Fazer downpipes
reddeviljp
PostPosted: 21:10 - 17 Aug 2014    Post subject: Fazer downpipes Reply with quote
I've got some small pin holes developed in one of the pipes and it's making a bit of grunt (sounds better, actually!). The only problem is that I can't afford to shell out for new pipes just yet. What damage is caused if you don't replace them for a while? Is it just loss of power?
I've never had the pipes go on me before so I'm genuinely ignorant on this issue. Cheers in advance, people.
Bike: 1993 CB400 SuperFour - 1999 Yamaha FZS600 - DAS passed 7/11/13 - Working my way towards a Yamaha FZ1.
Ben90
PostPosted: 21:37 - 17 Aug 2014    Post subject: Reply with quote
https://www.watsdyke.org.uk/wp-content/uploads/2012/02/tin-can.jpg + https://www.thetoolboxshop.com/user/products/fx020303-250g-tub-exhaust-repair-putty-2729-p.jpg + https://www.parkerhydraulics.co.uk/wp-content/uploads/2013/09/Hose-Clips.jpg
Yamaha FZ6 S2
reddeviljp
PostPosted: 09:59 - 18 Aug 2014    Post subject: Reply with quote
Ben90 wrote:
Cheers, Rob.
Ben90 - explain the end clip bit, please Embarassed
DrDonnyBrago
PostPosted: 10:38 - 18 Aug 2014    Post subject: Reply with quote
Apply putty to downpipe, wrap in the bean can then secure with the jubilee clip.
That said, buy new downpipes.
You will need to eventually anyway, may as well get on with it.
c_dug
PostPosted: 13:57 - 18 Aug 2014    Post subject: Reply with quote
My divvy pipes have been gradually getting worse more or less since I bought them. No damage caused yet. I don't think I've ever owned a bike that hasn't had leaky headers Embarassed Laughing
That said, maybe this will help you: https://www.bikechatforums.com/viewtopic.php?t=237320&highlight=exhaust
andys675
PostPosted: 18:59 - 18 Aug 2014    Post subject: Reply with quote
if you can get the money together buy the motad ones, I got mine from them on ebay for £140
the delkevic ones are ok, but lots of folks have to get hteir carbs balanced afterwards
the header studs are a bitch, 6mm with long nuts, if you can't a blowlamp or welding torch to heat them up first one of those pen size butane soldering tools off ebay work well
be careful with the radiator, there's an elbow on the lower rhs, I managed to rip it out of the paper thin rad when removing it, delkevic do pattern rads, another £90 Embarassed
reddeviljp
PostPosted: 19:48 - 18 Aug 2014    Post subject: Reply with quote
Excellent! Cheers c_dug Thumbs Up
Itchy
PostPosted: 20:02 - 18 Aug 2014    Post subject: Reply with quote
If you decide to replace the pipes, don't remove the studs!
Dremel off the nuts instead, much simpler.
A100man
PostPosted: 12:19 - 19 Aug 2014    Post subject: Reply with quote
Take a look at the 'for sale' forum - just seem some posted under the title various bits (or something like)..
Amber Phoenix
PostPosted: 13:18 - 19 Aug 2014    Post subject: Reply with quote
Or you might get lucky and after a week of dousing the header nuts with penetrative spray and very carefully loosening them, they may all pop off without a hitch. Mine certainly did.
Will depend how old yours is, how crudded up they are and general luck of the draw. A number of folk on the Fazer forum have snapped header bolts and had to pull the engine out to remove the remains or re-drill them down at an engineering workshop. Mine came off without issue.
Anyhow, here's a little write up on when I swapped some Motad downpipes onto my 2003 Fazer.
Beginner Biker Adventures Blog
Yamaha FZ6 S2 2007
reddeviljp
PostPosted: 22:05 - 19 Aug 2014    Post subject: Reply with quote
Cheers, Arfa. I knew I'd seen an article somewhere. Thanks a lot.
A100man - thank you. I've sent him a message.
motad_uk
PostPosted: 09:44 - 04 Sep 2014    Post subject: Reply with quote
as I am sure most of you know- anyone selling pipes or systems with the requirement to dyno test, change jets or balance carbs before use is selling stuff that has not been developed and designed properly (or at all!)
sales@motad.co.uk www.motad.co.uk
see us on Facebook at Motad Ltd
The last post was made 11 years, 156 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.94 - MySQL Queries: 13 - Page Size: 82.53 Kb
