| Mentaldazza |
 Mentaldazza Derestricted Danger
| andys675 |
 andys675 World Chat Champion
| Mentaldazza |
| andyscooter |
 andyscooter World Chat Champion
| Mentaldazza |
| barrkel |
 barrkel World Chat Champion
 Posted: 13:36 - 21 Jan 2015 Post subject: |
| Mentaldazza wrote: | It is 12 v but the bike can run without a battery it dont have a imobiliser |
12v is very low. A good, charged battery will be higher. What happens to the voltage when you hit the ignition and try to get it to turn over with the starter?
It may run without a battery, but that requires that the charging system is working correctly.
On my VFR, when the stator or reg/rec has died and the battery is no longer charging, it normally has enough juice to do initial startup, light up the dash etc., but then it dies when the ignition is pressed. It'll bump-start, but it'll only run until the battery is drained.
My bet is that something is wrong with your charging system and your battery doesn't have enough juice left to do any starting. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
Best road ever ridden: www.youtube.com/watch?v=s2MhNxUEYtQ |
| wr6133 |
 wr6133 World Chat Champion
| Mentaldazza |
| wr6133 |
| Mentaldazza |
| wr6133 |
| Mentaldazza |
| wr6133 |
| Mentaldazza |
| Mentaldazza |
| andys675 |
| Mentaldazza |
| Codezombie |
 Codezombie Nova Slayer
| Mentaldazza |
| andyscooter |
| andys675 |
| Mentaldazza |
 Posted: 09:27 - 13 Apr 2015 Post subject: |
Ok I've had my bike running for 2 days now with no problems just thought I'd let you know a wire from the stator plate going to the Cdi had vanished I brought a Haynes manual just for the wiring diagram . Cheers for all your help. thanks ____________________ Mental |
The last post was made 10 years, 276 days ago. Instead of replying here, would creating a new thread be more useful? |
