| Mantzy |
 Mantzy Spanner Monkey
| Kickstart |
 Kickstart The Oracle
 Posted: 17:11 - 14 Jan 2005 Post subject: |
Sounds like a repair using new parts is not worthwhile.
If you sell it to a breaker they will give you peanuts for it. Probably £250~£500 as that seems to be the amount an insurance company want for letting you keep a bike and they are not going to sell it for less than a breakers would pay.
Down to repair it yourself or break it.
Breaking it is a fair amount of work. Suspect you would not get a massive amount for it.
Personally I would fix it up using 2nd hand parts from breakers and Ebay.
What is the full damage?
| Mantzy |
 Posted: 17:51 - 14 Jan 2005 Post subject: |
The full damage is 3 pages long and been priced at £3.5K (new parts)...know i need a new tyre, clutch cover, right side fairing (not going to happen), front wheel, rearset, clipon, switchgear, front brake lever, exhaust, mirror and apparently loads oif other bits. Sure it can't be as much as that.
R ____________________ Current Bikes: 2010 Triumph Sprint ST 1050
Previous Bikes: 2002 Sachs XTC, 1999 Kawasaki ZX6R, 2004 GSX-R 600 K4, 2006 Yamaha XT660X |
| Gazdaman |
 Gazdaman I did a trackday!!!
| Mantzy |
 Posted: 21:37 - 14 Jan 2005 Post subject: |
Exhaust = £490
Stay, FR Step, RH = £40.14
Step, FR, RH = £20.72
Bolt 6x10 = £1.40
Cover-Clutch = £68.27 Just bought
Gasket, Clutch cover = £6.90
Bolt, 6x30 = £2.16
Cowling, Side RH, Firecracker Red = £325.40
Cowling-assy, Upper, Firecracker Red = £320.03
Bracket, Mirror = £35.70
Mirror assembly, RH = £35.99
Holder-Handle, RH = £36.66
Handle RH = £30.59
Housing assy control = £51.44
Grip assy, Throttle = £14.81
Weight, Handle = £9.14
Lever-comp, Front brake = £27.23
Wheel assy, Front, Gray = £325.49
Pipe-comp-right fork = £156.87
Seal-oil, Fork outer = £5.78
Axle, Front = £26.70
Filter Assy, Oil = £7.67
Pad, Side Cowling, RH, Upper = £5.46
Pad, Side Cowling, RH, Central = £5.46
Pad, Side Cowling, RH, Lower = £14.46
Pad, Upper Cowling, RH = £3.51
Pad, Upper Cowling, LH = £3.51
Lever-Brake, Pedal = £38.29
Step, RR, RH = £29.60
Cover-Meter Case, Upper = £44.09
Tank-Resonator, RH, M.F. = £29.92
120/65-Z17 Dunlop D207 = £75.90
Duct, Inner = £12.62
Duct, Ram, RH, M.F.C.GRA = £71.37
Seal, Cover, RH = £2.04
Cover, Ram Duct, RH, M.F. = £21.36
Stay = £41.16
3.6 litres engine oil = £19.87
Fork oil = £5.02
Screws = £7.92
Washers, Nylon, 5.3x11.5 = £8.40
Nuts, 5mm = £22.96
+ VAT, labour, sundries, p&p, frame touch-up and delivery = £3487.80
- labour, sundries and frame touch-up = £3118.80
But that's for brand new stuff and i'm sure i don't need all of it
R[/list] ____________________ Current Bikes: 2010 Triumph Sprint ST 1050
| fuel |
 fuel Nitrous Nuisance
| Kickstart |
| Azmodeus |
 Azmodeus Scooby Slapper
| Ste |
 Ste Not Work Safe
| Mantzy |
| G |
 G The Voice of Reason
 Posted: 12:25 - 15 Jan 2005 Post subject: |
I'm not sure what all their designations mean, but this is what I reckon it's likely to cost if you shop around a bit on ebay etc.
Try asking on www.mcnninjas.co.uk ; if their board is still working anyway.
Go to your local hardware store for bolts, or get a big tub of them.
Fairings aren't needed; if your lights are ok, then it should hold the front fairing without the side panels.
Exhaust = £100 for an orignal full system on ebay, maybe less
Stay, FR Step, RH = £40.14 ?
Step, FR, RH = £20.72 ?
Bolt 6x10 = £1.40
Gasket, Clutch cover = £6.90 Real men reuse gaskets
Bolt, 6x30 = £2.16
Cowling, Side RH, Firecracker Red = From about £35 on ebay for a tatty but inshape one; or repair it?
Cowling-assy, Upper, Firecracker Red = From about £35 on ebay; or repair it?
Bracket, Mirror = £15-20
Mirror assembly, RH = £15-20 for both mirrors I think
Holder-Handle, RH = £5-10 if you can find one
Handle RH = £5-10 for both sides
Housing assy control = £15-25, if it can't be repaired
Grip assy, Throttle = £5-10
Weight, Handle = £10 for a pair new
Lever-comp, Front brake = £7-10
Wheel assy, Front, Gray = pair of wheel with all the bits from about £200-£300 on ebay at the mo, including tyres, if you're lucky. Less for single front (the rear always goes for more as well).
Pipe-comp-right fork = A pair of forks: about £125-200, less than half that if you can find a single one
Seal-oil, Fork outer = £5.78 not needed with new fork
Axle, Front = £26.70 Try and get with wheel
Weight, Handle = £9.14 get a pair, see above.
Filter Assy, Oil = £7.67 Get free with oil from busters
Pad, Side Cowling, RH, Upper = £5.46 It's a bike, what would you want padding for
Pad, Side Cowling, RH, Central = £5.46 It's a bike, what would you want padding for
Pad, Side Cowling, RH, Lower = £14.46 It's a bike, what would you want padding for
Pad, Upper Cowling, RH = £3.51 It's a bike, what would you want padding for
Pad, Upper Cowling, LH = £3.51 It's a bike, what would you want padding for
Lever-Brake, Pedal = £5-10
Step, RR, RH = £29.60 ?
Cover-Meter Case, Upper = Not sure what this is for; if it's important, probably £10-20
Tank-Resonator, RH, M.F. = £29.92 ?
Bracket, Mirror = £35.70 See above
120/65-Z17 Dunlop D207 = £75.90 Get a better tyre, and get it cheap on ebay
Duct, Inner = £2-5
Duct, Ram, RH, M.F.C.GRA = £5-10
Stay = £41.16
3.6 litres engine oil = £20 for 4l better oil with oil filter
Fork oil = £5.02 not needed now
Screws = £7.92
Nuts, 5mm = £22.96 |
The last post was made 21 years, 307 days ago. Instead of replying here, would creating a new thread be more useful? |
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 76.63 Kb
