| Highside |
 Highside L Plate Warrior
| Taught2BCauti... |
 Posted: 14:52 - 16 Mar 2015 Post subject: |
How exactly is the engine management light flashing?
1 long and 3 short, 3 long and 1 short, or 4 short flashes?
1+3 would be for the TPS, 3+1 would be for the Cylinder-#2 ignition coil, 4 would be an ECU fault.
TPS normally reads between 2k and 3k ohms. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| Highside |
| Taught2BCauti... |
 Posted: 18:09 - 16 Mar 2015 Post subject: |
Not sure about 4 long - what year is the bike, and do you have an LCD display for the trip meter? ____________________ Honda Varadero XL125(V8)
| Highside |
| Taught2BCauti... |
 Posted: 22:38 - 16 Mar 2015 Post subject: |
It would be best if you could get hold of the service manual and look through the diagnostic codes.
I could only find the list for later models, and 4 long flashes refers to the 'secondary injector' which I don't think you have.
4 short flashes could also be an ECU general fault, but I also thought you had a TPS problem from those readings of 6 ohms. ____________________ Honda Varadero XL125(V8)
| Highside |
| Taught2BCauti... |
 Posted: 13:00 - 19 Mar 2015 Post subject: |
Strange one.
Do you get the problem when revving in neutral, or is it also linked to road speed?
Could the HID Ballasts be causing some electro-magnetic or RFI interference?
I would guess the rev-counter gets it's data from the ecu - is the wiring good from end to end?
It does sound like the engine management is going into some kind of 'safe mode' possibly due to a faulty sensor.
I had a TPS problem with a mercedes a while back, which turned out to be a cracked carbon track. It only showed up at higher revs, due to vibration, and with more than 1/3 accelerator travel, due to the location of the crack. ____________________ Honda Varadero XL125(V8)
| Highside |
| Highside |
The last post was made 10 years, 315 days ago. Instead of replying here, would creating a new thread be more useful? |
