ZZR Rear brake, what to do to sort it?
Wonko The Sane
PostPosted: 16:43 - 13 Jul 2014    Post subject: ZZR Rear brake, what to do to sort it? Reply with quote
I've tried to change my rear brake pads since I've done a jive bunny and let it get almost onto the backing material, this is due to assuming the wear on each rear pad would be similar, if the calliper was floating correctly then it would be!
So, the calliper on the bike, the retaining pin is seized in place and won't move.
The calliper on the bike also doesn't float as it should
Other than that, it doesn't leak fluid and the piston does move.
The spare calliper (spare complete intact set-up) in my box of spares is un-proven, it has no fluid in it and I don't know what condition it is in. The retaining pin in this is also seized in place. The body of the calliper is also showing signs of corrosion.
So, I need brake pads on to be using the bike to get to work so it's booked in at a garage tomorrow to get the pads changed, but in the long term something needs sorting more long-term.
Do I buy some retaining pins, cut the one in the spare calliper, get it working and fit the spare to the bike and use that while I re-build the bike's calliper?
Or, do I give the spare calliper a good overhaul and fit that permanently to the bike?
el_oso
PostPosted: 17:31 - 13 Jul 2014    Post subject: Reply with quote
this depends greatly on the caliper, so use your brain to figure out if you can do this before attempting it.
On the SV the pad retaining pins were seized in place. I drilled a small hole, smaller than the diameter of the pin from the other side through the calliper material. I was then able to punch the pin through using a punch. Issue resolved, no more stuck pins.
Duke 390
Car: Jeep Wrangler 4.0L
PostPosted: 17:56 - 13 Jul 2014    Post subject: Reply with quote
Those calipers seem to be prone to having the pistons seize, so if neither are siezed like that then you are doing well!
The pin that holds the pads in should just be located with an R clip. Get that out then try and hold onto the pin with a set of mole grips (not just pliers) between the pads and try and twist the pin (bit of penetrating oil on the holes the pin goes through will help). With luck it should just come lose.
Wonko The Sane
PostPosted: 18:09 - 13 Jul 2014    Post subject: Reply with quote
Done the above with no joy, I was using a pair of pliers as I couldn't get mole grips narrow enough to find my way in.
Think I'm going to get a re-build kit and take apart and re-build the spare calliper and fit that to the bike then re-build the one on the bike as a spare.
This way, when it happens next time, I have a spare calliper to just throw on, bleed and ride!
Wonko The Sane
Not possible, I'd have to drill through just below the bleed nipple so think I'd be causing more issues.
PostPosted: 18:11 - 13 Jul 2014    Post subject: Reply with quote
Really needs to be mole grips for a chance of this to work. With pliers you will really struggle to grip the pin anything like tight enough while twisting it.
DrSnoosnoo
PostPosted: 21:49 - 13 Jul 2014    Post subject: Reply with quote
When I needed to change my rear pad I to had a totally stuck pin. I tried pulling with pliers loads which ended up making it quite square. I hammered on a torx socket and ratcheted it loose then it came out.
I went super ghey though and but a gold ZX6R rear caliper and rreplaced my rear after the seal blew out, now it almost matches my gold CBR6RR fronts.
gavbriggs
PostPosted: 22:41 - 13 Jul 2014    Post subject: Reply with quote
I had the pins on the bandit stuck. Set of narrow nose mole grips on the pin very tight and hit the grips with a hammer in the direction the pins come out. Slowly they came out, polished em up to remove any damage and put em back with new pads
Recent bikes: Varadero 125 - Mod 2 3/2/14 - Bandit 1200 SK4
Wonko The Sane
PostPosted: 22:52 - 13 Jul 2014    Post subject: Reply with quote
I found your old thread where you'd described doing that but its not worked for me this time Sad
Looked at new calliper but £100+ is more than I'd like to spend at the moment.
DrSnoosnoo
PostPosted: 23:20 - 13 Jul 2014    Post subject: Reply with quote
I got the new rear caliper for about 35 quid if I remember right. It came from America but it was very fast and just a bolt on replacement.
Have you tried any penetrating sprays on the pin?
DrSnoosnoo
PostPosted: 23:23 - 13 Jul 2014    Post subject: Reply with quote
https://pages.ebay.com/link/?nav=item.view&id=221492195575&alt=web
25 quid isn't to be sniffed at
_mjs_
PostPosted: 05:37 - 14 Jul 2014    Post subject: Reply with quote
Definately a common problem. Ended up having to replace the entire caliper due to the pad pin getting seized in it's hole.
Wonko The Sane
PostPosted: 13:47 - 14 Jul 2014    Post subject: Reply with quote
As I needed to have it sorted yesterday I've had the garage near work sort it.
For £45 he stripped the caliper and got it floating and working as it should and fitted the new pads.
There be a fair amount of copper slip on the moving parts now.
PostPosted: 18:32 - 14 Jul 2014    Post subject: Reply with quote
^^^There's no shame in paying to fix something that does your noggin in. Thumbs Up
Well maybe a little bit of shame. Smile
Wonko The Sane
PostPosted: 11:43 - 15 Jul 2014    Post subject: Reply with quote
It was more a case of paying to be able to commute on motorways without getting deaded.
I changed the oil cooler, oil filter and oil myself
Also swapped the rear shock last weekend so not doing too badly.
Hetzer
PostPosted: 11:46 - 15 Jul 2014    Post subject: Reply with quote
Whack it about with a hammer, it often does the trick.
Amber Phoenix
PostPosted: 12:18 - 15 Jul 2014    Post subject: Reply with quote
Probably a bit late now, but I've got a set of brand new rear pads (SOK FA192's) and a new VenHill green rear brake line for a ZZR600, going spare in my bits box. At all interested?
Beginner Biker Adventures Blog
Yamaha FZ6 S2 2007
Llama-Farmer
PostPosted: 13:14 - 15 Jul 2014    Post subject: Reply with quote
Possibly worth taking out the pads and retaining pin and reapplying some copper grease every couple of months. Only a 5 minute job but stops it seizing like a bastard for next time.
Can use the time to press out the piston (without actually removing it from the caliper) so most of it is exposed, and then cleaning off the brake dust and crap with some brake cleaner. That should stop the piston seizing and will mean the seals last longer too.
At most you're looking at a half hour job once every 2-3 months.
Current Bike: 1999 Honda CB600 FX Hornet
Next Bike: I want a CBR-RR. And I want an F800 GS-A. And a VFR 800. Can I have all 3?
Dream Bikes: Honda VFR750R RC30, Honda NSR500, Ducati 996 R
Wonko The Sane
PostPosted: 22:33 - 19 Jul 2014    Post subject: Reply with quote
Yup, been thinking that might be a good plan.
Plenty of 'meat' left on my front pads but thinking it might be worth doing similar with the front brakes at some point in the near future - they're fire blade callipers tho, a common upgrade on the ZZR
Llama-Farmer
PostPosted: 01:10 - 20 Jul 2014    Post subject: Reply with quote
I would say that's a good idea on the front too yeah. Providing you don't get any grease on the friction surfaces and everything back the way its supposed to be then it's gonna do much more good than harm.
Just wipe the pad surfaces with brake cleaner before putting back together, and then a bit more brake cleaner on a rag and wipe down the discs too, just to remove any traces of anything that gets onto them
TUG
PostPosted: 04:07 - 20 Jul 2014    Post subject: Reply with quote
Stuck pins require either splitting the caliper body and twising with loads of WD-40 or better, or loads of WD or better combined with hitting it in and out from both sides until free, or heat then WD treatment. Glad you got it sorted though! Nothing beats an overhauled caliper!
Haz ER-5, innit!
Llama-Farmer
PostPosted: 14:31 - 20 Jul 2014    Post subject: Reply with quote
WD-40, the most incorrectly used product in the world ever.
It's a water displacement spray, not a penetrating oil or a lubricant. Whilst it may do the job to some degree, there are much much better things out there.
If you want a penetrating spray, use English Abrasives Plus Gas, works sooooo much better.
TUG
PostPosted: 17:21 - 20 Jul 2014    Post subject: Reply with quote
TUG wrote:
...loads of WD-40 or better, or loads of WD or better combined with hitting it in and out from both sides until free...
Most often than not, you will have a can of WD to hand and it works well enough to sort you out, I did state OR BETTER twice. Laughing
Haz ER-5, innit!
Llama-Farmer
PostPosted: 00:15 - 21 Jul 2014    Post subject: Reply with quote
Ha I'd very much disagree with that. It works well enough maybe 50% of the time. The other 50% requires action such as drilling stripped bolts out, replacing sheared and rounded parts, angle grinders or pipe wrenches.
TUG
PostPosted: 19:36 - 22 Jul 2014    Post subject: Reply with quote
Oh I didn't realise you use WD-40 on rounded off and snapped bolts etc, my mistake. Rolling Eyes
Haz ER-5, innit!
The last post was made 11 years, 266 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.25 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 138.92 Kb
