Fuel Syphon
delsol
PostPosted: 18:06 - 14 Feb 2015    Post subject: Fuel Syphon Reply with quote
Hi, guys, I hate sucking fuel down a hose and choking on the fumes, tastes like shit too Shocked .
Can you direct me to, or show me something really compact to extract say max 1/2 litre of petrol from the bike tank.
Just needing to top up a petrol stove canister on the go.
delsol
doggone
PostPosted: 18:16 - 14 Feb 2015    Post subject: Reply with quote
I suppose you could use a big plastic syringe.
https://www.molevalleyfarmers.com/mvf/store/products/luer-disposable-syringe-60ml
PostPosted: 18:20 - 14 Feb 2015    Post subject: Reply with quote
Possibly too big a volume for you but we have one of these for getting petrol out of bike tanks:-
https://www.machinemart.co.uk/shop/product/details/jiggle-siphon?da=1&TC=GS-051712420
Charlotte got it when in Aus over 20 years ago. Works well.
PostPosted: 18:27 - 14 Feb 2015    Post subject: Reply with quote
doggone wrote:
For lulz, go to pharmacies and ask if they sell big plastic syringes. The answer will most likely be no but I did get a leaflet for a needle exchange. Laughing
doggone
PostPosted: 18:28 - 14 Feb 2015    Post subject: Reply with quote
You don't need get fuel in your mouth anyway if you can pinch the tube, in fact that's all that device is doing.
Fumes admittedly not pleasant, unless you're addicted Confused
monkeybiker
PostPosted: 18:31 - 14 Feb 2015    Post subject: Reply with quote
https://www.ebay.co.uk/itm/like/271692675368?clk_rvr_id=780579741820&item=271692675368&lgeo=1&clk_rvr_id=780579741820&rmvSB=true&vectorid=229508&rmvSB=true
delsol
PostPosted: 18:48 - 14 Feb 2015    Post subject: Reply with quote
Cheers monkey biker, just need something more compact, thanks mate.
ScaredyCat
PostPosted: 19:38 - 14 Feb 2015    Post subject: Reply with quote
https://www.youtube.com/watch?v=xpHqraOdMDs
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
PostPosted: 20:02 - 14 Feb 2015    Post subject: Re: Fuel Syphon Reply with quote
First off - I'd just use the fuel line.
If it's hidden and something you'll use enough to go to the hassle of buying something, I'd consider adding a T junction and stick a tap on that.
Otherwise, not too small, but I've used a washing up liquid bottle with a .5cm hole in the top - stick the hose onto the nozzle.
With the hole uncovered, squeeze the bottle. Cover the hole with your finger and un-squeeze the bottle. As the fuel starts to flow from the suction, take your finger off the hole.
delsol
PostPosted: 13:46 - 15 Feb 2015    Post subject: Reply with quote
Great ideas guys, neat trick on ScaredyCat's vid.
Maybe a min jiggle syphon if you can get one, and like G's washing liquid bottle too.
Thumbs Up G's tap on the fuel line has to be the best way to go, just makes the most practical sense, need to nip out to see if I can easily fit one.
G, any particular type or setup you can suggest, ta.
PostPosted: 13:59 - 15 Feb 2015    Post subject: Reply with quote
I'd just get a [url="https://www.ebay.co.uk/sch/?_nkw=fuel hose t"]T connector[/url] along with a cheap fuel tap.
Add fuel hose either side - I'd probably route it to where the carb overflow goes, which should give enough of a 'tail' to move around when needed.
monkeybiker
PostPosted: 16:09 - 15 Feb 2015    Post subject: Reply with quote
What is the benefit of this petrol stove? To me it all seems a bit dodgy topping it up and setting it alight.
Would it not save a lot of hassle to just use a gas powered stove?
delsol
PostPosted: 18:40 - 15 Feb 2015    Post subject: Reply with quote
Not really dodgy mate, I would only top up an unconnected stove fuel tank.
I carry one container, about 500ml, for fuel, no need for spare canisters of gas so space saver, and I always have spare fuel in the bike tank to top up stove fuel tank.
Petrol stove puts out a lot of heat and boils water very quickly, relatively the petrol is much cheaper than gas and works well even at low temperatures.
If anything went wrong with the stove fuel tank or it's pump then I could buy a gas canister and the stove would work off that until I sorted a fix.
PostPosted: 19:33 - 15 Feb 2015    Post subject: Reply with quote
Also - I'd top up the stove bottle when you're at a petrol station anyway.
That way you've also got a bit of 'emergency fuel' for the bike, or to help out another bike etc, if you haven't used it for cooking yet.
-Matt-
PostPosted: 22:17 - 18 Feb 2015    Post subject: Reply with quote
I've got one of these thats worked well for getting fuel out a tank in the past. Only problem might be its not really 'compact' because of tube attached to the pump part which isn't flexible, but it would be very easy to slip under a strap on some luggage or something perhaps.
https://www.ebay.co.uk/itm/Manual-Hand-Siphon-Syphon-Liquid-Transfer-Pump-Pipe-/111315548911?pt=LH_DefaultDomain_3&hash=item19eaec7aef
Can get them for a couple of quid less if you're willing to wait for delivery from China Razz
PostPosted: 22:49 - 18 Feb 2015    Post subject: Reply with quote
Shocked
stromfirth
PostPosted: 22:39 - 26 May 2015    Post subject: Reply with quote
We use a foot operated Whale bile pump. Very effective!
PostPosted: 23:13 - 26 May 2015    Post subject: Reply with quote
Just get a piece of fuel hose the same diameter as your fuel line and a straight through connector to extend your fuel line. Route it so that you can pull a bit of a loop out, split it at the connector and drain some fuel off when you need it.
PostPosted: 12:49 - 27 May 2015    Post subject: Reply with quote
Just stop sucking before it gets to your mouth, use a clear hose and as soon as it goes "over the top", stop sucking and gravity does the rest.
There's another way without sucking that works with a reasonably full tank. Get a long piece of hose. Push as much of the hose as you can down under the fuel starting at one end so it fills up with fuel. Kink the end over to seal it then smoothly lift the hose up and out of the tank so the kinked end is below the fuel level. The hose should be full of fuel providing the kink was airtight and the other end is still in the fuel. You now just unkink the end and it'll start to flow.
Petrol stoves are awesome. I'll take the pepsi challenge to a full rolling boil on either of my petrol stoves against a gas one.
ripzay
PostPosted: 19:29 - 27 May 2015    Post subject: Reply with quote
Turkey baster? Razz
Current: 2005 KTM SuperDuke 990
Previous: 1996 Suzuki Bandit 600
Previous: 1994 Suzuki GSX-R 400
The last post was made 11 years, 106 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 107.04 Kb
