slight rev hang
el_oso
PostPosted: 15:01 - 28 Jun 2014    Post subject: slight rev hang Reply with quote
so the thundercat has been running pretty rough for a little while now. Wouldn't idle unless the screw was set for 3k rpm. I've taken teh carbs apart and cleaned them through with carb cleaner and compressed air. I've reset the idle mixture screws etc. I've also synced the carbs. The engine now seems a lot smoother and idles pretty well.
Possible trouble is that revs hang a little. I'm not sure if it's just me being a little bit paranoid or what but I've uploaded a video. Hanging revs to me mean that it's running pretty lean possibly because of an air leak. I've checked the carb rubbers pretty thoroughly and they seem fine. I've also sprayed some carb cleaner around the area to see if the revs pick up and all seems fine. any ideas, or is this just somemthing that happens on carbed bikes/this bike?
https://youtu.be/xTCX-TEE24U
Duke 390
Car: Jeep Wrangler 4.0L
m3-paul
PostPosted: 15:23 - 28 Jun 2014    Post subject: Reply with quote
I would go with air leak as well initially. My fireblade is a carb'd 918 and the revs fall very quickly, almost instantly, to idle.
Until two days ago my tzr250 was holding its revs and it turned out to be an air leak due to an old gasket I had disturbed because I had dismantled them for ultrasonic cleaning.
I ended up replacing the suspect carb with one of my spares as it was less hassle and also ensured that both the inlet to carbs and carb to airbox connections were very secure.
Yamaha TZR250 - love the smell of TTS!!!!
CBR900RR Fireblade - so much fun
c_dug
PostPosted: 15:42 - 28 Jun 2014    Post subject: Reply with quote
Assuming this one I've chosen at random from Youtube is what it should be like, then yours is definitely on the slow side!
Is the twist grip snapping back closed properly? Maybe the cables need oiling something?
c_dug
PostPosted: 15:49 - 28 Jun 2014    Post subject: Reply with quote
Just thinking, you could eliminate the possibility of it being anything in the cables or twist grip by disconnecting the cables from the carb end and manually operating the throttle on the carbs.
If there is enough access that is.
el_oso
PostPosted: 17:08 - 28 Jun 2014    Post subject: Reply with quote
they are new cables so shouldn't need oiling. The cables don't move as free as what they should do. There's too much tension on the cable. Need to wait for it to stretch a little then re-adjust.
Duke 390
bypass2
PostPosted: 20:29 - 28 Jun 2014    Post subject: Reply with quote
Are the new cables re routed properly and seated
el_oso
PostPosted: 15:45 - 29 Jun 2014    Post subject: Reply with quote
yes, I've routed them exactly the same way the old ones came out. It's almost like they are slightly too short though. I've got the adjusters set to minimum and there is no slack in the cable like there should be. I'm hoping it will stretch quite quickly and solve my problem
Duke 390
The last post was made 11 years, 223 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 51.53 Kb
