Question about 'running in' my new cbf125
ezsauce
PostPosted: 16:16 - 28 Aug 2014    Post subject: Question about 'running in' my new cbf125 Reply with quote
Hi there,
New to this forum, and riding itself.
Did my CBT about 10 days ago, which was horrendous and I have no idea how I passed... Never had any road or bike experience previous and signed up to the 125cc course, when I arrived, 7 other people were doing the course and ALL of them on 50cc pull and goes, was very daunting for me but I got through it.
Anyway, got myself a brand new CBF125 which I am loving it at the moment!!
Literally have no idea about anything mechanical, I so have lots of questions to ask and reading to do... however my first question is how I should 'run in' the engine, I had no idea engines need running in until someone mentioned it at work.
I have done around 180 miles on the bike and so far have not been faster than 55mph, is this a good idea or should I be testing it on an A road at full speed while the engine is new?
Thanks in advance for any replies.
Andy_Pagin
PostPosted: 16:19 - 28 Aug 2014    Post subject: Reply with quote
The owner manual should tell you how to run it in, the general rule is take it easy and avoid thrashing it for something like 600 miles.
stevo as b4
PostPosted: 17:03 - 28 Aug 2014    Post subject: Reply with quote
55mph on the flat is probably 80% throttle on a CBF anyway. Personally I would change the oil and filter now, and again after 600miles is up. Then thrash it hard every day once it's warm, with oil changes every 1000miles there after!
PostPosted: 17:08 - 28 Aug 2014    Post subject: Reply with quote
Oil change now, then ride it any way that you like.
If it dies, better that it die sooner than later.
I will mototune the arse off of my next 0 mile bike.
arry
PostPosted: 17:31 - 28 Aug 2014    Post subject: Reply with quote
It'll rust out from under you before the engine dies anyway, so don't take engine breaking in too seriously
But seriously - break in procedure will be in the manual; it'll likely be something like 200 miles at less than 50% throttle, no more than 4k rpm, then 200 miles at less than 70% throttle, 7k rpm and building up from there.
trevor saxe-coburg-gotha
PostPosted: 17:35 - 28 Aug 2014    Post subject: Reply with quote
My 125 had 96 miles (!) on it when I got it, so as good as zilch tbh. I therefore rode it how the handbook told me to - well, near enough. If I'd actually taken it at its word, I'd've never ridden faster than 30mph for the first fourteen millennia. Indeed, I'd probably be still on the return leg of my first wobbly bimble to this very day. Nevertheless, I was cautious, and determined to be kind. And will be again in the extremely unlikely event that I'm ever rich and daft enough to buy new. Mr. Green
ezsauce
PostPosted: 16:24 - 01 Sep 2014    Post subject: Reply with quote
Thanks for the advice.
Can I ask why you guys would change the air filter and the oil now? Considering it's brand new off the shelf?
edit: Also I don't actually think I have been given an owners manual, all I have is the Service and Warranty booklet
Andy_Pagin
PostPosted: 16:39 - 01 Sep 2014    Post subject: Reply with quote
Because you've already put enough miles on it for any muck left over during assembly to be absorbed by the oil.
Then go and nag the dealers, it must have come with a owners manual.
Clutchy
PostPosted: 16:58 - 01 Sep 2014    Post subject: Reply with quote
As part of your running in procedure, go buy some ACF-50 you'll thank me later.
daverave999
PostPosted: 18:57 - 01 Sep 2014    Post subject: Reply with quote
Change the oil filter, not the air filter! For those first few hundred miles the engine parts are 'bedding in' and there'll be little bits of metal worn off and that's why you want to change the oil. The oil passes through the oil filter which collects as much of these bits as possible. The idea of changing the oil and oil filter is to get these out of your engine before they can do any damage.
It's easy BTW. It's pretty much:
1 - Ride bike until oil is hot.
2 - Take off oil filler cap. Put oil pan (I used an old saucepan) under the sump plug and undo sump plug WITH A SPANNER. The oil and engine will be hot enough to burn you. Let it all run out.
3 - Undo oil filter over an oil pan. Let all the oil drain out.
4 - Wipe a film of clean oil over the gasket on the new filter and tighten it on.
5 - Fill up engine to the recommended level and put filler cap back on. Run engine for a couple of minutes then check level again. Top up if necessary.
6 - Dispose of used oil at your local tip. You local council will have somewhere to do this.
2007 Versys 650 2001 Yamaha XJ600S Diversion
HT: Imagine a bike......A bike designed by way of crude polls, assembled by cretins using the finest hammers that Lidl had on offer.
The last post was made 12 years, 16 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.27 Sec - Server Load: 1.83 - MySQL Queries: 13 - Page Size: 66.73 Kb
