| i.p.phrealy |
 i.p.phrealy World Chat Champion
 Posted: 19:12 - 03 Oct 2014 Post subject: VT500 won't bloody start!! |
So, after blowing up the previous engine and installing one from Smegballs the fecker won't start.
I thought it was the battery at first, so I borrowed a set of jump leads and tried that.
nothing.
All the other electrics work, indicators, lights, horn, the rad fan (it was on a bypass switch).
but press the button, not even a click. it doesn't turn over.
the bike is in neutral, the neutral light is on, it has fresh plugs, it has oil. I checked all the fuses and they're all good.
Dafuq do I do now?
 ____________________ it is impossible to lick your own elbow...
Finally allowed a big bike 19/03/14! |
| Taught2BCauti... |
 Posted: 19:37 - 03 Oct 2014 Post subject: |
Check the stand switch?
Do you have a resistance (in ohms) between the starter live terminal and earth? ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| i.p.phrealy |
 Posted: 20:05 - 03 Oct 2014 Post subject: |
Your problem is not that the engine is not starting - it's that the engine is not cranking. If it cranks it may well start.
Hit it with the basics. Large cable goes from the battery to the solenoid then from the solenoid to the starter. So the solenoid has two large terminals next to each other. Make sure the bike is out of gear and short them with an old spanner. Does the bike now crank?
If yes, you have a starter control circuit issue.
If no, you have a fault in the starter or you have left the heavy earth off the engine. ____________________ a.k.a 'Geri'
| i.p.phrealy |
 Posted: 21:46 - 03 Oct 2014 Post subject: |
I'd fit the starter off the old engine. Sounds like yours is faulty
| doggone |
 doggone World Chat Champion
| temeluchus |
| i.p.phrealy |
| i.p.phrealy |
| temeluchus |
| i.p.phrealy |
The last post was made 11 years, 228 days ago. Instead of replying here, would creating a new thread be more useful? |
