| jamesrs250 |
 jamesrs250 Nova Slayer
 Posted: 22:43 - 26 Apr 2014 Post subject: ER6 starting / running problem |
i have a problem with a er6 it was running fine last week
I went to start it today and it has trouble starting. when it does it will idel for a bit the stall. when i rev the bike it does not run right.
i have check the for a spark on the plugs both have a good spark
here is a quick vid
https://www.youtube.com/watch?v=x8hNstaZSTA&feature=youtu.be |
| Scotsman37 |
 Scotsman37 World Chat Champion
 Posted: 07:29 - 27 Apr 2014 Post subject: |
Seems likely your idle jets are clogged up because it seems once you've managed to get pass idle it throttles up good, but when you let go of the throttle and it goes back to idle it dies! The carbs need cleaned out!
What can cause this your fuel tank inside maybe starting to RUST up inside, and therefore very fine particles of rust is getting sucked into the carbs eventually clogging it up! So, for good measure install an inline fuel filter that is appropriate for your 600cc bike, and make sure its for larger bike not like a 125cc which allows less fuel through at higher speeds.
If it is rust you MUST either get the inside of the fuel tank treated to remove any internal surface of rust or install an inline fuel filter, and then you CAN remove the Carbs to get access to the bowls for the idle jets to clean them out with Carb cleaner & can of compressed air to blow out stubborn crap! You only have to remove the bowls and NOT the top capped part of it! Work on the removed Carbs in open aired area because the strong stench can possibly overwhelm you and even stink out your place for a very long time! It takes about 5 minutes with a disconnected fuel line to burn off the fuel in the carbs before removing it to minimize spill of fuel.
Alternative solution that may work?
Get some fuel treatment solution for it to put in the fuel tank and you could get a can of Motul Carb Cleaner, which I have found to be better than other brands, remove your bike's air filter, start it up as you did in the video but KEEP the throttle on and then start spraying a good dose of that Carb Cleaner, as it may help to begin cleaning it out - Even after you've sprayed a good dose of it keep the throttle on for about 5 minutes, if you can? I would still install an appropriate type of inline fuel filter for good measure in case there is a problem coming from the fuel tank!
P.S. If you do have to the remove the Carbs put something like a thick rag/old bit of carpeting to prevent damage to it while sitting it on a hard surface and then use an Impact Driver to begin the removal of the screws holding the carb's bowls on because you don't want to strip the heads off them with the start of normal screwdriver. DO NOT touch the top part of the Carbs otherwise you'll have a hell of a time to put the rubber diagrams back in place.
| janner_10 |
 janner_10 World Chat Champion
| jamesrs250 |
| janner_10 |
| Scotsman37 |
| jamesrs250 |
| wots |
 wots World Chat Champion
| jamesrs250 |
The last post was made 12 years, 206 days ago. Instead of replying here, would creating a new thread be more useful? |
