Plz help me fix my cg "/
Liljohn999
PostPosted: 21:31 - 06 Feb 2015    Post subject: Plz help me fix my cg "/ Reply with quote
I took the clutch side casing of and replaced the clutch put it all back together and now it won't start. It will now roll in any gear without using the clutch?
iginge This post is not being displayed because it has a low rating (Off Topic). Unhide this post / all posts.
Northern Monkey
PostPosted: 22:16 - 06 Feb 2015    Post subject: Re: Plz help me fix my cg "/ Reply with quote
Try putting it back to the way it was before you started
PostPosted: 22:41 - 06 Feb 2015    Post subject: Re: Plz help me fix my cg "/ Reply with quote
iginge wrote:
I assume it was working fine before hand.
Sufficient amount of fuel
Battery is in working order
Sufficient engine oil
Electrics on the bike work (lights, indicators, rear brake light) etc?
Slight confused.. do you mean when you roll the bike forward it will engage in any gear on it's own?
YOU'RE confused? You should stop giving technical advice, you're making yourself look stupid. Might as well tell someone to change the chain on their bath plug because the tap keeps dripping.
iginge
PostPosted: 22:43 - 06 Feb 2015    Post subject: Re: Plz help me fix my cg "/ Reply with quote
Keep the jokes coming.
My attempt to clear up the issue and get as much information as possible is more help the OP at this point than your response, if the OP chooses to answer my questions or not is up to them.
PostPosted: 22:47 - 06 Feb 2015    Post subject: Reply with quote
It wasn't a joke, you really should stop giving technical advice.
Carvel
PostPosted: 22:52 - 06 Feb 2015    Post subject: Reply with quote
I agree
temeluchus
PostPosted: 22:57 - 06 Feb 2015    Post subject: Reply with quote
I also agree.
Fisty
PostPosted: 23:00 - 06 Feb 2015    Post subject: Reply with quote
I agree that teme agrees that carvel agrees.
Fatter and faster than Fret
temeluchus
PostPosted: 23:05 - 06 Feb 2015    Post subject: Reply with quote
I also agree that Fisty agrees that I agree that carvel agrees.
Carvel
PostPosted: 23:09 - 06 Feb 2015    Post subject: Reply with quote
I too agree that Teme agrees that Fisty agrees that Teme agrees that I agree.
RhynoCZ
PostPosted: 23:16 - 06 Feb 2015    Post subject: Reply with quote
Let's agree that this is getting kind of boring now. Thumbs Up
Back to the CG, what do you mean it will roll in any gear? Like, you put it in gear and push the bike with no problem? Did you put new springs in there, or any springs at all?
Commuter_Tim
PostPosted: 23:20 - 06 Feb 2015    Post subject: Reply with quote
I agree too, get that leaky tap fixed pronto, taps shouldn't be able to roll in all gears. Folded arms
Praise Rhyno for trying to steer BCF away from stupidity, fools errand bro. Razz
I ride a Bandit 600... badly.
PostPosted: 23:20 - 06 Feb 2015    Post subject: Re: Plz help me fix my cg "/ Reply with quote
Chances are that as the old clutch has worn it has been adjusted to compensate. When you replace the clutch you have to adjust the free-play in the release mechanism because the new plates are thicker than the old ones.
Looks like all the adjustment on the CG is in the cable. Slacken the adjuster and until the lever has a bit of free play in it. If the clutch still doesn't engage and you can still push the bike in gear, you have put the clutch together wrong.
RhynoCZ
PostPosted: 23:27 - 06 Feb 2015    Post subject: Reply with quote
Good call Pete, I forgot the cable. The quick test, undo the cable and then try to roll the bike in gear. No cable means the springs (if you put some in there) will push the plates together and won't let you roll the motorcycle. Thumbs Up
Nobby the Bastard
Harley Gaydar
PostPosted: 23:50 - 06 Feb 2015    Post subject: Reply with quote
I've given good karma to everyone who thinks that your technical advice is shit.
Triumph Sprint ST 1050
mentalboy
PostPosted: 23:54 - 06 Feb 2015    Post subject: Reply with quote
As for the starting issue I'm going to assume that it's electrical and that you've got nothing happening when pushing the start button...
(...unless you mean it's turning the engine over but not firing up....)
...Have you forgotten to reaffix an earth cable fixed to the clutch cover by one of the cover bolts?
Oh, and for the record, I agree with Rhyno that it's boring that Carvel agrees with Fisty who agrees with Teme, but I agree with Carvel who agrees with Pete that technical advice on this subject is distinctly lacking, however I disagree with Pete advising the changing of a bath plug chain when the tap drips, everyone knows that you should clean the drain so that the bath won't flood Rolling Eyes
Make mine a Corona.
mudcow007
PostPosted: 00:37 - 07 Feb 2015    Post subject: Reply with quote
clutch dowl thingy (with the spring on)
mine was a swine to fit back properly - check dis!
bypass2
PostPosted: 01:10 - 07 Feb 2015    Post subject: Reply with quote
maybe you have put the clutch actuater back wrong and its permanently disengaged the clutch. disconect the clutch cable put it in gear see if it engages the gears then.
The last post was made 11 years, 111 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.28 - MySQL Queries: 13 - Page Size: 110.16 Kb
