Why don't after market huggers fit?
Wonko The Sane
PostPosted: 22:38 - 09 Jul 2014    Post subject: Why don't after market huggers fit? Reply with quote
I now have a skidmarx and a pyramid rear hugger for my fairly standard ZZR600
I spent sunday afternoon attempting to fit the skidmarx one but it wouldn't fit without rubbing the rear wheel quite badly.
I've spent this evening trying to fit the pyramid one, but again, this one rubs the rear wheel too.
how fucking hard is it to make a fucking piece of bloody plastic fit a bike that's been around for more than two bloody decades?
What do they do, have a look under a bike at a show and try to make the fucking thing from memory?
All I want is something to protect my shock from crap being flung at it, doesn't have to be fancy, doesn't have to be swish, just needs to fucking fit the bloody bike and do it's bloody job.
If you're wondering why not stick with the factory fitted one it got damaged by someone ramming me at a set of traffic lights.
Fisty
PostPosted: 22:39 - 09 Jul 2014    Post subject: Reply with quote
Have you got the correct size tyre fitted? I had a Pyramid one on my ZZR and it fitted fine.
Fatter and faster than Fret
Wonko The Sane
PostPosted: 22:44 - 09 Jul 2014    Post subject: Reply with quote
The tyre on there is the one that was on when I bought it, I'm presuming it to be the correct size for the bike.
Just been and checked, 160, 60, 17
Fisty
PostPosted: 22:51 - 09 Jul 2014    Post subject: Reply with quote
Yup, thats the right size.
kawakid
PostPosted: 23:01 - 09 Jul 2014    Post subject: Reply with quote
Weird never had an issue and have aftermarketsbon both bikes.
I've a twin and a 4.
Itchy
PostPosted: 23:21 - 09 Jul 2014    Post subject: Reply with quote
Potentially it might be that your bike isn't stock. Bikes can come with all sorts of hidden histories. Laughing
My CBR6 for instance, swing arm came off a F4i (meaning it was 20mm longer).
The forks came off a F4i (pre 2004) as well.
While the rear brake caliper turned out to be from a CBR600RR.
The shock was also off something else too as when I put the swing arm on it didn't quite fit and had an additional thing welded on.
Shaft
PostPosted: 23:33 - 09 Jul 2014    Post subject: Reply with quote
Could be that something's a bit pissed from the accident, causing the hugger to mount skew whiff.
Llama-Farmer
PostPosted: 00:38 - 10 Jul 2014    Post subject: Reply with quote
I've got a Pyramid rear hugger on the Hornet and it won't quite fit if there is a new (unstretched) chain AND a new tyre.
Too much tread + the wheel too far forwards = rubbing.
After a few hundred miles, retensioned the chain and the slightest fraction of mm of worn tyre and there was just about enough room. Although when the hot tyre picked up small stones you could hear them scrape the hugger still.
A thousand or so miles later theres plenty of space now.
Might just be the way.
Current Bike: 1999 Honda CB600 FX Hornet
Next Bike: I want a CBR-RR. And I want an F800 GS-A. And a VFR 800. Can I have all 3?
Dream Bikes: Honda VFR750R RC30, Honda NSR500, Ducati 996 R
Wonko The Sane
PostPosted: 07:23 - 10 Jul 2014    Post subject: Reply with quote
Unfortunately that's not the case, the chain has a few thousand miles on it, the tyre even more so.
If I were to file the mounting holes for the hugger and mount it slightly higher / slightly forwards there shouldn't be any issues provided it's tight?
If your tyre rubs when you've got a new one and new chain on, do you just go with it and let the tyre wear the hugger away for a bit?
PostPosted: 08:40 - 10 Jul 2014    Post subject: Reply with quote
I have a powerbronze one on my Explorer, that fits fine and I can't say I've ever had any problems with other aftermarket stuff.
I would think Powerbronze, Skidmarx and Pyramid are pretty careful to do their research & get things right for each bike. If they started turning out ill fitting gear it would get round pretty quickly.
I'm with Itchy on this one, is something not standard on your bike?
wr6133
PostPosted: 08:45 - 10 Jul 2014    Post subject: Reply with quote
Sounds silly but..... are you sure it's for your ZZR? The models changed over the years and parts for say a D may not fit an E... etc
Wonko The Sane
PostPosted: 09:02 - 10 Jul 2014    Post subject: Reply with quote
everything appears to be standard, the only modifications I know of are removal of the clean air system and fitting fireblade calipers to the front
the skidmarx is about 5mm out from fitting but rubs, have arranged to return it but might have another go at fitting
PostPosted: 09:06 - 10 Jul 2014    Post subject: Reply with quote
I am going with this, something ever so minutely out of line to the eye can make a world of difference to other parts.
Peirre oBollox
PostPosted: 09:14 - 10 Jul 2014    Post subject: Reply with quote
That can be the case with the 1050 Sprint ST`s, as the rear wheel is adjusted by an eccentric hub, which can position the rear tyre too close to the hugger when either a new tyre or a chain is fitted
Llama-Farmer
PostPosted: 09:25 - 10 Jul 2014    Post subject: Reply with quote
Yeah it wasn't offering any resistance to the wheel spinning so it wasn't putting tight pressure on, in fact it probably wasn't even touching the main tread, could have just been the rubber "hairs" brushing the hugger, but I just left it.
The Pyramid is fibreglass and fairly thick, so I figured if a couple of mm wore away thats still less than halfway through the whole hugger. And any wear this time is less/no rubbing next time.
I suppose it depends how much it's rubbing for you, but with a new chain and/or new tyre it will be significantly worse. I'd just extend the holes and fit it securely, with rubber washers to absorb vibes.
PostPosted: 09:38 - 10 Jul 2014    Post subject: Reply with quote
Never had an issue with after market huggers IME.
Hetzer
PostPosted: 10:44 - 10 Jul 2014    Post subject: Reply with quote
I had murders with a Pyramid item for a 1998 Blade. T'was utter shite, I had to do all manner of surgery, tie-wrap and spacing-washers to get it to fit. And that was after numerous pics exchanged between me and Pyramid. After they'd sent a replacement because we figured the first was the wrong one. It was just extremely poorly made/dimensioned.
DrSnoosnoo
PostPosted: 11:19 - 10 Jul 2014    Post subject: Reply with quote
I wonder whether they expect the ZZR has the same swingarm as a ZX-R?
I have drilled out, widened and filed my current one to make fit. Total bodgery but now it at least stays on and keeps shit off my shock.
The last post was made 12 years, 88 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 101.18 Kb
