Virago 535 Starter motor issues
Animal66
PostPosted: 12:21 - 04 Jul 2014    Post subject: Virago 535 Starter motor issues Reply with quote
Hi, new here so hope someone can help. My daughters 535 is not starting. I have had the starter off and tested it, it spins freely when starter pushed but does not engage the flywheel. Is this likely to be a battery, solenoid or starter motor issue? Its not making any strange noises, just spinning.
Thanks in advance.
Mark
M Ward
fatjames
PostPosted: 13:43 - 04 Jul 2014    Post subject: Reply with quote
Someone might be along to help you, but in the mean time, I've always found https://www.viragotechforum.com very helpful.
TUG
PostPosted: 14:00 - 04 Jul 2014    Post subject: Reply with quote
It's been a long long time since I worked on one of those and without a workshop manual I couldn't really help, I'll have a look and see if I can find one but in all honesty If the motor spins freely off the bike, does it spin freely when you have mounted it back up? or is there just no sound and no movement?
Haz ER-5, innit!
Animal66
PostPosted: 14:04 - 04 Jul 2014    Post subject: Reply with quote
Hi Tug, it is spinning when back on bike, just not engaging flywheel.
thanks.
M Ward
TUG
PostPosted: 14:08 - 04 Jul 2014    Post subject: Reply with quote
If you can find a workshop manual for your bike I highly recommend it before I suggest anything else. I can't remember how these engines are put together, If you can lend a starter motor of another 535 owner then I'd hazard a punt at that. I only say that because it sounds like your motor is getting a feed from the starter circuit but because itself is either faulty or the starter clutch assembly is faulty it is unable to engage.
Haz ER-5, innit!
Aff
PostPosted: 14:11 - 04 Jul 2014    Post subject: Reply with quote
Sprag Clutch deaded?
Electric Bike Project
fatjames
PostPosted: 14:38 - 04 Jul 2014    Post subject: Reply with quote
On the site I mentioned above, they have links to the haynes and hymer manuals for all years.
Animal66
PostPosted: 14:49 - 04 Jul 2014    Post subject: Reply with quote
Thanks all,will see if I can get a manual.
M Ward
TUG
PostPosted: 14:52 - 04 Jul 2014    Post subject: Reply with quote
Just spent a while getting my knowledge back up to speed. Your starter is at the front of the engine and then the teeth mesh with a starter clutch assembly. If the sprag clutch is fubar then it won't engage. You need to take the side casing off and have a good look around and provide us with many pictures. Laughing
Haz ER-5, innit!
Animal66
PostPosted: 15:02 - 04 Jul 2014    Post subject: Reply with quote
looks like I may have start dismantling bits of engine then, will have to wait a couple of weeks when i have some spare time, will keep you posted.
thanks again
M Ward
TUG
PostPosted: 15:10 - 04 Jul 2014    Post subject: Reply with quote
It won't be that hard to do, like you say, just time consuming and a bit of a pain in the arse, get to your local yamaha dealer and get the workshop manual they might be nice enough to print some pages off for you or burn you a copy. If you struggle, I'll get one for you. Thumbs Up
Haz ER-5, innit!
bikenut
PostPosted: 15:16 - 04 Jul 2014    Post subject: Reply with quote
also see cmsnl, find your bike and exploded views,,,,they may help.......
nuts about bikes
TUG
PostPosted: 15:33 - 04 Jul 2014    Post subject: Reply with quote
Like this. https://www.cmsnl.com/yamaha-xv535a-virago-1990_model9652/partslist/C-04.html#results
Haz ER-5, innit!
davebike
PostPosted: 16:09 - 04 Jul 2014    Post subject: Reply with quote
It will be the starter clutch failed or the bolt that hold it to the back of the alternator rotor
Seen a few do this
Hope it is the bolt the stater clutch is over £150 + vat
Dave
NC750Xdct + others at work !
[email protected]
Animal66
PostPosted: 16:41 - 04 Jul 2014    Post subject: Reply with quote
thanks Dave, i am beginning to suspect your right about the starter clutch, will see if I can get the side cover off tomorrow.
M Ward
Animal66
PostPosted: 18:47 - 30 Jul 2014    Post subject: Reply with quote
Hi all, bike back from garage, it was the sprag clutch,it had disintegrated, running nice again now.
M Ward
TUG
PostPosted: 19:51 - 30 Jul 2014    Post subject: Reply with quote
Epic, thanks for coming back and telling us, it will help others in the future. How bad disintegrated are we talking? Laughing
Haz ER-5, innit!
davebike
PostPosted: 07:08 - 31 Jul 2014    Post subject: Reply with quote
XV535 is well know for the starter clutch failing in the trade
An easy one to diagnose Wink
Dave
[email protected]
Animal66
PostPosted: 19:01 - 31 Jul 2014    Post subject: Reply with quote
apparently it was in bits in the bottom of the engine Sad
at least its fixed.
M Ward
The last post was made 12 years, 80 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 96.54 Kb
