GZ125. New cdi now bog
Bishopgaming
PostPosted: 12:24 - 20 Dec 2014    Post subject: GZ125. New cdi now bog Reply with quote
Hi all I had a problem with no spark. I changed cdi and presto. Now however I can only do 40mph. Sometimes I get to 50 but rarely.
Before I repaired with a new cdi when she was running I did 65.
Seems to have a sort of flat spot on the throttle 3/4 of the way. Like has no more power to give.
Is it my carb settings as I had it off the bike at one point during repair. If so any tip on how to set it? Novice here.
Edit.
Exhaust pops with throttle closing from over half.
Bishopgaming
PostPosted: 16:51 - 21 Dec 2014    Post subject: Reply with quote
Bump
talkToTheHat
PostPosted: 00:19 - 22 Dec 2014    Post subject: Reply with quote
Sounds like the mixture is way out, possibly an air leak? with the bike running spray water over the rubber intake boot between the engine and carb and see if the engine speed changes.
Mine would pop a little at idle, but yours sounds way out.
Check the spark plug is clean, the spark gap is to specification, and that you have a strong enough spark. If the bike is eating CDIs, either your ignition coil or the witing to it has an intermittent short, or your rectifier is on the way out. Get a multimeter and check electrics carefully. Most "carb" problems are electrical. Most of the other ones are inexpert reassembly after an electrical fault.
Bandit. does. everything.
Bishopgaming
PostPosted: 02:20 - 22 Dec 2014    Post subject: Reply with quote
Thanks for the reply. I have no idea how to adjust the mixture. It's my first cdi in 8 months but it was damaged. Any idea how I can adjust it. My choke cable snapped could that be the problem.
UncleFester
PostPosted: 08:37 - 22 Dec 2014    Post subject: Reply with quote
I doubt it is helping - if you know it's broken, get it fixed.
2017 Z1000SX
Bishopgaming
PostPosted: 15:47 - 22 Dec 2014    Post subject: Reply with quote
Choke cable
Is on it's way. I managed 53 in 4th earlier. It just isn't enough for my
Route. Any help is fantastic
UncleFester
PostPosted: 15:54 - 22 Dec 2014    Post subject: Reply with quote
I would wait till that's fitted and fixed - no use chasing multiple issues if one could be the root cause of the other(s).
2017 Z1000SX
mudcow007
PostPosted: 17:14 - 22 Dec 2014    Post subject: Reply with quote
is it starting ok with no choke?
have you pulled the plug an checked out how black it is(n't)
I reckons - but im more than likely wrong, is you are running mega rich, so starts easy but has no powa
take plug out, wipe all the shite off, go for a ride pull plug out an tell us
Bishopgaming
PostPosted: 23:24 - 22 Dec 2014    Post subject: Reply with quote
Plugs black. I tried sorting the mixture however I'm not sure I'm using the correct screw. Or even how to use it any ideas
talkToTheHat
PostPosted: 03:26 - 23 Dec 2014    Post subject: Reply with quote
Fix the choke operation. If its on and left on it will foul your plug causing plug to be black. Is plug black with dry soot or oily?
Check your air filter is not blocked.
What's your oil like, is the level low, high, is the oil thin and reeking of petrol?
Carb should have thumbwheel idle adjustment, a drain screw and a little screw behind a blanking plug for idle mixture correction. Unless you moved it when you dismantled the carb, leave well alone. Check fuel level in carb, and check the fuel in your float bowl is clean. This requires some clear plastic tubing and a manual with the correct float level. Beyond that mixture adjustment requires changing parts in the carb.
A high fuel level caused by a maladjusted or leaking float, debris in the float valve or a worn float valve is easily correctable.
Get a new plug in there and have a spare. If you've got a working choke, good float level, a good air filter, no air leaks and clean fuel, then next most likely is the rest of your combustion chamber looks like your plug and that's probably cureable with some redex dosing and an italian tune-up.
Further suggestions: slide does not move in carb freely or diaphragm is damaged, or something to do with this operation was not assembled correctly when you serviced the carb. [/u]
temeluchus
PostPosted: 06:26 - 23 Dec 2014    Post subject: Reply with quote
You could have the incorrect ignitor and it is not advancing the ignition. This will cause performance to be flat as a pancake.
Bishopgaming
PostPosted: 12:57 - 23 Dec 2014    Post subject: Reply with quote
Just received a new choke cable. Fitting later today as well as adjusting the mixture correctly. Then will be cleaning carb if no luck
mudcow007
PostPosted: 12:59 - 23 Dec 2014    Post subject: Reply with quote
I would clean the carb anyway, you may has well, you know all is good then
check the float etc while your at it as well
Bishopgaming
PostPosted: 13:24 - 23 Dec 2014    Post subject: Reply with quote
Alright I'll get se cleaner to go through it. Thanks for the advice I'll keep you updated.
Bishopgaming
PostPosted: 14:00 - 23 Dec 2014    Post subject: Reply with quote
Right ok I adjusted the mixture idle to highest idle. Then turned down my actual idle thumb screw. Now I'm gonna blast it with carb cleaner
Bishopgaming
PostPosted: 15:16 - 23 Dec 2014    Post subject: Reply with quote
Same problem. Exhaust sounds super deep now however. Too much fuel?
Bishopgaming
PostPosted: 19:48 - 24 Dec 2014    Post subject: Reply with quote
found a small hole in my diaphragm? could this be the issue
temeluchus
PostPosted: 08:41 - 25 Dec 2014    Post subject: Reply with quote
Assuming you mean the one on the slide, yes it will. Use some rubber cement and a small patch. Inner tube repairs are fine for this.
Bishopgaming
PostPosted: 18:32 - 25 Dec 2014    Post subject: Reply with quote
Thanks mate I'll try that now.
Bishopgaming
PostPosted: 02:53 - 29 Dec 2014    Post subject: Reply with quote
Same problem. Seems no matter what I do can't achieve above 50. Could the cdi be limited?
temeluchus
PostPosted: 05:37 - 29 Dec 2014    Post subject: Reply with quote
Where did you get the ignitor from?
Bishopgaming
PostPosted: 04:00 - 30 Dec 2014    Post subject: Reply with quote
A friend had it in his garage
talkToTheHat
PostPosted: 07:35 - 30 Dec 2014    Post subject: Reply with quote
Check the part code, IIRC german (and perhaps other) models had an electronicly limited top speed of about 80kph.
Amusing that some european learner bikes were required to not be capable of 60, and pre-2012 125 suitable for the test had to be theoreticly capable of 60...
Bishopgaming
PostPosted: 10:39 - 30 Dec 2014    Post subject: Reply with quote
Hi mate how
Do I check the model of its german
talkToTheHat
PostPosted: 06:49 - 31 Dec 2014    Post subject: Reply with quote
Check the part number on the CDI against suzuki's parts catalog. Try websites like this https://www.cmsnl.com/suzuki-gz125-2000-y_model13796/partslist/FIG19.html#results or cultivate a relationship with a dealer
Simpler question, is it the same part code as the CDI you broke?
The last post was made 11 years, 278 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 124.86 Kb
