suzuki gs 125 only starts with easy start
stevenc370
PostPosted: 21:16 - 17 Oct 2014    Post subject: suzuki gs 125 only starts with easy start Reply with quote
so I got myself suzuki gs 125 cheap off fleabags for a bit of a project through the winter the guy i got it off said it was sat idling when it cut out snd hasnt started since. I took the carb off and cleaned everything with carb cleaner and still the same. However if I spray carb cleaner into the carb whilst turning it over it will start and idles quite nicely but as soon as I touch the throttle it back fires and cuts out. Any ideas on what could be wrong. I was thinking about buying a new carb but unsure if this would solve it.
hmmmnz
PostPosted: 23:08 - 17 Oct 2014    Post subject: Reply with quote
valve clearances
do them,
before you do anything else,
do them, do them, do them.
the humans are dead
I kick arse for the lord
stevenc370
PostPosted: 14:54 - 18 Oct 2014    Post subject: Reply with quote
so I did the valve clearance this morning there was minimal adjustment and the symptoms are still exactly the same. I spoke to my dad he reckons could be a tooth out on the cam chain what do you guys think before I pull it in bits to have look.
stevenc370
PostPosted: 15:27 - 18 Oct 2014    Post subject: Reply with quote
how would I go about checking the position of the cdi unit? also how do you set the valve timing I no there's the marking on the crankcase and flywheel for tdc but is there a marking on the cam shaft or top end of the engine. Thanks for the help
stevenc370
PostPosted: 15:59 - 18 Oct 2014    Post subject: Reply with quote
Back in the shed it is then. Thanks for the help.
stevenc370
PostPosted: 12:02 - 19 Oct 2014    Post subject: Reply with quote
so I've started doing the valve timing this morning set the marks all up as it says in the manual span it round a few times by hand with the rocker cover off to check the chain wouldn't slip all seemed well then but it all back together checked by hand again and the piston is hitting the valve. where did I go wrong? The marks still all line up?
bradh511
PostPosted: 01:28 - 13 Jan 2015    Post subject: Reply with quote
The rocker covert has the tappet arms inside so you can spin it over all you want won't do anything ie open valves till its back on you may have set it 180 out?
Theory 11-10-12 lets hope i get mod 1 and 2 done by the 18th of jan 2013 Smile
bradh511
PostPosted: 14:42 - 13 Jan 2015    Post subject: Reply with quote
By this i mean the cam locating stud is facing up when cam marks appear flat with head...and lobes appear to have no lift if you catch my drift
The last post was made 11 years, 29 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 65.12 Kb
