Noticed some cracks on my Varadero 125 engine
primalcarl
PostPosted: 14:12 - 01 Feb 2015    Post subject: Noticed some cracks on my Varadero 125 engine Reply with quote
I bought a Varadero 125 in December but after managing to break my wrist the very next day, I'm only now thinking about riding it.
I was applying some acf50 to it today and noticed some cracks on the engine. Pretty pissed off is an understatement Sad
https://img.photobucket.com/albums/v195/jaffacake71/Mobile%20Uploads/20150201_120831_resized_1.jpg~original
Bike is an '08 with 8k on the clock
What should I do?
PostPosted: 15:26 - 01 Feb 2015    Post subject: Reply with quote
Ride it? Mime had loads like that and it didn't die. Didn't leak or cause any issues.
1198
PostPosted: 15:49 - 01 Feb 2015    Post subject: Reply with quote
As long as it's oil / airtight I'd ignore it and ride it - although I'd keep an eye on it.
After a month, maybe more, I imagine the previous owner would just tell you to go hop if you were to complain to them.
CHR15
Turbo nutter bastard
PostPosted: 15:50 - 01 Feb 2015    Post subject: Reply with quote
there not cracks.
if you run your fingernail over them you'll notice they stick out like a burr.
there caused by thermal expansion cracking of the die that was used to cast those aluminium parts.
every time you pour liquid ali into the die and let it solidify the die gets heat cycled which causes thermal stress and leads to the die cracking.
it occurs quicker in parts of the die with step changes or tight rads, hence probably why its across that rad on the upstand.
theres nothing wrong with the casting and your engine isnt going to assplode, hence why they continue using the "damaged" tooling to keep costs down.
Taught2BCauti...
PostPosted: 16:10 - 01 Feb 2015    Post subject: Reply with quote
Nothing to worry about - probably just surface cracks due to casting (as stated by others) and nothing will leak in or out.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
devojunior
PostPosted: 15:35 - 06 Feb 2015    Post subject: Reply with quote
if your worried rub them down with some wet and dry so they dissapear, if they come back then there cracks if not then as i suspect chris and others are correct about the cating process.
The last post was made 11 years, 104 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 2.45 - MySQL Queries: 13 - Page Size: 48.43 Kb
