| Wonko The Sane |
 Wonko The Sane World Chat Champion
 Posted: 22:38 - 09 Jul 2014 Post subject: Why don't after market huggers fit? |
I now have a skidmarx and a pyramid rear hugger for my fairly standard ZZR600
I spent sunday afternoon attempting to fit the skidmarx one but it wouldn't fit without rubbing the rear wheel quite badly.
I've spent this evening trying to fit the pyramid one, but again, this one rubs the rear wheel too.
how fucking hard is it to make a fucking piece of bloody plastic fit a bike that's been around for more than two bloody decades?
What do they do, have a look under a bike at a show and try to make the fucking thing from memory?
All I want is something to protect my shock from crap being flung at it, doesn't have to be fancy, doesn't have to be swish, just needs to fucking fit the bloody bike and do it's bloody job.
If you're wondering why not stick with the factory fitted one it got damaged by someone ramming me at a set of traffic lights. ____________________ Looking to pass your CBT / Bike tests in Bury Lancashire? try www.focusridertraining.co.uk Would recommend.
They're also on Facebook https://www.facebook.com/pages/Focus-Rider-Training/196832923734251 |
| Fisty |
 Fisty Super Spammer
| Wonko The Sane |
| Fisty |
 Fisty Super Spammer
| kawakid |
 kawakid World Chat Champion
| Itchy |
 Itchy Super Spammer
 Posted: 23:21 - 09 Jul 2014 Post subject: |
Potentially it might be that your bike isn't stock. Bikes can come with all sorts of hidden histories.
My CBR6 for instance, swing arm came off a F4i (meaning it was 20mm longer).
The forks came off a F4i (pre 2004) as well.
While the rear brake caliper turned out to be from a CBR600RR.
The shock was also off something else too as when I put the swing arm on it didn't quite fit and had an additional thing welded on. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| Shaft |
 Shaft World Chat Champion
 Posted: 23:33 - 09 Jul 2014 Post subject: |
Could be that something's a bit pissed from the accident, causing the hugger to mount skew whiff. ____________________ Things get better with age; I'm close to being magnificent........
| Llama-Farmer |
 Llama-Farmer World Chat Champion
| Wonko The Sane |
 Posted: 07:23 - 10 Jul 2014 Post subject: |
Unfortunately that's not the case, the chain has a few thousand miles on it, the tyre even more so.
If I were to file the mounting holes for the hugger and mount it slightly higher / slightly forwards there shouldn't be any issues provided it's tight?
If your tyre rubs when you've got a new one and new chain on, do you just go with it and let the tyre wear the hugger away for a bit? ____________________ Looking to pass your CBT / Bike tests in Bury Lancashire? try www.focusridertraining.co.uk Would recommend.
| Polarbear |
 Polarbear Super Spammer
| wr6133 |
 wr6133 World Chat Champion
| Wonko The Sane |
 Posted: 09:02 - 10 Jul 2014 Post subject: |
everything appears to be standard, the only modifications I know of are removal of the clean air system and fitting fireblade calipers to the front
the skidmarx is about 5mm out from fitting but rubs, have arranged to return it but might have another go at fitting ____________________ Looking to pass your CBT / Bike tests in Bury Lancashire? try www.focusridertraining.co.uk Would recommend.
| P.addy |
 P.addy Red Rocket
| Peirre oBollox |
 Peirre oBollox Could Be A Chat Bot
| Llama-Farmer |
 Posted: 09:25 - 10 Jul 2014 Post subject: |
| Daffyd wrote: | Unfortunately that's not the case, the chain has a few thousand miles on it, the tyre even more so.
If your tyre rubs when you've got a new one and new chain on, do you just go with it and let the tyre wear the hugger away for a bit? |
Yeah it wasn't offering any resistance to the wheel spinning so it wasn't putting tight pressure on, in fact it probably wasn't even touching the main tread, could have just been the rubber "hairs" brushing the hugger, but I just left it.
The Pyramid is fibreglass and fairly thick, so I figured if a couple of mm wore away thats still less than halfway through the whole hugger. And any wear this time is less/no rubbing next time.
I suppose it depends how much it's rubbing for you, but with a new chain and/or new tyre it will be significantly worse. I'd just extend the holes and fit it securely, with rubber washers to absorb vibes. ____________________ Current Bike: 1999 Honda CB600 FX Hornet
Next Bike: I want a CBR-RR. And I want an F800 GS-A. And a VFR 800. Can I have all 3?
Dream Bikes: Honda VFR750R RC30, Honda NSR500, Ducati 996 R |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 09:38 - 10 Jul 2014 Post subject: |
Never had an issue with after market huggers IME. ____________________ My Flickr |
| Hetzer |
 Hetzer Super Spammer
| DrSnoosnoo |
 DrSnoosnoo World Chat Champion
The last post was made 12 years, 88 days ago. Instead of replying here, would creating a new thread be more useful? |
