| Korn |
 Korn Admin
 Posted: 00:44 - 17 Jan 2005 Post subject: Race dash project |
Part of getting my R6 ready for the track this year meant needing to replace the instrument dash - which had started to rot - with something new. I decided that along with the rev counter and temperature guage my new version was going to incorporate an onboard lap timer... here's how it came to be: (click pictures for large versions)
https://www.kornel.com/pics/Dash/t_P1010006.jpg https://www.kornel.com/pics/Dash/t_P1010007.jpg
First step involved getting hold of the foam I needed for the backing, I needed something both fairly strong and also waterproof. After some searching I found something called a "cycle carrier spacer" in Halfords that was weather resistant and thick enough to handle the task. I marked it up to the dimensions I wanted and drew on the instruments and fixing screws.
https://www.kornel.com/pics/Dash/t_P1010012.jpg https://www.kornel.com/pics/Dash/t_P1010013.jpg
To cut the oval shape I used an upside down jigsaw mounted in a vice. With the saw running and the trigger locked I could move the foam about using the metal plate of the saw as a cutting table. The edges came out almost perfect, certainly a lot better than my first attempt with a stanley knife. The rev counter and temp guage holes were just drilled out with hole saws, and the mounting holes punched through.
https://www.kornel.com/pics/Dash/t_P1010018.jpg https://www.kornel.com/pics/Dash/t_P1010021.jpg
The lap timer I found wasn't intended to be mounted as an instrument, so I had to open up the case and add two mounting pillars - small bolts with the heads ground down fixed to the back of the case. I then cut out a rectangle of clear plastic to cover the back of the hole in the foam backing and glued it in place.
https://www.kornel.com/pics/Dash/t_P1010030.jpg https://www.kornel.com/pics/Dash/t_P1010053.jpg
Next I drilled the appropriate holes to fix the timer to the backing plate and attached a thumb switch to the left handle bar to serve as the manual trigger. I added a quick release connector into the wiring to enable the manual switch to be replaced by an i/r receiver - for use with a trackside lap beacon.
And here it is all finished up:
https://www.kornel.com/pics/Dash/t_P1010045.jpg ____________________ 3516 Miles, 11 Countries |
| Silver |
 Silver World Chat Champion
| Visitor Q |
 Visitor Q $25 whore
 Posted: 01:02 - 17 Jan 2005 Post subject: |
i would love that, but not for timing laps, but more timing roads, and checking my belief that im faster going up a road say, then down on certain stretches and things like that. ____________________ China traffic/travel bike vid - When I make a sweeping statement, please add the word 'statistically' in to the sentence before you bitch...
From September 2014 to January/February 2015 I will not be using any English, nor reading any. As such, I won't be on here. PM at will, but I won't be checking/posting unless in emergencies. Certainly not for the first couple of months. Please berate me savagely if I break that rule... |
| Kickstart |
 Kickstart The Oracle
 Posted: 01:03 - 17 Jan 2005 Post subject: |
| Jrod |
 Jrod Page 3 Girl
| G |
 G The Voice of Reason
 Posted: 10:12 - 17 Jan 2005 Post subject: |
The dash used on the rs series and other has a lap timer.
However it's a finger operated one, while I would presume korn's can take an input from a beacon reciever. Wouldn't be much use for what br wants however. Is a lot less hassle to get accurate laps when you're trying to slip stream a ducati . |
| Klause |
 Klause World Chat Champion
 Posted: 10:32 - 17 Jan 2005 Post subject: |
Smart idea and looking good . Have to remember that if I ever need to replace my dash board. |
| Ric |
 Ric Could Be A Chat Bot
| Jrod |
 Jrod Page 3 Girl
 Posted: 13:54 - 17 Jan 2005 Post subject: |
Even if its not super accurate its better than what I'd have to do. Count.  |
| Ric |
| MarJay |
 MarJay But it's British!
 Posted: 14:00 - 17 Jan 2005 Post subject: |
Korn,
Tart.
 ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| Dom |
 Dom World Chat Champion
| Jrod |
 Jrod Page 3 Girl
 Posted: 14:21 - 17 Jan 2005 Post subject: |
What, a cool engine? But then you can't rag it ?  |
| G |
| Dom |
 Posted: 14:27 - 17 Jan 2005 Post subject: |
| Ric |
| Jon |
 Jon Anyone for donuts?
| Sparks! |
 Sparks! Sir Tart-a-lot
 Posted: 14:39 - 17 Jan 2005 Post subject: |
| Dom |
 Posted: 14:41 - 17 Jan 2005 Post subject: |
Lol... git.
It is in that general area. Will check in a bit. |
| Gazdaman |
 Gazdaman I did a trackday!!!
| Dan 4RR |
 Dan 4RR World Chat Champion
 Posted: 16:09 - 17 Jan 2005 Post subject: |
I like it.
How long did it take you ? |
| swaffs |
 swaffs World Chat Champion
 Posted: 16:54 - 17 Jan 2005 Post subject: |
Nice work Korn. now all you have to do is get the the thing on the track.
perhaps you might be able to switch it as a rear view camera monitor as well !!
S ____________________ Swaffs Photography |
BCF vinyl stickers
"Look not back in anger, nor forward in fear, but around you in awareness." |
| Azmodeus |
 Azmodeus Scooby Slapper
| Korn |
 Korn Admin
| TiN |
 TiN Pocket Tin
 Posted: 23:34 - 17 Jan 2005 Post subject: |
That's kool Korn ...but the foamy bit looks a little lardy to me. What bore is that Brembo? The connecting the M/C to the reservoir looks mighty heavy duty... ____________________ TiN
dotgems.net |
The last post was made 21 years, 239 days ago. Instead of replying here, would creating a new thread be more useful? |
