| Wonko The Sane |
 Wonko The Sane World Chat Champion
 Posted: 15:43 - 13 Jul 2014 Post subject: ZZR Rear brake, what to do to sort it? |
I've tried to change my rear brake pads since I've done a jive bunny and let it get almost onto the backing material, this is due to assuming the wear on each rear pad would be similar, if the calliper was floating correctly then it would be!
So, the calliper on the bike, the retaining pin is seized in place and won't move.
The calliper on the bike also doesn't float as it should
Other than that, it doesn't leak fluid and the piston does move.
The spare calliper (spare complete intact set-up) in my box of spares is un-proven, it has no fluid in it and I don't know what condition it is in. The retaining pin in this is also seized in place. The body of the calliper is also showing signs of corrosion.
So, I need brake pads on to be using the bike to get to work so it's booked in at a garage tomorrow to get the pads changed, but in the long term something needs sorting more long-term.
Do I buy some retaining pins, cut the one in the spare calliper, get it working and fit the spare to the bike and use that while I re-build the bike's calliper?
Or, do I give the spare calliper a good overhaul and fit that permanently to the bike? ____________________ Looking to pass your CBT / Bike tests in Bury Lancashire? try www.focusridertraining.co.uk Would recommend.
They're also on Facebook https://www.facebook.com/pages/Focus-Rider-Training/196832923734251 |
| el_oso |
 el_oso World Chat Champion
| Kickstart |
 Kickstart The Oracle
 Posted: 16:56 - 13 Jul 2014 Post subject: |
Those calipers seem to be prone to having the pistons seize, so if neither are siezed like that then you are doing well!
The pin that holds the pads in should just be located with an R clip. Get that out then try and hold onto the pin with a set of mole grips (not just pliers) between the pads and try and twist the pin (bit of penetrating oil on the holes the pin goes through will help). With luck it should just come lose.
| Wonko The Sane |
| Wonko The Sane |
| Kickstart |
| DrSnoosnoo |
 DrSnoosnoo World Chat Champion
| gavbriggs |
 gavbriggs Crazy Courier
| Wonko The Sane |
| DrSnoosnoo |
| DrSnoosnoo |
| _mjs_ |
 _mjs_ Could Be A Chat Bot
| Wonko The Sane |
 Posted: 12:47 - 14 Jul 2014 Post subject: |
As I needed to have it sorted yesterday I've had the garage near work sort it.
For £45 he stripped the caliper and got it floating and working as it should and fitted the new pads.
There be a fair amount of copper slip on the moving parts now. ____________________ Looking to pass your CBT / Bike tests in Bury Lancashire? try www.focusridertraining.co.uk Would recommend.
| Howling TerrorOutOfOffice |
 Howling TerrorOutOfOffice Super Spammer
| Wonko The Sane |
| Hetzer |
 Hetzer Super Spammer
| Amber Phoenix |
 Amber Phoenix Traffic Copper
 Posted: 11:18 - 15 Jul 2014 Post subject: |
Probably a bit late now, but I've got a set of brand new rear pads (SOK FA192's) and a new VenHill green rear brake line for a ZZR600, going spare in my bits box. At all interested? ____________________ Beginner Biker Adventures Blog
Yamaha FZ6 S2 2007 |
| Llama-Farmer |
 Llama-Farmer World Chat Champion
| Wonko The Sane |
| Llama-Farmer |
| TUG |
 TUG World Chat Champion
| Llama-Farmer |
| TUG |
| Llama-Farmer |
| TUG |
The last post was made 11 years, 195 days ago. Instead of replying here, would creating a new thread be more useful? |
