a Corona.
DrSnoosnoo
PostPosted: 20:36 - 23 Apr 2014    Post subject: Reply with quote
So I got the camshafts off by bolting down the other side of the bearing whatsit and then turning each bolt out by half a turn then giving a whack with a rubber mallet and repeated until they were fully turned out. Got the chain hanging on a massive spanner, the cams have the markings on and I took a picture so I'll be prepared to get it back on with the correct timing, I hope.
Found that all the shims were 3mm, so perhaps they're still the stock ones? Ordered 5 replacements from wemoto too so now im waiting.
Wondering whether I should whip the carbs off to check the jets and what have you are at the factory settings, or shall I leave it as it is because it was working fine?
mentalboy
PostPosted: 20:53 - 23 Apr 2014    Post subject: Reply with quote
Firstly I hope that you weren't describing your hammer action literally!!! Shocked
Have you already ordered the shims? I had the same situation as you fairly recently and discovered purely by chance that it was more economically sound to buy a 'trade' pack of shims (obviously making sure you get the right diameter!!).I think there were about ninety in a box for about £70 which worked out cheaper than the 12 OEM's that I'd been quoted for and gave me a huge amount of options for chopping and changing shims as necessary.
Also gives you somewhere handy to store old shims - don't throw them away as you'll never know when they'll come in handy!
Make mine a Corona.
DrSnoosnoo
PostPosted: 07:14 - 24 Apr 2014    Post subject: Reply with quote
I was waiting for someone to ask about my hammer action haha! Nah it was a few taps with the hammer between my fingers, really not hard at all.
I've ordered 5 from wemoto for 23 quid, just didn't have the money to buy a big box like you suggest. Probably would next time though! They were 3.58 each so not too costly this time.
DrSnoosnoo
PostPosted: 10:16 - 26 Apr 2014    Post subject: Reply with quote
They look like pair valves, you're bike Fi? If they are....you don't need em Wink 'Suspicious why one is oilier........worn valve seal maybe?
You're brave if you've never done valve clearances before......my advice would be to check everything three times......and keep your oil ways clean. Wink
Nope it's a carby! Yeah I'm brave but also tight, I don't wanna pay hundreds on this bike that isn't worth much anymore.
The way I see it, if I can get to my final year of a PhD, I can follow some Haynes manuals with the right tools and the internet.
The last post was made 12 years, 208 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.12 Sec - Server Load: 0.53 - MySQL Queries: 15 - Page Size: 113.02 Kb
