Coolant hose warning
sickpup
Old Timer
PostPosted: 19:33 - 14 Mar 2015    Post subject: Coolant hose warning Reply with quote
Just had to replace one of the coolant hoses on the ER6 after it split and looks like I need to do the other one.
Looking at the inside of the split one you can see just how much it is perished. Keep in mind this bike is only 7 years old and there are many bikes with more years on them on original pipework so check your hoses before the upcoming season starts Wink
https://i945.photobucket.com/albums/ad297/750RK/Odds%20and%20ends/20150314_192437.jpg
PostPosted: 19:44 - 14 Mar 2015    Post subject: Reply with quote
Not having a lot of luck with rubber stuff are you mate?
Might want to check your gimp suit/gas mask in case it's splitting at the seams Very Happy
sickpup
Old Timer
PostPosted: 19:55 - 14 Mar 2015    Post subject: Reply with quote
Thing is the manufacturers recommend replacement every 3-5 years and the Japanese Shaken requires a 3 yearly replacement on coolant hoses, maybe they are right.
PostPosted: 20:21 - 14 Mar 2015    Post subject: Reply with quote
Yeah most people don't realise that fuel lines have a service life either.
sickpup
Old Timer
PostPosted: 20:43 - 14 Mar 2015    Post subject: Reply with quote
The greatest problem there is Neoprene ones are sold for bikes and Ethanol eats them in a matter of months.
Andy_Pagin
PostPosted: 10:53 - 15 Mar 2015    Post subject: Reply with quote
Is this a particular problem with bikes, or modern vehicles in general? Some of the hoses on my Landrover are 47 years old.
RhynoCZ
PostPosted: 11:46 - 15 Mar 2015    Post subject: Reply with quote
How many miles a year can you do?
sickpup
Old Timer
PostPosted: 16:52 - 15 Mar 2015    Post subject: Reply with quote
Old Series vehicles are VERY under stressed so everything tends to last longer BUT at 47 years they probably need replacing.
PostPosted: 19:33 - 15 Mar 2015    Post subject: Reply with quote
My GPZ500 was 9 years old when I got it. The coolant hoses crackled when squeezed gently.
Well, I'm sure the next owner replaced them. Whistle
barrkel
PostPosted: 20:05 - 15 Mar 2015    Post subject: Reply with quote
That the link pipe from radiator to water pump? My GF's 57 ER6 is just about OK, but not looking great. I dismantled the pump over the weekend owing to oil coming out the weep hole with the engine running, currently awaiting replacement seals. Not that uncommon on the ER6 either.
Are you replacing with oem original part, or cut length from somewhere else?
sickpup
Old Timer
PostPosted: 20:21 - 15 Mar 2015    Post subject: Reply with quote
Its actually the top hose, the bottom has already been replaced and needs doing again. Got all the seals here for the water pump, will be doing that when I get a chance.
Cradleys have all the bits in stock btw.
Ed Case
PostPosted: 21:45 - 15 Mar 2015    Post subject: Reply with quote
Read this post...interesting.....I normally buy any bits I need from Cradley but I've been checking the ads for silicon hoses and the prices seem more-or-less comparable.......anyone have any opinions or experiences with these things ?.
prawny1
PostPosted: 12:36 - 18 Mar 2015    Post subject: Reply with quote
Road salt and cold temps don't help when it comes to rubber parts.
I find more failures from contamination than actual perishing though, like from head gasket failure softening the hoses (more often egr cooler leaking on cars) or running with no anti freeze making the inside brittle and leading to a build up of corrosion on the pipe joints.
It is strange that the hoses are recommended for changing every three years when modern antifreeze lasts 5 years+.
Have you pressure tested/ gas sniffed the system to make sure you don't have a headgasket issue?
hellkat wrote:
lozzypop1
Certified MILF!
PostPosted: 21:55 - 23 Mar 2015    Post subject: Reply with quote
Just did a spirited run to wales and back this weekend. Seems fine.
PostPosted: 22:05 - 23 Mar 2015    Post subject: Reply with quote
Given the advances in modern materials and the relatively short length of hose on a motorcycle. Why someone would replace a perished rubber radiator (or fuel) hose with another rubber radiator hose is entirely beyond me.
One word: Silicone.
Ed Case
PostPosted: 09:36 - 24 Mar 2015    Post subject: Reply with quote
One word: Silicone.
So I take it that's an affirmative to my query re silicone hoses stinkwheel ?.
PostPosted: 14:03 - 24 Mar 2015    Post subject: Reply with quote
It's heat resistant enough to rest against the exhaust without melting. It's solvent resistant enough to use it as fuel hose. Gets the thumbs-up from me.
Only thing to watch is taking it round sharp bends. It can kink. You sometimes need to buy a pre-bent corner.
skatefreak
PostPosted: 14:43 - 24 Mar 2015    Post subject: Reply with quote
Pipes on my 1995 CBR600 f3 look origional..
Was thinking of replacing them but it almost seems as if manufacturers realised 'Make parts last 25 minutes instead of forever = profit".
Pretty cynical but everything is going that way...
New cars being the worst.
My 2005 307 has given me a shed load more trouble than the 1998 306... go figure...
-Jvr
.Chris.
PostPosted: 16:54 - 24 Mar 2015    Post subject: Reply with quote
A few years ago I had a pretty scary hose failure on my Morris Minor. The fuel hose connecting the fuel pump on the bulkhead to the carburettor started leaking at the midpoint, dripping fuel onto the top of the exhaust pipe while the engine was running Shocked. It'd been happening for some time as I'd noticed an increase in fuel consumption, but couldn't work out why until one day I stopped the car and smelt fuel. Because the hose had a braided covering, I couldn't see the degradation in the rubber hose underneath until it started leaking.
Chris
1985 Kawasaki Z550F
The last post was made 10 years, 353 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 105.05 Kb
