I think the divvy is going to die...
sidewinder
PostPosted: 10:14 - 18 Sep 2014    Post subject: I think the divvy is going to die... Reply with quote
So the divvy had a problem.engine is running smooth not missing .all four headers are at the same temp checked this with a temp probe from work.it just been serviced new filters fuel air and oil .new plugs gapped to spec and carbs recently balanced.
but it seems to be totally down on power as if it is running on 3 cylinders but it's definetly not.must be something wrong I could not keep up a gs500 this morning Sad .any ideas of what it could be this one has me stumped.
Cheers all Thumbs Up
nowhere.elysium
The Pork Lord
PostPosted: 10:17 - 18 Sep 2014    Post subject: Reply with quote
Have you checked for air leaks? Have the valve clearances been checked any time recently? Are the coils in good nick?
Baffler186
PostPosted: 10:38 - 18 Sep 2014    Post subject: Reply with quote
What's the nature of the power loss i.e. are there noticeable flat spots, is it jumpy, or is it all totally smooth but feels like you're down 30HP?
Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic
sidewinder
PostPosted: 10:49 - 18 Sep 2014    Post subject: Reply with quote
It feels smooth but down on power.no flat spots runs fine .just got very slow Very Happy
sidewinder
PostPosted: 10:51 - 18 Sep 2014    Post subject: Reply with quote
Valve clearances were done a few months back.its had new inlet rubbers recently to the ones which hold the carbs on Thumbs Up
Clutchy
Compression test?
sidewinder
PostPosted: 11:03 - 18 Sep 2014    Post subject: Reply with quote
Good point on compression test.but it's not using oil or any visable blue smoke
A100man
PostPosted: 12:38 - 18 Sep 2014    Post subject: Reply with quote
A couple of basic ones..
Binding brake.. Throttle not opening fully..
sidewinder
PostPosted: 12:50 - 18 Sep 2014    Post subject: Reply with quote
Compression test just been done all cypinders s are within specs.brakes not binding they have also just been done.could it be coils or the rectifier?
raak
PostPosted: 13:07 - 18 Sep 2014    Post subject: Re: I think the divvy is going to die... Reply with quote
i assume it was a new fuel filter as well, as you wrote.
only reason is i had an ntv ran fine but at full throttle, it just seemed to do little above 70moh...changed filter all back to normal.
probably of no help, just thought i'd mention it.
good luck with fault finding.. Thumbs Up
Previous bikes: Suzuki GT250A / Yamaha DT125 / NTV Honda 650 // currently Suzuki RF900
Baffler186
PostPosted: 14:19 - 18 Sep 2014    Post subject: Reply with quote
Not sure about coils. Symptoms are similar to what happened when my reg/rec went, but that was because my battery had been killed so I was essentially just running the battery completely flat (as it wasn't holding a charge anymore). Can you test battery and rectifier with multi-meter?
sidewinder
PostPosted: 15:15 - 18 Sep 2014    Post subject: Reply with quote
Battery is pretty new and lights get brighter when revved a bit..I just don't think it is electrical.the bike is running fine not missing or any thing.it pulls fine but not with the same power as before.fuel filter was changed and fuel is running clear through it.its topping out at 80ish almost feels like it's restricted...starts first time all the time from hot and cold.could it be the choke not closing completely that's all I can think of now Confused
Cheers for the help so far all Thumbs Up
el_oso
PostPosted: 16:13 - 18 Sep 2014    Post subject: Reply with quote
I've had something similar on my thundercat. I somehow managed to twist the fuel hose after having the tank off which restricted the fuel flow.
maybe time to give the carbs and overhaul.
Duke 390
Car: Jeep Wrangler 4.0L
talkToTheHat
PostPosted: 16:55 - 18 Sep 2014    Post subject: Reply with quote
A plague on Viragos is sticking carb slides and ruptured diaphragms, causes lumpy running and lack of power but no cold headers at idle, divvy is from same era, do same problems apply?
Bandit. does. everything.
sidewinder
PostPosted: 17:07 - 18 Sep 2014    Post subject: Reply with quote
Fuck yeah fixed it Dance!
As mentioned above removed carbs stripped them all nice and clean.fuel lines etc all ok .then misses came out with bacon .and said whats that rattling sound coming from the exhaust.took a look and guess what the spring which holds the baffle in place had come of .causing the baffle to sit at a angle.blocking half the pipe of.so put it back in place replaced the spring.and hey presto back to it full 63bhp .runs a lot better now Embarassed
Cheers for the help again all Karma
A100man
PostPosted: 23:20 - 18 Sep 2014    Post subject: Reply with quote
good result. Very Happy
Ballpien
PostPosted: 01:01 - 19 Sep 2014    Post subject: Reply with quote
Bacon saves the day
R125 - FZ1n ABS
Looking forward to the 5,000,000th post in 2017
sidewinder
PostPosted: 17:06 - 19 Sep 2014    Post subject: Reply with quote
Bacon rules.a d the bike still seems to be ok Thumbs Up
The last post was made 12 years, 24 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.44 - MySQL Queries: 13 - Page Size: 96.23 Kb
