VT500 won't bloody start!!
i.p.phrealy
PostPosted: 19:12 - 03 Oct 2014    Post subject: VT500 won't bloody start!! Reply with quote
So, after blowing up the previous engine and installing one from Smegballs the fecker won't start.
I thought it was the battery at first, so I borrowed a set of jump leads and tried that.
nothing.
All the other electrics work, indicators, lights, horn, the rad fan (it was on a bypass switch).
but press the button, not even a click. it doesn't turn over.
the bike is in neutral, the neutral light is on, it has fresh plugs, it has oil. I checked all the fuses and they're all good.
Dafuq do I do now?
Thinking
Taught2BCauti...
PostPosted: 19:37 - 03 Oct 2014    Post subject: Reply with quote
Check the stand switch?
Do you have a resistance (in ohms) between the starter live terminal and earth?
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
i.p.phrealy
PostPosted: 19:53 - 03 Oct 2014    Post subject: Reply with quote
there isn't one!
The multimeter is getting broken out this weekend.
PostPosted: 20:05 - 03 Oct 2014    Post subject: Reply with quote
Your problem is not that the engine is not starting - it's that the engine is not cranking. If it cranks it may well start.
Hit it with the basics. Large cable goes from the battery to the solenoid then from the solenoid to the starter. So the solenoid has two large terminals next to each other. Make sure the bike is out of gear and short them with an old spanner. Does the bike now crank?
If yes, you have a starter control circuit issue.
If no, you have a fault in the starter or you have left the heavy earth off the engine.
i.p.phrealy
PostPosted: 21:09 - 03 Oct 2014    Post subject: Reply with quote
What he said! Laughing it isn't cranking, but as the engine hasn't been span up for a few years i didn't want to try and bump it.
took the jump lead and stuck one end on the starter terminal and the other to the + of the battery, no cranking.
Earth is connected, also tried to bypass the big earth just in case by clipping the other jump lead to the engine and the other to the - of the battery.
so the starter is probably fubar then Mad
PostPosted: 21:46 - 03 Oct 2014    Post subject: Reply with quote
I'd fit the starter off the old engine. Sounds like yours is faulty
doggone
PostPosted: 22:02 - 03 Oct 2014    Post subject: Reply with quote
Or stuck.
Try the big hammer at it.
temeluchus
PostPosted: 22:08 - 03 Oct 2014    Post subject: Reply with quote
if you are really lucky, the rings are rusted to the bores. Have fun.
i.p.phrealy
PostPosted: 14:59 - 04 Oct 2014    Post subject: Reply with quote
nope, turned it over by hand to check for this.
new motor didn't have a starter motor. going to take it off, jump lead it to the car and twat it with a hammer. Thumbs Up
i.p.phrealy
PostPosted: 18:38 - 09 Nov 2014    Post subject: Reply with quote
didn't need the hammer, took the starter motor off, attached it to jump leads then touched them to my car battery and the starter spun up line a good un.
hmmm...
more time next weekend to see what's up with it. it's the only free weekend I have this side of christmas.
temeluchus
PostPosted: 19:23 - 09 Nov 2014    Post subject: Reply with quote
How to the brushes look? Have you checked the windings?
i.p.phrealy
PostPosted: 23:02 - 09 Nov 2014    Post subject: Reply with quote
i'd bought new brushes just in case, I'll swap them over anyway.
The last post was made 11 years, 227 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.08 - MySQL Queries: 13 - Page Size: 77.63 Kb
