Kick starting a Cagiva E350 T4
dilligat
PostPosted: 20:16 - 17 Feb 2015    Post subject: Kick starting a Cagiva E350 T4 Reply with quote
Hello
I have a 1992 ex French military Cagiva Elefant E350 T4. It has both a kick start and starter motor.
The kick start has an automatic decompression system that works off the kick starter.
This means it's a pig to find TDC to kick the thing esp when the battery has died from repeated starts when greenlaning.
Does anyone have the manual or any idea how to kick it without wasting valuable energy randomly kicking at it in the vain hope i GET THE RIGHT STROKE?
Thanks in desperation!
J
316lad
PostPosted: 20:24 - 17 Feb 2015    Post subject: Re: Kick starting a Cagiva E350 T4 Reply with quote
dilligat wrote:
Hello
J
No, only if you install a window in the magneto side casing and mark up the magneto TDC Point and corresponding casing mark in red sharpie!!!! - of course - stupid idea. Sorry.
You could, however put her into 2nd gear, roll her forward gently but firmly - and when she really bites and locks the back wheel you'll know you've sort of hit just about short of TDC.
Then, give her a tiny blip on the Kick Starter to get her to true TDC.
Then, kick over as normal.
PostPosted: 21:01 - 17 Feb 2015    Post subject: Reply with quote
Possibly helpful bit: The advice for Enfields is to put it in 2nd then roll backwards until you're stopped by compression.
Pointless aside: There's also a whole set of rituals involving pre-kicking under decompression/valve lift, listening for compression stroke whoosh, and finding TDC by watching the ammeter twitch while you slowwwwly turn it over. I followed them religiously until I realised that it was still a lottery whether it fires on the first kick, and I can be off a lot quicker by just climbing on and stamping away until I get lucky.
dilligat
PostPosted: 07:14 - 18 Feb 2015    Post subject: Reply with quote
Thank you gents I will give the 2nd gear idea a go
MaybeGuy
PostPosted: 08:02 - 18 Feb 2015    Post subject: Reply with quote
Take out the decomp mech.
The last post was made 11 years, 221 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 44.53 Kb
