gz 125 marauder brake dragging
jetticusblack...
PostPosted: 21:18 - 28 Apr 2014    Post subject: gz 125 marauder brake dragging Reply with quote
Hey guys
recently got myself a half decent budget gz125 and spent today with it in the house checking it over and giving it a shine
found the brake light spring broken so fixed that
throttle felt really loose so tightened it accordingly
gave clutch cable bit of a tighten as it didnt feel great, is a lot better now
back brake is great
new battery and lights are all great but will need to bump for first run to help battery out as pressing starter just makess a single click sound
Stripped damaged stickers off and replaced torn grips
only issue left is my front brake, it is dragging slightly and doesent feel nice, ive been told the pads were replaced recently.
i tried removing the two bolts and pulling the caliper off to look but its refusing to come off the disk!
Help! Smile
davebike
PostPosted: 07:38 - 29 Apr 2014    Post subject: Reply with quote
Calliper is sized
You will need to leaver the pads apart and the calliper off the disk without bending the disk
It may help to drain the brake fluid
I expect you have to remove the pistons clean the seal groves in the calliper and replace the seals or possible fit new ones
The pistons should clean up with green scourer and WD40 type fluid
Clean the sliding pins
reassemble with red brake grease
Don not use copperslip it will damage the rubber components of brakes
Dave
Dave
NC750Xdct + others at work !
[email protected]
jetticusblack...
PostPosted: 09:02 - 29 Apr 2014    Post subject: Reply with quote
Ok so ive drained fluid now and disassembled but cant get piston out it wont budge
davebike
PostPosted: 09:37 - 29 Apr 2014    Post subject: Reply with quote
You need a specialist tool
A sort of internal collet chuck that fits to a slide hammer
https://www.ebay.co.uk/itm/LASER-TOOLS-3673-MOTORCYCLE-BRAKE-PISTON-REMOVAL-TOOL-/201012446249?pt=UK_Hand_Tools_Equipment&hash=item2ecd468429
You probably now have a job for a workshop Sad(
Dave
[email protected]
jetticusblack...
PostPosted: 09:43 - 29 Apr 2014    Post subject: Reply with quote
I hope not ive not got many pennies at all was hopeing itd be less of a job than it is, and i can get a new caliper for 50 spose it would be pretty easy to replace considerin its all off already Sad
smegballs
PostPosted: 09:45 - 29 Apr 2014    Post subject: Reply with quote
Fill it with fluid again and pump it without pads in to push the pistons out. If it is a single piston happy days. If not use a pad and a g clamp to incrementally push both pistons out. Eventually they will both be so far our they they can be take out by hand. Compressed air will also get them out, put the pop will make you jump!
For fifty quid you can rebuild the caliper with a new seals and a stainless steel piston, and never worry about it seizing again barring a bit of light cleaning every time you change the pads.
smegballs
PostPosted: 10:09 - 29 Apr 2014    Post subject: Reply with quote
While a slide hammer is a useful bit of kit to have, I doubt that setup can generate as much force on the pistons and the hydraulic fluid does in normal operation!
jetticusblack...
PostPosted: 20:57 - 29 Apr 2014    Post subject: Reply with quote
Ok so i got someone to rebuild it today and it should be back to its former glory, all lines are completely empty now and it is all refitted but its now not pulling fluid from the reservoir downwards even when i try moving lever etc
i guess this is because theres no fluid in pipes its not working to pull it through but its got me stumped, tried leaving it tried all things i know...
davebike
PostPosted: 07:06 - 30 Apr 2014    Post subject: Reply with quote
Ok
Now you need to bleed the system
The way I used before I had modern kit
Get a long length of clear plastic pipe that fits the bleed screw
Push it on with the open end HIGH and undo the bleed about one turn
Suck on the pipe while working the leaver and watching for fluid in the pipe
As soon as the leaver feel different or fluid appears stop sucking
Keep pumping close the bleed screw if it pumps up hard your done if no re open the bleed and pump some more and try again
DAve
Dave
[email protected]
jetticusblack...
PostPosted: 09:21 - 30 Apr 2014    Post subject: Reply with quote
Sucking is giving me nothing still, reservoir is full, bleed open and suck and fluid isnt moving down at all
Tried moving lever and nothing doesent to diddley
Ive checked brake lines for blockages of which there are none
jetticusblack...
PostPosted: 09:37 - 30 Apr 2014    Post subject: Reply with quote
jetticusblack...
PostPosted: 09:47 - 30 Apr 2014    Post subject: Reply with quote
jetticusblack...
PostPosted: 10:29 - 30 Apr 2014    Post subject: Reply with quote
Also tried fixing hoover to bleed line and doing same as instructed and still getting no movement..
jetticusblack...
PostPosted: 10:30 - 30 Apr 2014    Post subject: Reply with quote
jetticusblack...
PostPosted: 20:16 - 30 Apr 2014    Post subject: Reply with quote
Fixed! Wahoo! Few hours blowing sucking and massaging pipes *ha*
Found the master cylinder piston/spring was jammed so sorted that out
spent a while blowing fluid into the caliper, then managed to finally get it to take and gravity bled it through
thank you for the advice and help it deffinitely did help Smile
Ariel Badger
PostPosted: 20:53 - 30 Apr 2014    Post subject: Reply with quote
Sucking you say (repeatedly), I may have a little job for you Mr. Green
jetticusblack...
PostPosted: 00:49 - 01 May 2014    Post subject: Reply with quote
filthy haa Razz
The last post was made 12 years, 202 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.11 - MySQL Queries: 13 - Page Size: 92.54 Kb
