| stevenc370 |
 stevenc370 Two Stroke Sniffer
| hmmmnz |
 hmmmnz Super Spammer
| stevenc370 |
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 15:08 - 18 Oct 2014 Post subject: |
your da may be right ,if so the valves could be kissing the piston.
You could try checking the compression if its a higher milage bike......above 14k.Also check the carb jets are standard and unblocked and the float height is reasonably accurate.It does sometimes happen that the camchain adjuster seizes and can jump a tooth.
another thing to check is the cdi unit for accurate position.
Easy start should be handled with care ,IMHO it should only be used on tired deisels or in an emergency when the weathers freezing and the battery is nearly fckld.
I ve heard stories of people wrecking engines with easy start. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| stevenc370 |
| unitynotsocri... |
 Posted: 15:45 - 18 Oct 2014 Post subject: |
theres usually a mark on the camshaft sproket and a T mark on the flywheel . If the cdi has been moved it would be unusual .
One way to check is to find TDC ...top dead centre and check the the top of the valve springs and make sure they are not opening any of the valves..........soz........check out RV125 timing on BCF old thread
| stevenc370 |
| stevenc370 |
| bradh511 |
 bradh511 Scooby Slapper
 Posted: 01:28 - 13 Jan 2015 Post subject: |
The rocker covert has the tappet arms inside so you can spin it over all you want won't do anything ie open valves till its back on you may have set it 180 out? ____________________ Theory 11-10-12 lets hope i get mod 1 and 2 done by the 18th of jan 2013  |
| bradh511 |
 Posted: 14:42 - 13 Jan 2015 Post subject: |
By this i mean the cam locating stud is facing up when cam marks appear flat with head...and lobes appear to have no lift if you catch my drift ____________________ Theory 11-10-12 lets hope i get mod 1 and 2 done by the 18th of jan 2013  |
The last post was made 11 years, 31 days ago. Instead of replying here, would creating a new thread be more useful? |
