| MattR6 |
 MattR6 L Plate Warrior
| Minty |
 Minty World Chat Champion
| MattR6 |
| Minty |
 Posted: 20:22 - 27 Dec 2014 Post subject: |
To be bluntly obvious, I guessed it was beyond your dad on the basis he suggested just cutting the fan wire to switch it off.
You started with dodgy indicators and now have a permanently live fan. You can't cut the live wire to everything.
And if it is 40amp,then I'd expect it to be a major one. The simplest way to see what it is, is to see what is no longer working now it has blown.  ____________________ My fingers smell of your mum. |
 Posted: 21:04 - 27 Dec 2014 Post subject: |
First thing I'd do is rip the alarm off and sling it down the street. ____________________ a.k.a 'Geri'
| Fisty |
 Fisty Super Spammer
| MattR6 |
| MattEMulsion |
 MattEMulsion World Chat Champion
 Posted: 22:33 - 27 Dec 2014 Post subject: |
I've looked at the (difficult to follow0 wiring diagram and the fan is switched by a relay which is fed live power and controlled by the ECU. So either the fan relay is stuck closed or the ECU remains powered AND thinks the engine is too hot.
Find the fusebox and pull te fuse for the fan, that should let you keep the charge in the battery, though it won't cure the underlying fault.
Put your location in your profile and you might find someone is nearby who can help. If you're in Kent I can spare some time this week. ____________________ a.k.a 'Geri'
| kramdra |
 kramdra World Chat Champion
 Posted: 00:51 - 28 Dec 2014 Post subject: |
Did you ever bump start her rather than jumping (jumping is using another battery, bump is by push starting). The reason I ask is because shortly after doing so to my cbr600 couple years ago the regulator died and refused to charge. The occasional flat battery issue was caused by oxford hotgrips being left on (which are suppost to turn off before they flatten battery, guess what? ). So I suspect bump starting might not do the reg much good, which was recommended against in the manual probably for this reason.
Regs are relatively cheap, borrow a multimeter and check if she is charging properly. Also check your stator and reg connections for corrosion and heat damage.
I would also be checking your indicator switch and all front loom connectors. Open them up, check for corrosion and spray with graphite lube or wd40. Check resistance of the fan switch at the relevant temperatures, connector for corrosion.. |
| Clutchy |
 Clutchy World Chat Champion
| monkeybiker |
 monkeybiker World Chat Champion
The last post was made 11 years, 278 days ago. Instead of replying here, would creating a new thread be more useful? |
