| mr.z |
 mr.z World Chat Champion
 Posted: 14:31 - 10 Jan 2005 Post subject: CDIs mounting question... (EMF?) |
A weird question but...
Going to be moveing my cdi units, they are monuted at the moment verticaly with a couple of mm appart... the plan is to mount them horizontaly tapeing them together and giveing them adiquate anti vibe protection..
Question is, will they interfere with each other in any way if they are mounted together? i mean stuff like EMF interferance, or any other i'll effects? should i bother insulateing with tin foil or something like that? ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| pipnet11 |
 pipnet11 Brolly Dolly
| mr.z |
 Posted: 16:00 - 10 Jan 2005 Post subject: |
Good good, i was pretty sure.. i didn't want something like it causeing all four plugs fireing at the same time or something
I'm not sure why i was thinking it would? i dunno...
Thanks for that though  ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| stinkwheel |
 Posted: 21:48 - 10 Jan 2005 Post subject: |
Suck it and see is my advice. Tape them together then try starting the engine.
It shouldn't cause a particular problem even if they did both fire together on most bikes. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| mr.z |
 Posted: 11:03 - 11 Jan 2005 Post subject: |
Good stuff, well dremeled the back of the cdi off and after picking all off the.. whatever it was sealing it, resoldered all the points inside, tested it out and it worked perfic (at least seems to, before it didn't work for more than 10 seconds)
Covered it in sillicone sealant (bathroom stuff), waiting for it to dry.. another question now.. when its wet is it going to conduct electricity? i want to road test it meeeeh...
No bike for 3 days and ive got withdrawal symptoms, is that unhealthy? ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| Big Pete |
 Big Pete Spanner Monkey
| mr.z |
 Posted: 13:00 - 11 Jan 2005 Post subject: |
tits... it didn't smell acidic, but i'll be takeing it off now anyway...
I'm actually getting a new cdi, phoned the shop and he knew what it was straight away, theres one been ordered, i thought while i'm waiting for a newun i'd try fixing mine, it was allready broke so nothing to loose...
As an alternative ive got some glue sticks, melted down would they do the job? (seeing as i can't GET to maplins on acocunt of the ded bike...) ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| stinkwheel |
 Posted: 13:09 - 11 Jan 2005 Post subject: |
Saw your post about the silicone mastic and thought ohshit but Big Pete has covered that one.
How big a hole is it you acutally need to fill up? About the same size as say, a whole pack of araldite? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Big Pete |
| mr.z |
 Posted: 15:17 - 11 Jan 2005 Post subject: |
Thanks stinkwheel and pete
I went with the hot glue option, araldite would probably have been better but dont have any at the mo, but have lots of glue sticks then cling film and then electrical tape in abundence... got rid of most if not all of the sillicone sealant, wont be doing that again
Its clicking away quite happy now, think i will give it a run arround the block in a little while, i think its gonna be fine though...
Thanks again though, appart from the sealnt i'm quite happy with that, amazeing people just bin cdi's and spend £90 when they can be fixed relatively easyly even by me  ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
The last post was made 21 years, 9 days ago. Instead of replying here, would creating a new thread be more useful? |
