Need a new oiler, anyone tried the Cameleon one?
James83
PostPosted: 15:30 - 04 Sep 2014    Post subject: Need a new oiler, anyone tried the Cameleon one? Reply with quote
I’m want a new oiler. Considering the usual tutoro and scottoiler, I like the look of the system, but its more than twice the price of the tutoro. I’ve just come across this in my googling: https://www.amazon.co.uk/Cameleon-Oiler-lubricator-driven-vehicles/dp/B00JI6W7WG/, but there are no reviews. Looks to be American, Anyone used one? Any good?
Jonathan A wrote: tart.
map
Mr Calendar
PostPosted: 15:40 - 04 Sep 2014    Post subject: Reply with quote
Hmmm.
Never heard of them before. Web site appears to be cameleonoiler.com.
There's no bricks and mortar address that I can see. Call me picky but that sets alarm bells ringing in my head (no I'm sure it's not tinnitus). No phone number either. Contact only via website form.
What sort of (legitimate) company is afraid to tell you where they are? I'm all in favour of startup businesses but I draw the line if they can't put some effort in and not look like a scam.
..but your post has reminded me I still need a chain oiler. Preferably before winter.
James83
PostPosted: 15:46 - 04 Sep 2014    Post subject: Reply with quote
My thoughts exactly, hence the question. I'm not playing guinea pig here - if no ones used one on here, I'm not going to bother Smile
ninjabob
PostPosted: 15:51 - 04 Sep 2014    Post subject: Reply with quote
Think they have been available in the US for a long time - never here.
Looks like a quality piece of kit.
https://www.webbikeworld.com/r4/cameleon-motorcycle-chain-oiler/
map
Mr Calendar
PostPosted: 16:02 - 04 Sep 2014    Post subject: Reply with quote
FWIW found a supposedly independent review on webbikeworld.com <edit>as link above by ninjabob</edit>. Oiler requires electrical connection which may account for cost over manual, or the shake release auto, Tutoro. I guess has electric brain to pulse out oil.
What I take from the review...
WebBikeWorld Cameleon Review wrote:
...The most difficult part of installing any automated chain oiling system is getting the drip tube correctly located. With the Cameleon, you also have the added issue of tapping into a switched electrical power source...
I expect installation issues same as Tutoro. I'm guessing pulse rate may vary depends what actual oil you use.
For an electronic chain oiler based in the UK have you seen PDOiler.co.uk?
Google shows me lots more hits on people actually installing that. Looks ballpark price a tad cheaper than the Cameleon too.
barrkel
PostPosted: 17:30 - 04 Sep 2014    Post subject: Reply with quote
I put the scottoiler e-system on my old ER6f. I took it off before I sold it, but my VFR came with a scottoiler v-system and I've not swapped them around.
Electronic oilers - judging by the esystem - are definitely better than gravity-based oilers, especially when touring. With big temperature differentials depending current weather, the oil viscosity can change quite a bit, and it's not difficult to dump all your chain oil in short order when using a setting suitable for a cool, rainy day in warm sunshine. I never had this problem with the esystem.
Wonko The Sane
PostPosted: 17:54 - 04 Sep 2014    Post subject: Reply with quote
I've got a loobman on my ZZR which I got quite annoyed with at first as I couldn't find anywhere for it to fit
It's currently fixed to the front of the pillion foot peg hanger and I clip my heel on it (it's a bit bulky tbh)
Since I don't carry a pillion it might get mounted on the hanger itself out of the way of my foot and in the way of a pillion foot for the above reason.
at £22 its quite good but requires some fettling to get working well and does drip a little bit now and then.
Islander
PostPosted: 19:59 - 04 Sep 2014    Post subject: Reply with quote
The PDOiler is very good, it uses a wick to deliver the oil rather than a nib and is electronically controlled. Thumbs Up
Doddle to fit, doddle to set up too.
Pukka
PostPosted: 20:06 - 04 Sep 2014    Post subject: Reply with quote
I've got one of these, I can definitely recommend it. Have had it fitted for about 10k miles now and cant fault it at all.
Dont know much about the scottoiler personally but had a friend with the tutoro manual one that was always tinkering with it and could never get it to work properly before he decided to take it off and not bother.
James83
PostPosted: 20:20 - 04 Sep 2014    Post subject: Reply with quote
The PDOiler looks interesting, but it says you suspend the dispenser over the chain rather than touching it or the sprocket - do you find it hits the chain reliably?
Islander
PostPosted: 20:39 - 04 Sep 2014    Post subject: Reply with quote
Yes as long as you follow the instructions when setting it up. Thumbs Up
kramdra
PostPosted: 00:05 - 05 Sep 2014    Post subject: Reply with quote
All expensive. Note that PD pump is available separately for £40 if your a cheap git.
I planned to assemble one using a bike engine oil pump (very small, very low displacement per revolution, and very cheap). however I never bothered to find a suitably slow motor to drive it (small stepper motor would be ideal)
So now, I just give a good squirt each outwards journey... typically every 40-60 miles. Quite a bit sprays onto the edge of the tyre, but Ive found its not noticably slippy.
ninjabob
PostPosted: 12:04 - 05 Sep 2014    Post subject: Reply with quote
That is the one I fitted - physically pumps oil at regular intervals once the ignition is switched on - I think the Cameleon is just a gravity fed unit but with and electronic tap.
PD Oiler used to be marketed as the Motrax Lubetronic Electronic Chain Oiler until they went tits up and now sold directly by the maker and very helpful he is too.
The last post was made 12 years, 32 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 80.43 Kb
