Honda cbf 125 engine light.
Edwardoooo
PostPosted: 23:06 - 14 Feb 2015    Post subject: Honda cbf 125 engine light. Reply with quote
Hello everyone.
I need help pulling my hair out here.
I have just got my heap of sh1t cbf back from the garage. Took it about 40 miles and the engine management light came on now it will not start.
Thanks.
Accuhaler
PostPosted: 23:11 - 14 Feb 2015    Post subject: Reply with quote
why was it at the garage?
Edwardoooo
PostPosted: 23:38 - 14 Feb 2015    Post subject: Reply with quote
It had an mot due for thursday took it to the garage a week before to get sorted.
The mechanic foned me 3 days later said it was bad news needed rear tyre ,chain and sprocket kit ,left rear indicator ,front pads ,caliper seals ,fork seals.
The front tyre was also leaking at rim and rear brake seized on nothing to do with engine im gutted to say the least.
Thanks for help.
Taught2BCauti...
PostPosted: 08:43 - 15 Feb 2015    Post subject: Reply with quote
Put the bike on the side-stand, and watch the Engine Light as you turn on the ignition.
Count the number of long and short flashes - this represents a number.
Long flash = 10, short flash = 1, so 3 x Long plus 4 x short = 34.
Post back with the result.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
MCN. This post is not being displayed because the poster is banned. Unhide this post / all posts.
Taught2BCauti...
PostPosted: 10:41 - 15 Feb 2015    Post subject: Reply with quote
Soylent Blue wrote:
Put the ECU in the freezer for 24 hours. It will cancel all the fault codes.
But won't cure the fault!
As soon as you try to start the engine, the ECM goes into fail mode again.
You need to find out what the fault code refers to - and fix the problem.
(My guess is the fuel pump - common problem on those)
Edit: Putting the ECU in a freezer, can totally destroy it!
Skudd
PostPosted: 12:04 - 15 Feb 2015    Post subject: Reply with quote
Giving crap advice is daft and very unnecessary. Poor show.
Edwardoooo
PostPosted: 15:07 - 15 Feb 2015    Post subject: Reply with quote
I checked the engine light when only on the side stand it is not flashing just solid then goes off after a few seconds.
There is a clicking noise coming from the back seat when i try to turn her over but im not mechanical i don't know if its the battery but lights and horn all work.
Cheers for the help lads.
Nemo
PostPosted: 18:11 - 15 Feb 2015    Post subject: Reply with quote
If the light is going off after a few seconds then it's not a problem.
The clicking is either battery not having enough juice to turn the starter motor or a bad connection.
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
Edwardoooo
PostPosted: 18:26 - 15 Feb 2015    Post subject: Reply with quote
Yeh I thought that but the light came on when i was about to stop at traffic lights.
That is why i thought it was something to do with engine light.
I can't bump it and also lights horn everything ok.
Thanks for your help nemo.
Nemo
PostPosted: 18:47 - 15 Feb 2015    Post subject: Reply with quote
It will power the lights and horn and what not, but the starter requires a far greater amperage. Just get a multimeter across the terminals.
Edwardoooo
PostPosted: 19:56 - 15 Feb 2015    Post subject: Reply with quote
Is there any other way to check I don't have a multimeter or just get it from halfords or somewhere ?
By terminals do you mean the battery i just don't really know anything about bikes.
Thanks.
Nemo
PostPosted: 20:33 - 15 Feb 2015    Post subject: Reply with quote
Yeah you can get a multi meter from halfords, although tool station is probably cheaper.
Put the dial to dc volts 20, then put the red lead on the positive battery terminal, and the black lead on the negative.
They usually sit at around 12.5volts, you can also check the voltage as you try to start it, if the voltage drops dramatically (say 9 volts) then the battery will need changing.
Edwardoooo
PostPosted: 20:55 - 15 Feb 2015    Post subject: Reply with quote
Ok that is good thanks.
I think it may need changing its an 11 plate i got it last july with 7000 miles with 3 owners wasn't the best looking so not really been cared for.
I had to change tyres chain sprockets when i got it and also asked the mechanic to check it over in a honda dealership he said it was ok except cosmetic stuff.
The last post was made 11 years, 277 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.29 - MySQL Queries: 13 - Page Size: 79.36 Kb
