ER6 starting / running problem
jamesrs250
PostPosted: 22:43 - 26 Apr 2014    Post subject: ER6 starting / running problem Reply with quote
i have a problem with a er6 it was running fine last week
I went to start it today and it has trouble starting. when it does it will idel for a bit the stall. when i rev the bike it does not run right.
i have check the for a spark on the plugs both have a good spark
here is a quick vid
https://www.youtube.com/watch?v=x8hNstaZSTA&feature=youtu.be
Scotsman37
PostPosted: 07:29 - 27 Apr 2014    Post subject: Reply with quote
Seems likely your idle jets are clogged up because it seems once you've managed to get pass idle it throttles up good, but when you let go of the throttle and it goes back to idle it dies! The carbs need cleaned out!
What can cause this your fuel tank inside maybe starting to RUST up inside, and therefore very fine particles of rust is getting sucked into the carbs eventually clogging it up! So, for good measure install an inline fuel filter that is appropriate for your 600cc bike, and make sure its for larger bike not like a 125cc which allows less fuel through at higher speeds.
If it is rust you MUST either get the inside of the fuel tank treated to remove any internal surface of rust or install an inline fuel filter, and then you CAN remove the Carbs to get access to the bowls for the idle jets to clean them out with Carb cleaner & can of compressed air to blow out stubborn crap! You only have to remove the bowls and NOT the top capped part of it! Work on the removed Carbs in open aired area because the strong stench can possibly overwhelm you and even stink out your place for a very long time! It takes about 5 minutes with a disconnected fuel line to burn off the fuel in the carbs before removing it to minimize spill of fuel.
Alternative solution that may work?
Get some fuel treatment solution for it to put in the fuel tank and you could get a can of Motul Carb Cleaner, which I have found to be better than other brands, remove your bike's air filter, start it up as you did in the video but KEEP the throttle on and then start spraying a good dose of that Carb Cleaner, as it may help to begin cleaning it out - Even after you've sprayed a good dose of it keep the throttle on for about 5 minutes, if you can? I would still install an appropriate type of inline fuel filter for good measure in case there is a problem coming from the fuel tank!
P.S. If you do have to the remove the Carbs put something like a thick rag/old bit of carpeting to prevent damage to it while sitting it on a hard surface and then use an Impact Driver to begin the removal of the screws holding the carb's bowls on because you don't want to strip the heads off them with the start of normal screwdriver. DO NOT touch the top part of the Carbs otherwise you'll have a hell of a time to put the rubber diagrams back in place.
janner_10
PostPosted: 07:35 - 27 Apr 2014    Post subject: Reply with quote
Start with the simple things before thinking you need to dismantle the carbs.
Put a multi meter across the battery.
Should be around 12.5v when engine off and > 14v when the engine is on.
jamesrs250
PostPosted: 10:06 - 27 Apr 2014    Post subject: Reply with quote
cheers for the reply but the er6 is injection,,,
if it was carbed i could find the problem and fix it..
but as it is injection i have no idear where to start
janner_10
PostPosted: 10:07 - 27 Apr 2014    Post subject: Reply with quote
Start with the battery
Scotsman37
PostPosted: 10:19 - 27 Apr 2014    Post subject: Reply with quote
Ok, oops! lol
Have you double checked to see that the fuel pump is working properly?
jamesrs250
PostPosted: 12:10 - 27 Apr 2014    Post subject: Reply with quote
Ok, oops! lol
prity sure it is because you can here it the fuel pump prime..when you turn the ignition on
wots
PostPosted: 14:20 - 27 Apr 2014    Post subject: Reply with quote
Sounds to me as it's not actually firing properly on both, maybe just on one then it kind of goes. In any event, coil pack, they are renowned for rusting the metal band in the bore. You'll know if they've rusted, they are a twat to get out. I replaced mine and both had cracked. The top of the spark plugs was rusty too.
EDIT: https://www.bikechatforums.com/viewtopic.php?p=3834354
jamesrs250
PostPosted: 16:30 - 27 Apr 2014    Post subject: Reply with quote
YEAH I KNOW took me ages to get the old ones out they come out in bits..so have fitted new coils
The last post was made 12 years, 206 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.10 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 62.44 Kb
