Anrdoid GPS tracker apps
Robby
Dirty Old Man
PostPosted: 12:13 - 10 Aug 2014    Post subject: Anrdoid GPS tracker apps Reply with quote
I'm currently using an old Android phone as a GPS tracker on the bike. The problem is that it isn't very reliable, stops updating its position for no good reason. It's an old phone and a cheap bike, so there's no point getting a proper tracker.
My current setup uses the Spysat app, and uploads the position every two minutes to www.spysat.eu
As far as I can tell, the main problem is that the thing is using GPS to get a fix the whole time. The phone lives in the tail unit next to a tower block most of the time, so it doesn't get a very good look at the sky. There is no option in this app to get a vague location off cell towers.
Is anyone else doing a similar thing, and have you found a better app? I want to be able to go to a web page and see where my bike is, to the best accuracy possible.
Snop Doog
PostPosted: 16:14 - 10 Aug 2014    Post subject: Re: Anrdoid GPS tracker apps Reply with quote
I used to use 'My Tracks' on my SGS3, it's by Google. When I used it, I had no problems. I stopped because I didn't need it. But yeah, it tracks your path, speed distance and elevation. Also, it's free Very Happy
Edit: You can upload, and then view your tracks on Google Drive.
Edit 2: You can set the accuracy you want. E.g, 1 metre, 3, metres, 7 metres and so on. It wasn't those exact numbers but you get where it's going.
PostPosted: 17:11 - 10 Aug 2014    Post subject: Re: Anrdoid GPS tracker apps Reply with quote
Robby wrote:
I want to be able to go to a web page and see where my bike is, to the best accuracy possible so that I can do unspeakable and unimaginable things to whoever has taken it.
EFA. Wink
Gobsheen
PostPosted: 20:32 - 12 Aug 2014    Post subject: Reply with quote
This should do the job. Pretty cheap and only searches for a location when you tell it to.
https://www.ebay.co.uk/itm/290702741408?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
MZ Mastiff
Furrybiker
PostPosted: 17:34 - 13 Aug 2014    Post subject: Reply with quote
Could you use Google Location history, it does need gps to be really accurate but is free apart from using some data?
The last post was made 12 years, 4 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 45.59 Kb
