CDIs mounting question... (EMF?)
mr.z
PostPosted: 14:31 - 10 Jan 2005    Post subject: CDIs mounting question... (EMF?) Reply with quote
A weird question but...
Going to be moveing my cdi units, they are monuted at the moment verticaly with a couple of mm appart... the plan is to mount them horizontaly tapeing them together and giveing them adiquate anti vibe protection..
Question is, will they interfere with each other in any way if they are mounted together? i mean stuff like EMF interferance, or any other i'll effects? should i bother insulateing with tin foil or something like that?
pipnet11
PostPosted: 14:38 - 10 Jan 2005    Post subject: Reply with quote
EMF, thats A-level physics time again, cant really remember all that. lol. I would be very surprised if there would be enough interference to cause a problem.
I love the girls that do, I hate the girls that dont, I hate the girls who say they will and then they say they wont, but the girl I like most of all and I think youll say Im right, is the girl who says she never has but looks as though she might. - Max Bygraves
mr.z
PostPosted: 16:00 - 10 Jan 2005    Post subject: Reply with quote
Good good, i was pretty sure.. i didn't want something like it causeing all four plugs fireing at the same time or something Shocked
I'm not sure why i was thinking it would? i dunno...
Thanks for that though Thumbs Up
PostPosted: 21:48 - 10 Jan 2005    Post subject: Reply with quote
Suck it and see is my advice. Tape them together then try starting the engine.
It shouldn't cause a particular problem even if they did both fire together on most bikes.
mr.z
PostPosted: 11:03 - 11 Jan 2005    Post subject: Reply with quote
Good stuff, well dremeled the back of the cdi off and after picking all off the.. whatever it was sealing it, resoldered all the points inside, tested it out and it worked perfic Very Happy (at least seems to, before it didn't work for more than 10 seconds)
Covered it in sillicone sealant (bathroom stuff), waiting for it to dry.. another question now.. when its wet is it going to conduct electricity? i want to road test it Sad meeeeh...
No bike for 3 days and ive got withdrawal symptoms, is that unhealthy?
Big Pete
PostPosted: 11:58 - 11 Jan 2005    Post subject: Reply with quote
Did the silicon smell vaguely of vinegar? If so you are going to have corrosion problems with the Cdi circuitry. Bathroom silicon is usually acetic acid based (thats the vinegar smell) and will attack the copper on the PCBs. Shocked I would start looking for a replacement CDi if I was you. If you need to re-pot electronics again, go to Maplins and get some potting compound or some high voltage putty.
Trust me, I`m an engineer
GarageOfPower.co.uk
mr.z
PostPosted: 13:00 - 11 Jan 2005    Post subject: Reply with quote
tits... it didn't smell acidic, but i'll be takeing it off now anyway...
I'm actually getting a new cdi, phoned the shop and he knew what it was straight away, theres one been ordered, i thought while i'm waiting for a newun i'd try fixing mine, it was allready broke so nothing to loose...
As an alternative ive got some glue sticks, melted down would they do the job? (seeing as i can't GET to maplins on acocunt of the ded bike...)
PostPosted: 13:09 - 11 Jan 2005    Post subject: Reply with quote
Saw your post about the silicone mastic and thought ohshit but Big Pete has covered that one.
How big a hole is it you acutally need to fill up? About the same size as say, a whole pack of araldite?
Big Pete
PostPosted: 14:14 - 11 Jan 2005    Post subject: Reply with quote
hot glue should be ok, most DIY stuff melts around 65C IIRC, so the components in your CD1 should cope OK. I think its non corrosive as well but couldnt say for sure. As its only a temporary thing, why not triple wrap it in cling film?
GarageOfPower.co.uk
mr.z
PostPosted: 15:17 - 11 Jan 2005    Post subject: Reply with quote
Thanks stinkwheel and pete Thumbs Up
I went with the hot glue option, araldite would probably have been better but dont have any at the mo, but have lots of glue sticks Very Happy then cling film and then electrical tape in abundence... got rid of most if not all of the sillicone sealant, wont be doing that again Embarassed
Its clicking away quite happy now, think i will give it a run arround the block in a little while, i think its gonna be fine though...
Thanks again though, appart from the sealnt i'm quite happy with that, amazeing people just bin cdi's and spend £90 when they can be fixed relatively easyly even by me Shocked
The last post was made 21 years, 10 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 68.34 Kb
