Honda CB600F5 Hornet will not start.
jonathan26
PostPosted: 16:55 - 05 Jan 2015    Post subject: Honda CB600F5 Hornet will not start. Reply with quote
Ok any ideas will be appreciated. The bike is a Honda Hornet 600, 2005.
With the recent cold weather the bike has been hard to start, I thought this might be due to a week battery or problem with the charging system. In any case after a bit of trying, either just using the choke or a bit of choke with throttle, I had always, until now been able to start it.
I have have just checked the plugs which were in good condition, with a bit of black carbon on the ceramic part and dark Gray on the electrodes. they looked close to what was recommended in the Haynes manual. So i cleaned them with a wire brush and checked the distances, all seamed good.
After re fitting the plugs, and trying to start with a charged battery, the bike would turn over but not start. It fired a bit but would not start, a couple of times back firing.
I also looked at the air filter, which looked clean, although there was a bit tiny bit of oil residue in the bottom of the box which I cleaned.
So now with a charged battery it will turnover with the choke fully on, but not start. With no choke or semi choke it fires a bit but will not start, sometimes misfiring.
Any ideas would be appreciated.
Taught2BCauti...
PostPosted: 11:36 - 06 Jan 2015    Post subject: Reply with quote
It sounds like a fuelling issue to me, so a carburettor strip and clean might be on the cards.
A weak battery can also cause problems, so check the system with a voltmeter - noting the readings across the battery with the ignition on, and also whilst cranking on the starter.
If the voltage drops too much below 12v, this could cause the CDI unit to malfunction.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
temeluchus
PostPosted: 12:25 - 06 Jan 2015    Post subject: Reply with quote
slap new plugs in it and think about a new battery before ripping the carbs apart.
sickpup
Old Timer
PostPosted: 13:11 - 06 Jan 2015    Post subject: Reply with quote
How exactly did you come to this conclusion?
PostPosted: 13:12 - 06 Jan 2015    Post subject: Re: Honda CB600F5 Hornet will not start. Reply with quote
Any chance that you just wire brushed a couple of iridium plugs?
jonathan26
PostPosted: 18:21 - 06 Jan 2015    Post subject: Re: Honda CB600F5 Hornet will not start. Reply with quote
I'm not sure, does using a wire brush kill them? Is there a way to clean them?
Just checked the plugs, they seem to be sparking, but were wet even after 1 day.
jonathan26
PostPosted: 18:38 - 06 Jan 2015    Post subject: Reply with quote
I will test the battery, but I did try starting with another battery with no result.
Also if the plugs are wet ( flooded), its possible I could have done this. I would have thought after 1 day the fuel would have evaporated. What problems with the carbs could account for excess fuel sent to the engine?
Thanks
bradh511
PostPosted: 18:49 - 06 Jan 2015    Post subject: Reply with quote
if the plugs wet then it a spark problem ... have you got you kill switch on is there any other cut off switches that you may bypass to simply rule them out it doesn't have a clutch switch or side stand ??
i heard of a few cases with some bikes you choke is not stuck on .. causing it to flood?
All the best Brad
Theory 11-10-12 lets hope i get mod 1 and 2 done by the 18th of jan 2013 Smile
yen_powell
PostPosted: 19:20 - 06 Jan 2015    Post subject: Reply with quote
Does the bike use the same dodgy fuel pump as CBR600s?
XT1200Z and a DR350 in bits
The last post was made 11 years, 312 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.24 - MySQL Queries: 13 - Page Size: 61.96 Kb
