| el_oso |
 el_oso World Chat Champion
 Posted: 15:01 - 28 Jun 2014 Post subject: slight rev hang |
so the thundercat has been running pretty rough for a little while now. Wouldn't idle unless the screw was set for 3k rpm. I've taken teh carbs apart and cleaned them through with carb cleaner and compressed air. I've reset the idle mixture screws etc. I've also synced the carbs. The engine now seems a lot smoother and idles pretty well.
Possible trouble is that revs hang a little. I'm not sure if it's just me being a little bit paranoid or what but I've uploaded a video. Hanging revs to me mean that it's running pretty lean possibly because of an air leak. I've checked the carb rubbers pretty thoroughly and they seem fine. I've also sprayed some carb cleaner around the area to see if the revs pick up and all seems fine. any ideas, or is this just somemthing that happens on carbed bikes/this bike?
https://youtu.be/xTCX-TEE24U ____________________ Duke 390
Car: Jeep Wrangler 4.0L |
| m3-paul |
 m3-paul Spanner Monkey
| c_dug |
 c_dug Super Spammer
 Posted: 15:42 - 28 Jun 2014 Post subject: |
Assuming this one I've chosen at random from Youtube is what it should be like, then yours is definitely on the slow side!
Is the twist grip snapping back closed properly? Maybe the cables need oiling something? ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| c_dug |
 c_dug Super Spammer
| el_oso |
| bypass2 |
 bypass2 Spanner Monkey
| el_oso |
The last post was made 11 years, 227 days ago. Instead of replying here, would creating a new thread be more useful? |
