| Bishopgaming |
 Bishopgaming Derestricted Danger
| Bishopgaming |
| talkToTheHat |
 talkToTheHat World Chat Champion
| Bishopgaming |
| UncleFester |
 UncleFester World Chat Champion
| Bishopgaming |
| UncleFester |
| mudcow007 |
 mudcow007 World Chat Champion
| Bishopgaming |
| talkToTheHat |
 Posted: 03:26 - 23 Dec 2014 Post subject: |
Fix the choke operation. If its on and left on it will foul your plug causing plug to be black. Is plug black with dry soot or oily?
Check your air filter is not blocked.
What's your oil like, is the level low, high, is the oil thin and reeking of petrol?
Carb should have thumbwheel idle adjustment, a drain screw and a little screw behind a blanking plug for idle mixture correction. Unless you moved it when you dismantled the carb, leave well alone. Check fuel level in carb, and check the fuel in your float bowl is clean. This requires some clear plastic tubing and a manual with the correct float level. Beyond that mixture adjustment requires changing parts in the carb.
A high fuel level caused by a maladjusted or leaking float, debris in the float valve or a worn float valve is easily correctable.
Get a new plug in there and have a spare. If you've got a working choke, good float level, a good air filter, no air leaks and clean fuel, then next most likely is the rest of your combustion chamber looks like your plug and that's probably cureable with some redex dosing and an italian tune-up.
Further suggestions: slide does not move in carb freely or diaphragm is damaged, or something to do with this operation was not assembled correctly when you serviced the carb. [/u] ____________________ Bandit. does. everything. |
| temeluchus |
| Bishopgaming |
| mudcow007 |
| Bishopgaming |
| Bishopgaming |
| Bishopgaming |
| Bishopgaming |
| temeluchus |
| Bishopgaming |
| Bishopgaming |
| temeluchus |
| Bishopgaming |
| talkToTheHat |
| Bishopgaming |
| talkToTheHat |
The last post was made 11 years, 278 days ago. Instead of replying here, would creating a new thread be more useful? |
