Peugeot speedfight 2 no spark
Mentaldazza
PostPosted: 16:07 - 20 Jan 2015    Post subject: Peugeot speedfight 2 no spark Reply with quote
Hi I have a speedfight 2 it was a cold frosty night the bike was being a little bit of a pain to start like it normally is so after about 5 kicks it turns over but then cut out after another 5 it done the same and hasn't had no life since I turn the ignition on and petrol gage goes up so its not to do with battery or ignition plug I have changed the spark plug and ht lead and plug cap but still no spark I have checked the wires that go to the ht lead and they are fine also checked the fuse that is fine I have ran out of ideas could anyone help with what could be causing this to happen thanks
Mental
andys675
PostPosted: 22:28 - 20 Jan 2015    Post subject: Reply with quote
coils go quite often on these, they're the same as a honda vision and cost anything from £6 to £20 on ebay
https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H1.Xhonda+vision+coil&_nkw=honda+vision+coil&_sacat=0
Mentaldazza
PostPosted: 00:56 - 21 Jan 2015    Post subject: Reply with quote
I have replaced the coil and the starter motor don't work and can only be kicked so could it be the starter relay?
Mental
andyscooter
PostPosted: 07:54 - 21 Jan 2015    Post subject: Reply with quote
petrol gauge will work with a tiny bit of power
whats the voltage on the battery reading
Mentaldazza
PostPosted: 12:03 - 21 Jan 2015    Post subject: Reply with quote
It is 12 v but the bike can run without a battery it dont have a imobiliser
Mental
barrkel
PostPosted: 13:36 - 21 Jan 2015    Post subject: Reply with quote
12v is very low. A good, charged battery will be higher. What happens to the voltage when you hit the ignition and try to get it to turn over with the starter?
It may run without a battery, but that requires that the charging system is working correctly.
On my VFR, when the stator or reg/rec has died and the battery is no longer charging, it normally has enough juice to do initial startup, light up the dash etc., but then it dies when the ignition is pressed. It'll bump-start, but it'll only run until the battery is drained.
My bet is that something is wrong with your charging system and your battery doesn't have enough juice left to do any starting.
wr6133
PostPosted: 13:48 - 21 Jan 2015    Post subject: Reply with quote
Your VFR has a fuel pump and or FI hence the need for power. The OP's ped is carb'd and vacuum tapped so can be started on a kick with a completely dead battery and should stay running. From what he has done already I'd be looking at the fuelling, the diaphragm for the vac tap may be buggered and stopping any petrol getting to the carb, hence it running for a little bit but not since.
Mentaldazza
PostPosted: 14:08 - 21 Jan 2015    Post subject: Reply with quote
I see where your coming from but that don't explain the spark problem . All lights run off the mag when it is running
Mental
wr6133
PostPosted: 14:17 - 21 Jan 2015    Post subject: Reply with quote
How have you been checking the plug for a spark? If you have been relying on the kicker then there is no way you could hold the plug earthed against the frame, while kicking the thing over and watching the plug.
Mentaldazza
PostPosted: 15:09 - 21 Jan 2015    Post subject: Reply with quote
I had my brother to help me I kicked while he watched for a spark
Mental
wr6133
PostPosted: 15:35 - 21 Jan 2015    Post subject: Reply with quote
Ok, swap roles (just incase your brother is being potato)
From what I'm reading (correct me if wrong)
Started on kick, ran for a bit and died
Started one more time and did the same
No longer starts
You have replaced
Spark plug
HT lead
Plug cap
Coil
You have checked various things (with a mutimeter I assume).
So assuming all those new parts work and your checks were correct, we know the spark plug should be sparking.
You say it's not so either it is and you are not checking it properly or one of the parts you have checked/replaced was checked incorrectly.
If the plug does spark, then your issue is fuelling (you could toss a capful of fuel down the plughole, go all Mr Motivator on the kicker and if it fires you have a fuelling issue and a potato brother)
If it doesn't spark then do all your checks again working back from the plug all the way to the CDI because you have missed something the first time round.
Mentaldazza
PostPosted: 15:48 - 21 Jan 2015    Post subject: Reply with quote
Yes all correct yes my brother can be a patato at times but I made sure he wasent doing nothing wrong and we did try both ways . I will check it all agen I haven't checked the Cdi how would your know when it is gone
Mental
wr6133
PostPosted: 15:57 - 21 Jan 2015    Post subject: Reply with quote
When you have ruled out everything else. You then try a replacement CDI, if it works old CDI was dead.
Mentaldazza
PostPosted: 16:01 - 21 Jan 2015    Post subject: Reply with quote
Ok cheers ill check ill order a new Cdi asap thanks
Mental
Mentaldazza
PostPosted: 13:19 - 07 Mar 2015    Post subject: Reply with quote
Ok I'm back I've replaced the Cdi it dint spark so I brought new wire and re wired it still no spark any suggestions thanks
Mental
andys675
PostPosted: 00:24 - 10 Mar 2015    Post subject: Reply with quote
time to get a multimeter and see what power you have coming out of the stator plate and going to the coil
Mentaldazza
PostPosted: 19:07 - 26 Mar 2015    Post subject: Reply with quote
Ok my stator plate was dead so I brought a new 1 but still no spark really annoying me now
Mental
Codezombie
PostPosted: 22:25 - 26 Mar 2015    Post subject: Reply with quote
I'd start looking for a break in the circuit somewhere, (broken wire) and be continuity checking all along the circuit.
2015 Zero-SR; Yamaha Diversion 900
Mentaldazza
PostPosted: 00:15 - 27 Mar 2015    Post subject: Reply with quote
I brought another wiring loom and still no spark but I dunno if that loom is dodgy so gunna get a new 1 and take the bike and try befor I buy
Mental
andyscooter
PostPosted: 07:56 - 27 Mar 2015    Post subject: Reply with quote
have you checked the battery yet
in all your posts you are changing electrical componants but you havnt mentioned the battery
you say it powers the gauges but a minimal bit of power will do that
andys675
PostPosted: 11:29 - 29 Mar 2015    Post subject: Reply with quote
you can't just keep throwing money at it
buy a fecking multimeter, less than £5
spend some time checking the electrical system to see where you have power and where you don't and use that information to work out what is wrong, simple continuity of a wire or connector may be all you're suffering from
Mentaldazza
PostPosted: 09:27 - 13 Apr 2015    Post subject: Reply with quote
Ok I've had my bike running for 2 days now with no problems just thought I'd let you know a wire from the stator plate going to the Cdi had vanished I brought a Haynes manual just for the wiring diagram . Cheers for all your help. Very Happy thanks
Mental
The last post was made 10 years, 265 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.17 - MySQL Queries: 13 - Page Size: 110.8 Kb
