Did I get diddled?
SpuceLee
PostPosted: 14:05 - 17 Jun 2014    Post subject: Did I get diddled? Reply with quote
Took my ybr125 into the garage because the electric start wasnt working.
They charged me £133 for reconditioning the alternator (inc. £2.50 for topping up the oil)...is this an average price or have I been diddled?
ybr125
Snorty
PostPosted: 14:08 - 17 Jun 2014    Post subject: Reply with quote
It wouldn't start so they reconditioned the alternator, maybe it was knackered and not charging your battery hence no juice to start it. £133 for a rewind seems... reasonable.
Whether that was the case or not... who knows.
PostPosted: 14:09 - 17 Jun 2014    Post subject: Reply with quote
Well my new alternator for the Blackbird was £90 all in with gaskets. That was brand new and would take half and hour > 45 mins, so an hours labour really, they might charge more... but realistically it is 1 hour. So, diddled.. not really, but its a piece of cake job that you could have DIY and saved £££ Thumbs Up
nowhere.elysium
The Pork Lord
PostPosted: 14:12 - 17 Jun 2014    Post subject: Reply with quote
Because your average garage rewinds stators on a regular basis, of course.
If they fitted a reconditioned stator to replace your old one, then yes, I'd say that £133 for parts & labour sounds about right. If they're claiming that they rewound it for you, when they just charged the battery, then you'd have been entering 'just been screwed' territory.
SpuceLee
PostPosted: 14:16 - 17 Jun 2014    Post subject: Reply with quote
hmmm time will tell i guess
ybr125
map
Mr Calendar
PostPosted: 14:17 - 17 Jun 2014    Post subject: Reply with quote
What year YBR?
Any error codes flashing?
I ask as old this thread about a non starting 2009 YBR talks about error codes from the various flashing frequency of the dash lights.
Then there's this other old thread about a non starting YBR. TL;DR it was the battery.
SpuceLee
PostPosted: 14:29 - 17 Jun 2014    Post subject: Reply with quote
map wrote:
What year YBR?
2008,
no flashing dash lights..although i actually did notice that the engine warning light came on and stayed on whenever i was in first gear
ybr125
Northern Monkey
PostPosted: 14:30 - 17 Jun 2014    Post subject: Re: Did I get diddled? Reply with quote
You should feel a little embarassed that your bike was low on oil. It's something you should check more regularly.
However, it does show they gave your bike a once over while it was there. £133 doesn't seem to bad
SpuceLee
PostPosted: 14:36 - 17 Jun 2014    Post subject: Re: Did I get diddled? Reply with quote
I do check my oil fairly regularly..I assumed they were taking advantage a wee bit as I cant really demand that they take back £2.50's worth of oil can I?
ybr125
Snorty
PostPosted: 14:47 - 17 Jun 2014    Post subject: Reply with quote
I was playing devil's advocate to be honest. I imagine a new stator would be cheaper than a rewind, and as said I doubt they'd do it themselves - so would probably charge more than that for a rewind (outsource + profit on top).
PostPosted: 15:00 - 17 Jun 2014    Post subject: Reply with quote
Oil may come out if you remove the engine case, some do, some don't. Mine did Thumbs Up
barrkel
PostPosted: 15:43 - 17 Jun 2014    Post subject: Reply with quote
They generally send them to a rewind specialist, like Westcountry Windings.
(The last bit stopping my VFR getting back on the road is waiting for the rewound stator to come back...)
nowhere.elysium
The Pork Lord
PostPosted: 15:49 - 17 Jun 2014    Post subject: Reply with quote
Don't make me crack out the captain obvious memes.
On a side note, am I the only one that's found West Country Windings a) to be inappropriately named, given that they're now based in Harlow, and b) more expensive than a replacement stator typically is?
Cyclingbiker
PostPosted: 20:50 - 17 Jun 2014    Post subject: Reply with quote
I recall they wanted £180 for a cg 2 coil stator, i eventually got one for £30 from a breaker, but they're still in business so someone will pay it out of desperation.
Pitstop Motorcycles in Warrington did my 2 pole stator on my CG for £45 with postage back to me. The garage themselves don't do the rewind but hand them to a local chap who does it for them. I found them recommended on UKGSer as WCW had gone to pot. They did a good job Thumbs Up
Honda CB500s (1999) - Honda CG 125 BR-J (1991)
Mod 1 - Passed - 12/11/12 --- Mod 2 - Passed - 26/11/12
suburban myth
PostPosted: 06:04 - 18 Jun 2014    Post subject: Reply with quote
A place near me (Nottingham) does rewinds and repairs on mostly classic and rare pieces. Also makes a bit out of authenticating and certificating replacement clocks ie if you buy a set that say 22000 miles on them when actually your bike has only done 12000, he certificates and documents this.
Mark65
PostPosted: 08:59 - 18 Jun 2014    Post subject: Reply with quote
Your starter wasn't working so they rewound the stater? Confused , would it not have been the starter motor, connection or switch?, mine has clicked twice in the 10k I put on it and both times it was sticking brushes, Am I missing something here?. I think yes they charged to much.
Mark
PostPosted: 12:31 - 18 Jun 2014    Post subject: Reply with quote
Mark
My dead stator stopped the bike turning as it kills the battery by not charging it.
It was the overall cause in my case.
Mark65
PostPosted: 08:36 - 19 Jun 2014    Post subject: Reply with quote
Ah ok, I didnt assume op had tried a new battery first. Very Happy
MattEMulsion
PostPosted: 09:51 - 19 Jun 2014    Post subject: Reply with quote
Does it all now work as it should? If so then you have got what you wanted and £133 is not that bad for the work that they have done. Anything done at a garage is retail pricing, that's how they stay in business.
Yamaha YZF-R6
The last post was made 12 years, 24 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 112.34 Kb
