| delsol |
 delsol World Chat Champion
 Posted: 18:06 - 14 Feb 2015 Post subject: Fuel Syphon |
Hi, guys, I hate sucking fuel down a hose and choking on the fumes, tastes like shit too .
Can you direct me to, or show me something really compact to extract say max 1/2 litre of petrol from the bike tank.
Just needing to top up a petrol stove canister on the go.
delsol |
| doggone |
 doggone World Chat Champion
 Posted: 18:16 - 14 Feb 2015 Post subject: |
| Kickstart |
 Kickstart The Oracle
| Ste |
 Ste Not Work Safe
 Posted: 18:27 - 14 Feb 2015 Post subject: |
For lulz, go to pharmacies and ask if they sell big plastic syringes. The answer will most likely be no but I did get a leaflet for a needle exchange.  |
| doggone |
 Posted: 18:28 - 14 Feb 2015 Post subject: |
You don't need get fuel in your mouth anyway if you can pinch the tube, in fact that's all that device is doing.
Fumes admittedly not pleasant, unless you're addicted  |
| monkeybiker |
 monkeybiker World Chat Champion
 Posted: 18:31 - 14 Feb 2015 Post subject: |
| delsol |
| ScaredyCat |
 ScaredyCat World Chat Champion
| G |
 G The Voice of Reason
| delsol |
 Posted: 13:46 - 15 Feb 2015 Post subject: |
Great ideas guys, neat trick on ScaredyCat's vid.
Maybe a min jiggle syphon if you can get one, and like G's washing liquid bottle too.
G's tap on the fuel line has to be the best way to go, just makes the most practical sense, need to nip out to see if I can easily fit one.
G, any particular type or setup you can suggest, ta. |
| G |
 Posted: 13:59 - 15 Feb 2015 Post subject: |
I'd just get a [url="https://www.ebay.co.uk/sch/?_nkw=fuel hose t"]T connector[/url] along with a cheap fuel tap.
Add fuel hose either side - I'd probably route it to where the carb overflow goes, which should give enough of a 'tail' to move around when needed. |
| monkeybiker |
| delsol |
| G |
| -Matt- |
 -Matt- World Chat Champion
| Ste |
 Ste Not Work Safe
| stromfirth |
 stromfirth Derestricted Danger
| Pete. |
 Pete. Super Spammer
 Posted: 23:13 - 26 May 2015 Post subject: |
Just get a piece of fuel hose the same diameter as your fuel line and a straight through connector to extend your fuel line. Route it so that you can pull a bit of a loop out, split it at the connector and drain some fuel off when you need it. ____________________ a.k.a 'Geri'
| stinkwheel |
 Posted: 12:49 - 27 May 2015 Post subject: |
Just stop sucking before it gets to your mouth, use a clear hose and as soon as it goes "over the top", stop sucking and gravity does the rest.
There's another way without sucking that works with a reasonably full tank. Get a long piece of hose. Push as much of the hose as you can down under the fuel starting at one end so it fills up with fuel. Kink the end over to seal it then smoothly lift the hose up and out of the tank so the kinked end is below the fuel level. The hose should be full of fuel providing the kink was airtight and the other end is still in the fuel. You now just unkink the end and it'll start to flow.
Petrol stoves are awesome. I'll take the pepsi challenge to a full rolling boil on either of my petrol stoves against a gas one. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| ripzay |
 ripzay Nitrous Nuisance
 Posted: 19:29 - 27 May 2015 Post subject: |
Turkey baster?  ____________________ Current: 2005 KTM SuperDuke 990
Previous: 1996 Suzuki Bandit 600
Previous: 1994 Suzuki GSX-R 400 |
The last post was made 11 years, 106 days ago. Instead of replying here, would creating a new thread be more useful? |
