SV650 - Lights are on but nobody is home.....like its owner!
Pigeon
PostPosted: 19:00 - 24 Apr 2014    Post subject: SV650 - Lights are on but nobody is home.....like its owner! Reply with quote
tl:dr Does my alternator or battery have bad juju? Or was the super cheap USB adaptor not the best idea?
I feel like a sponge on BCF, trying to soak up info. I've used some of the previous help received to get to a point and am hoping someone can advise.
Parked the bike last night, all good. Went to start it this morning and there was a very slight 1/4 move of the cylinders and nothing else. Dash lights on, but repeated presses of the start button didn't do much.
Switched the kill switch on, then off. Sat on the bike, put sidestand up. Clutch out, then in. Tried again, nada but the dash lights.
At the weekend I stuck in a USB adaptor into the 12v ciggy socket I wired into a fuse box that’s wired to the battery. No devices where connected to the USB ports, but I removed the adaptor from the ciggy socket just in case. Then stuck the battery on charge and went to work via the other bike.
9 hours later and Optimate is flashing green, indicating the battery is charged and holding its charge.
I unplug the charger and faff around, an hour passes and a multimeter on the batter terminals reports 13.14v
The bike starts instantly and battery is now 13.70v
I slowly increase the revs to 6k rpm and the output of the battery falls! 13.30v
I wasn't expecting that, I thought it was supposed to rise to near 14v, or am I wrong?
I switch on the lights and at tickover its 13.30v, then 12.70v@6k
If it's a 12v battery, then putting out 12.7 with all the lights on at cruising revs doesn't seem bad to me. But I don't know what I'm talking about.
One thing, the battery is a YT12ABS (correct for the bike), but its a Numax brand and only 9.5Ah with 120CCA. The Yuasa YT12ABS is 10Ah and 175CCA. Seems a big difference in CCA.
The Reg/rec has been replaced at some point with one that has a sticker claiming to be made by TourMax
I double checked the wires too/from the battery to my fuse box and I used solder, shrink wrap and insulation tape. There are no exposed live wires shorting that I can see.
I'm leaving it on charge (Optimate cable wired in to fuse box) to get to work. And will measure the v out of battery via Optimate adaptor (not as accurate, but should give a clue, was showing 13.11v) in the morning. Then check in the evening once home. Then I could plug back in the USB adaptor into the ciggy socket and see what happens after 24-48 hours.
Does that seem reasonable?
Do any of the readings above provide cause for further investigation?
Could the USB adaptor have caused this with nothing connected to it?
Many thanks again!!
Nobby the Bastard
Harley Gaydar
PostPosted: 19:22 - 24 Apr 2014    Post subject: Reply with quote
Either your alternator or the wiring to it is fucked.
Triumph Sprint ST 1050
Pigeon
PostPosted: 19:31 - 24 Apr 2014    Post subject: Reply with quote
Sad
Presume you say that on the basis of the falling voltage with rising revs?
Even still, is 12.7v not more than 12v, so even with lights ablaze it's still charging the battery a bit, no?
Nobby the Bastard
Harley Gaydar
PostPosted: 19:45 - 24 Apr 2014    Post subject: Reply with quote
Sad
No, the falling voltage is due to your battery being drained because the alternator isn't charging it.
With a charged battery, you should be able to read about 14.5 v across the battery with the engine running, regardless of the revs.
Pigeon
PostPosted: 20:00 - 24 Apr 2014    Post subject: Reply with quote
Arse! Going to have to look through the Haynes manual and try and confirm the thing(s) which need replacing.
I've had the bike a month and it's started ok. But only really used the lights for the last few days when we had fog in the morning and rain / dark at night.
While I spend time looking into it, could a 10.5Ah Yuasa battery give me more time over a 9.5Ah Numex?
Once running, could it cut out on me at night? If it's discharging it could. Maybe the 10Ah would give me more time.
Carvel
PostPosted: 20:06 - 24 Apr 2014    Post subject: Reply with quote
Reg/rec.
Pigeon
PostPosted: 20:21 - 24 Apr 2014    Post subject: Reply with quote
Carvel wrote:
Reg/rec.
Buying the cheapest bike on ebay in Guildford during March was probably not my best idea. Probably should have spent more and gone for the CBR600 Smile
I had a look and a few more are available now, £2k would have got a nice one. Oh well.
It's wet this weekend, so another 10 hour stint in the garage shoving multimeter probes into various things sounds a good thing to do.
Just seen this post, same symptoms as me
https://forums.sv650.org/archive/index.php/t-164281.html
Several people finding that the reg/rec needs another earth to the battery.
I've got my new extra fusebox under the rear seat, that is wired to the battery (both + and -). Presumably I could run a + and - from the reg/rec to my fusebox, which would be handy as they are next to each other.
But I'll test with just the earth first to see if it makes a difference.
I'll still check the reg/rec ac v too..... not done that before, got the Haynes though.
PostPosted: 20:29 - 24 Apr 2014    Post subject: Reply with quote
Pigeon wrote:
Carvel wrote:
Reg/rec.
Exact same symptoms as my 'busa the year before last. Your comment about the battery earth carries a lot of weight too because my problem turned out to be a connector on the loom earth.
At the battery look to see if the negative terminal has two black wires crimped into it. If it does, follow the thinner of the two to see if it has a single spade terminal connector in it before it disappears into the loom. If it does, un-plug it and check it's condition. Mine was all coated in oxidisation, cleaning it fixed the problem for the year but it started creeping back so I cut that connector off and crimped a ring terminal to it and put it directly on the battery.
Pigeon
PostPosted: 21:05 - 24 Apr 2014    Post subject: Reply with quote
Thanks Pete!
I'm not good with mechanics, but enjoy it. I'm useless with electrics and don't enjoy it, but maybe that's because I don't understand it even at a basic level. Must make more effort.
Will make a start Friday evening and maybe get lucky with earth.
A reg/rec from a CBR1000RR seems a good mod. It's larger and still fits. But that'll depend on the multimeter results.
I suspect I'll be back tomorrow asking for more translations of numbers Smile
Cheers all! Thumbs Up
PostPosted: 21:10 - 24 Apr 2014    Post subject: Reply with quote
I would highly recommend an Electrex World reg/rec. Both my BB and R1 have have one. Give out superb voltage.
I would however be cautious, its an SV and the only experience I have had is electrical failure, same shape too. Started smelling of eggs.
Carvel
PostPosted: 21:27 - 24 Apr 2014    Post subject: Reply with quote
Just fitted one of these to my Cbr600, another thumbs up from me Thumbs Up
sickpup
Old Timer
PostPosted: 21:35 - 24 Apr 2014    Post subject: Reply with quote
Guess who makes them?
PostPosted: 21:41 - 24 Apr 2014    Post subject: Reply with quote
Someone with the surname Xing?
sickpup
Old Timer
PostPosted: 21:53 - 24 Apr 2014    Post subject: Reply with quote
Generally they are just genuine Reg/recs from what I can tell. The Tourmax ones are genuine, normally Shindengen ones that are bought up as excess to requirements.
Tourmax isn't a company as such it is a group of Japanese companies selling under the same banner so they do all sorts of things bike related. If you buy there brake pistons and seal set they often come in genuine Honda packaging.
Pigeon
PostPosted: 21:59 - 25 Apr 2014    Post subject: Reply with quote
Been in the garage for 3 hours probing stuff. Some of the results are junk though I think.
I was using a Draper 52320 (the budget one).
https://i1329.photobucket.com/albums/w559/pigeon35/Random/draper_52320_zps169067e2.png
1. Checked battery for current leaks.
+ tester to - loom, - tester to - bat
Showed nothing at 200m DCA and 20m DCA.
I then put the USB adaptor into the ciggy socket (but with nothing connected to it. And registered 30.00 @ 200m DCA
So is that 30mA draw, surely not enough to flatten a 9.5Ah battery?
Would that be 9.5 / (30/1000) = 316 hours? mmmm, maybe 5 days of that would be enough to reduce the battery enough to not crank.
2.Measure charging voltage between battery terminals (on fully charged battery from Optimate).
Lights on @ 5k rpm = 12.70v having idled at 13.30
"Under 13.5 or over 15 inspect the Stator Coil, reg/rec".
So this is as yesterday, 12.7v means a possibly bad sign
3. Disconnect the generator coupler by the reg/rec. Check resistance on genny end of the 3 yellow wires.
I set the multimeter to 200 OHM and placed the red wire from multimeter to the first digit in the following list and the black to the second.
1-3 = 0.9
1-2 = 0.9
2-3 = 1.0
3-Earth I assume that is what the diagram meant by a horizontal black bar with wavey lines under it, sort of:
Anyway, nada. 3-Earth = no reading. I was earthing on the subframe and the loom off the negative on the battery.
So I went:
3-1 = 0.9
The manual says the SV should be 0.2 to 0.55
So I'm well out, indicating "replace the stator"
But the multimeter was set to 200OHM with a
"+/- 1.5% rdg +/- 4 dgts"
So how can I trust that 0.9 isn't in fact 0.2 or 3?
I'm loathe to replace stator (£75) and lose £25 of recent oil on the back of that test which seems to have such a margin for error.
4. Genny no load test
Multimeter set to 200 ACV
Engine running at 5k rpm
1-3 = 83
1-2 = 79
2-3 = 80
3-Earth missed this one I think because of above.
3-1 = 83
Spec = Over 70v. So that's good, no? The genny is hitting the reg/rec with a bunch of juice. Moreover it rose from 55-60v at idle to 80-85 at 5k rpm. Unlike the battery voltage test, which showed a collapse in voltage at higher rpm.
5. Reg/rec inspection. WTF happened here! I got very lost.
https://i1329.photobucket.com/albums/w559/pigeon35/Random/20140425_211802resized_zpsa7d2f79d.jpg
The multimeter was set to Diode (although the SV manual showed image which I now know means "Forward" and the diode on the Draper is set to "Reverse") But I cracked on carrying out the probes as per the sheet....or so I thought.
So when the positive was in Y1, Y2, Y3, B&W with the negative in the R. I got readings of 620+
When the positive was in B&W and negative in Y1, Y2, Y3, R then I got 620+. All others were 1.
Not exactly a range of 0.4 to 1.5!
There is no explanation of the Diode test in the Draper 52320 manual.
But there is in the 78998 manual.
"a. Touch the test probe tips to the diode or semiconductor junction you wish to test. Note the meter reading"
"b. Reverse the probe polarity by switching probe position, note the reading".
"c1. If one reading shows a value and the other reading shows 1, then the diode is good".
"c2. If both show 1, device is open"
"c3. if both are small or 0, device is shorted"
The SV sheet said "Diode Test" Which I did by placing the probes as per the grid. But seeing the Draper manual I did not do a diode test completely. And the SV sheet refers to "measure the voltage between the lead wires"
But hang on, thats not the Diode test
Should I have set the multimeter to 2000m DCV and carried out the test as per the grid instead of the setting you see in the pic?
But if that is the case, where is the voltage coming from?
The notes say "disconnect the generator coupler" That still leaves the B/W and R block going to the battery.
Was that reg/rec test in fact two parts, one the diode test and two a voltage test?
Sorry for making your head ache. Mine is fried Confused
TheCatSatOnTh...
PostPosted: 22:12 - 25 Apr 2014    Post subject: Reply with quote
By genuine do you mean OEM? They claim to make their own in the UK and they apparently use MOSFET, which according to more knowledgeable than me (a search suggests your name mentioned regarding this) on this forum (and their marketing), is more reliable than 'standard' shunt type.
For all I know though all reg/rectifiers are MOSFET since 1900s. Laughing
Pigeon
PostPosted: 23:30 - 25 Apr 2014    Post subject: Reply with quote
OK, so I followed https://www.youtube.com/watch?v=F8EjV0IjW9Q to do the diode check and got the following:
M = multimeter lead
R = Positive on Reg/rec
BW = Negative on Reg/rec
Code:
            Y1    Y2    Y3
M+ -> R     1      1      1
M+ -> BW   640   660    659
M- -> R    664   647    656
M- -> BW    1      1      1
Which apparently points to an OK reg/rec. Not guaranteed. But not obviously knackered.
Last thing to try tomorrow is this extra earth wire I guess.
janner_10
PostPosted: 06:35 - 26 Apr 2014    Post subject: Reply with quote
Just going on the output from the alternator (and the balance of the winding resistance) I would say your problem lies with the Reg / Rec.
What you are feeding into it is fine, buts its output is not enough. I may of missed if you have done it, but take the reading directly from the DC side of the reg / rev in addition to the battery terminal reading - this will confirm if your loom is good.
Also, hats off for trying to fix and diagnose yourself.
Makes a refreshing change to read someone 'having a go' Some right wet fart post lately in the Workshop section by folk that just haven't a clue and don't really want to learn. Some twat taking his bike to a dealers for an oil change being an example.
Pigeon
PostPosted: 09:10 - 26 Apr 2014    Post subject: Reply with quote
janner_10 wrote:
What you are feeding into it is fine, buts its output is not enough. Take the reading directly from the DC side of the reg / rev in addition to the battery terminal reading - this will confirm if your loom is good.
Thanks for the advice! Just to double check my understanding, this is to test the voltage output from the reg/rec?
So start the engine, set the multimeter to DCV 20 and get the probes into the end of the connection box that comes straight out of the reg/rec, then rev to 5k rpm?
Makes a refreshing change to read someone 'having a go'.
Thanks mate! Very Happy
I'm a bit slow on the uptake (spent 10 hours changing 1 tyre), but do enjoy taking something not good, learning something, applying it and making it better (hopefully). Saving money is also a big factor.
Sometimes things go wrong (front Caliper falling off at 40mph), but hopefully don't make the same mistakes again Smile
Clutchy
PostPosted: 09:36 - 26 Apr 2014    Post subject: Reply with quote
While you are waiting for more advice, I'd so go and check everywire/connection on the charging circuit if you can, I have a 3 page read over 2 months and we could not work it out as it was intermittent, wasted a lot of money and it turned out to be a broken wire in the middle of the loom.
Might be worth a look anyway. Thumbs Up
janner_10
PostPosted: 09:43 - 26 Apr 2014    Post subject: Reply with quote
Spot on - measure the output directly from the Reg / Rec and then at the battery terminals - they should match if the loom is good. Post up your results.
The meter set to DCV 20 is correct.
kramdra
PostPosted: 12:35 - 26 Apr 2014    Post subject: Reply with quote
You need to check wiring. Regulators usually die because of poor connections. Almost every dead one will have burnt or heat damaged/corroded connections joining loom and if this was not repaired last time, it will happen again. It will also fuck the battery and stator. My cbr2500rr for example - no problems with regulator yet but the connectors are fucked, burnt and corroded.
As for the test procedures they are often a load of shit:
For example the stator coil ohm test - normal cheap multimeter cables can not accurately measure under 1R. This test is somewhat pointless and best to check voltage and do a load test on each coil. The actual voltage is irrelevant, as long as it is above 20v, rises with revs and all similar.
Load test - get 3x 2R, 200w rated resistors (or make, I use nichrome wire). Connect between phases, measure the voltage drop between each. This will also tell you the current so no need to measure it. If they seem fairly balanced, then all is good.
Pigeon
PostPosted: 19:29 - 26 Apr 2014    Post subject: Reply with quote
tl;dr Had some ups and downs Smile Haven't finished, old reg/rec is welded itself to frame.
Went out to start 10:30, 5 mins later door bell goes and it's the postman with my shiny new GSX-R1000 reg/rec. Nice timing sir, oh and whats this, a cheque for £75 from SSE as a goodwill gesture for the xmas power outage. Hope this luck is a theme for the rest of the day.
Back to garage, 5mins later door bell again, parents have paid a surprise visit. Bike has to wait. We watched last weeks BSB round and I did lunch, they left at 4pm.
Back to garage. So to test the output from the old reg/rec direct. Disconnect the Optimate (green lights flashing) that's been on all night/day. Ignition on.....no dash lights. Tried it a few times, tried the side stand. Nothing. FFS!
Start to get that creeping feeling that I've bitten off more than I can chew and have made the situation worse and killed my bike! Sad
I swear a lot and kick the clutch cover (not the smartest idea). At that exact moment of searing pain, the 250w Metal Halide floodlight that I fitted to the garage so I can work on bikes in near daylight blows! ***** **** ***** ***** Bulb is supposed to last 8,000 hours and I think its done maybe 500 in 18 months.
Starting to spot a theme with my dodgy wiring.
Luckily the darkness now provided by 2 15 year old 36w fluorescent tubes calms my panic attack.
Check the battery with multimeter 13.60v. So check mini fuses (specifically 10a ignition), they are fine. Check starter solenoid. mmm 30a fuse looks blown, can't see in the darkness. Try to extract it, can't. Use pliers gently to lever it out. It just disintegrates. The plastic is so brittle it just crumbles. How on earth did that blow by itself overnight? The only thing on was the Optimate.
That £75 cheque seems a long time ago.
Disconnect battery from loom, remove solenoid, get the fuse out, replace with a new and re-install. Double check there are no live wires shorting. Apply more insulation tape to bends and joins just in case.
Re-connect battery to loom.
Ignition on, we have lights, thank fuck!! Smile
Use multimeter, check output from reg/rec with lights on and engine from tick-over to 5k rpm. I add an extra earth wire from the reg/rec to the crank case as a test. It does nothing, get same values as when testing battery. Starts 13.60 drops to 12.90. So .20 better, but confirms your thoughts, not a dodgy loom but the reg/rec.
Thanks to Brooks Barn + Royal Mail, we have a shiny new one.
Did the Diode test on new reg/rec No issues. 1's in the rights places and all the numbers were 538-540
Use a hacksaw to remove the single junction box on the GSXR unit, so have the 5 spade wires. The 3 for the stator I just re-crimp, solder, shrink wrap and insulate. The live and earth I fit spades to, solder, wrap and insulate. Unplug the old reg/rec and just plug the individual wires into the halves of the old junction boxes on the old loom.
Fire up the bike again and the battery reads 14.20v at just over tickover Smile At 5k rpm it's rock steady at 15.00v (maybe a touch high now?). Lights on and its steady at 14.40v
I'm deliriously happy, thanks guys, brilliant result! Mr. Green
So just a case of simply unscrewing the old unit, screw in the new and button everything up. Except I can't get the old unit off. I've been trying for 90mins with "shock + release" spray. I've tried hitting the screwdriver with a hammer, tried levering the thing a little. All in the hope it cracks the rust. But all I've done is start to round off the heads.
There isn't a nut the other side, instead it looks like the screw goes through a collar. The ends of the screws poke out and appear split like a self locking bolt.
I'm at another loss here. I have a battery powered drill which I'm charging now. No idea if it's up to the job. But presume the only thing to do here is drill holes with increasing size of drill bit until I can get this bugger off?
Apologies for the Tef post, it's been a long day!
Light at the end of the tunnel. So close.
https://i1329.photobucket.com/albums/w559/pigeon35/Random/20140426_173303resized_zps188d0cd9.jpg
Carvel
PostPosted: 20:03 - 26 Apr 2014    Post subject: Reply with quote
Carvel wrote:
Reg/rec.
What do I win?
Get a 10mm socket on a 3/8 drive ratchet and lean on it, they'll go eventually. A screwdriver wont get you anywhere.
PostPosted: 20:17 - 26 Apr 2014    Post subject: Reply with quote
15 is a little too high... my SV was reading 16.5v when it cooked itself.
Did you order the correct regulator by any chance...? I'm sure some bikes won't cry about it, like fitting R1 regulators to Fireblades etc but unsure if the SV is picky.
The highest reading I've had on a known healthy charging system is 14.4v. Glad to see you are fiddling though Very Happy
The last post was made 12 years, 206 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.10 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 147.45 Kb
