Race dash project
Korn
Admin
PostPosted: 23:44 - 16 Jan 2005    Post subject: Race dash project Reply with quote
Part of getting my R6 ready for the track this year meant needing to replace the instrument dash - which had started to rot - with something new. I decided that along with the rev counter and temperature guage my new version was going to incorporate an onboard lap timer... here's how it came to be: (click pictures for large versions)
https://www.kornel.com/pics/Dash/t_P1010006.jpg https://www.kornel.com/pics/Dash/t_P1010007.jpg
First step involved getting hold of the foam I needed for the backing, I needed something both fairly strong and also waterproof. After some searching I found something called a "cycle carrier spacer" in Halfords that was weather resistant and thick enough to handle the task. I marked it up to the dimensions I wanted and drew on the instruments and fixing screws.
https://www.kornel.com/pics/Dash/t_P1010012.jpg https://www.kornel.com/pics/Dash/t_P1010013.jpg
To cut the oval shape I used an upside down jigsaw mounted in a vice. With the saw running and the trigger locked I could move the foam about using the metal plate of the saw as a cutting table. The edges came out almost perfect, certainly a lot better than my first attempt with a stanley knife. The rev counter and temp guage holes were just drilled out with hole saws, and the mounting holes punched through.
https://www.kornel.com/pics/Dash/t_P1010018.jpg https://www.kornel.com/pics/Dash/t_P1010021.jpg
The lap timer I found wasn't intended to be mounted as an instrument, so I had to open up the case and add two mounting pillars - small bolts with the heads ground down fixed to the back of the case. I then cut out a rectangle of clear plastic to cover the back of the hole in the foam backing and glued it in place.
https://www.kornel.com/pics/Dash/t_P1010030.jpg https://www.kornel.com/pics/Dash/t_P1010053.jpg
Next I drilled the appropriate holes to fix the timer to the backing plate and attached a thumb switch to the left handle bar to serve as the manual trigger. I added a quick release connector into the wiring to enable the manual switch to be replaced by an i/r receiver - for use with a trackside lap beacon.
And here it is all finished up:
https://www.kornel.com/pics/Dash/t_P1010045.jpg
3516 Miles, 11 Countries
Silver
PostPosted: 23:54 - 16 Jan 2005    Post subject: Reply with quote
I can't see the Cheddars in the finished version...
Visitor Q
$25 whore
PostPosted: 00:02 - 17 Jan 2005    Post subject: Reply with quote
i would love that, but not for timing laps, but more timing roads, and checking my belief that im faster going up a road say, then down on certain stretches and things like that.
PostPosted: 00:03 - 17 Jan 2005    Post subject: Reply with quote
Looking good.
Jrod
Page 3 Girl
PostPosted: 02:19 - 17 Jan 2005    Post subject: Reply with quote
The RS125 has a lap timer as standard I belive?
PostPosted: 09:12 - 17 Jan 2005    Post subject: Reply with quote
The dash used on the rs series and other has a lap timer.
However it's a finger operated one, while I would presume korn's can take an input from a beacon reciever. Wouldn't be much use for what br wants however. Is a lot less hassle to get accurate laps when you're trying to slip stream a ducati Smile.
Klause
PostPosted: 09:32 - 17 Jan 2005    Post subject: Reply with quote
Smart idea and looking good Thumbs Up . Have to remember that if I ever need to replace my dash board.
Ric
PostPosted: 12:53 - 17 Jan 2005    Post subject: Reply with quote
yer but i found u needed a super bendy thumb to press it and cat like reflexs to make it work
i wouldnt mind doin summin like that to moderise my dash but i doubt theres enough room
Jrod
Page 3 Girl
PostPosted: 12:54 - 17 Jan 2005    Post subject: Reply with quote
Even if its not super accurate its better than what I'd have to do. Count. Razz
Ric
PostPosted: 12:58 - 17 Jan 2005    Post subject: Reply with quote
1, 2, 3, 4, ooooh a gixxer
DAMN
PostPosted: 13:00 - 17 Jan 2005    Post subject: Reply with quote
Korn,
Tart.
Smile
Dom
PostPosted: 13:20 - 17 Jan 2005    Post subject: Reply with quote
Yep it does. Has a little thumb button on the left switchgear to mark when you cross the line. So damn cool, I just wish it had an engine to match. Laughing Crying or Very sad
Edit: Mental note... read all the posts before replying.
Jrod
Page 3 Girl
PostPosted: 13:21 - 17 Jan 2005    Post subject: Reply with quote
What, a cool engine? But then you can't rag it ? Mr. Green
PostPosted: 13:23 - 17 Jan 2005    Post subject: Reply with quote
Erm, you use your forefinger on my rs250 Confused ... might explain why you were having problems using your thumb Smile.
Dom
PostPosted: 13:27 - 17 Jan 2005    Post subject: Reply with quote
Oooooohh, bad joke. Razz
On the 125 it's a teeny button just to the left and under the indicator buttons if I remember right. Thinking Must admit I've not used it once since I bought the bike though so I could be wrong.
Ric
PostPosted: 13:34 - 17 Jan 2005    Post subject: Reply with quote
using it also alarms people while goin for ur lap record up the high st etc, u slip ur thumb down to press the lap timer and u get it wrong end up on the horn and get all disorientated
Jon
Anyone for donuts?
PostPosted: 13:38 - 17 Jan 2005    Post subject: Reply with quote
Korn, there may be a problem with your lap timer... it doesn't show enough digits on the screen for your lap times
Sparks!
Sir Tart-a-lot
PostPosted: 13:39 - 17 Jan 2005    Post subject: Reply with quote
Try pressing the button.. it's probably the horn Laughing Laughing Or did you think that beep everytime you pressed it started the stop watch??? Very Happy Mr. Green
Dom
PostPosted: 13:41 - 17 Jan 2005    Post subject: Reply with quote
Laughing Lol... git. Razz Mr. Green
It is in that general area. Will check in a bit.
Gazdaman
I did a trackday!!!
PostPosted: 14:38 - 17 Jan 2005    Post subject: Reply with quote
Looks excellent, I did something similar, except I superglued an old watch over my non-working tacho.
Be nice to see pics when the fairings are back on.
Gaz
Dan 4RR
PostPosted: 15:09 - 17 Jan 2005    Post subject: Reply with quote
I like it. Thumbs Up
How long did it take you ?
swaffs
PostPosted: 15:54 - 17 Jan 2005    Post subject: Reply with quote
Nice work Korn. now all you have to do is get the the thing on the track.
perhaps you might be able to switch it as a rear view camera monitor as well !!
S
Swaffs Photography |
BCF vinyl stickers
"Look not back in anger, nor forward in fear, but around you in awareness."
Azmodeus
PostPosted: 16:07 - 17 Jan 2005    Post subject: Reply with quote
Does the Fire Extinguisher you glued to the back of the foam help with cornering?
Korn
Admin
PostPosted: 16:19 - 17 Jan 2005    Post subject: Reply with quote
Most of Sunday evening, on and off with other stuff that needed doing.
Also, since the bike is on a daylight MOT if I ever want to ride it on the road the handlebar switch can be used to operate a horn (required for the MOT) and I'm going to make up a little insert so I can swap the lap timer out for a digital speedo.
TiN
Pocket Tin
PostPosted: 22:34 - 17 Jan 2005    Post subject: Reply with quote
That's kool Korn Smile ...but the foamy bit looks a little lardy to me. What bore is that Brembo? The connecting the M/C to the reservoir looks mighty heavy duty...
TiN
dotgems.net
The last post was made 21 years, 304 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 131.12 Kb
