Charging camera battery on bike on remote tours?
charliefirpo
PostPosted: 19:01 - 16 Mar 2015    Post subject: Charging camera battery on bike on remote tours? Reply with quote
I will be making long trips with sometimes a few days without a power outlet. I will be able to charge my USB phone and GPS fine with the socket on my F650GS but I don't know how to charge my camera battery because it doesn't work with USB. It's a regular 220-240V AC.
Is there a way to charge your batteries on a bike? How do you fellow touring folk do that?
edit:
Is this all I need?
https://www.amazon.co.uk/Ring-Automotive-RINV120-Compact-Inverter/dp/B002XDERD8/ref=sr_1_16?ie=UTF8&qid=1426529058&sr=8-16&keywords=car+power+inverters
doggone
PostPosted: 20:41 - 16 Mar 2015    Post subject: Reply with quote
Yes that would do it, and you will likely find more uses for it.
Alternatively there's probably a 12V version of your battery charger but next year you might buy a different one and will sit gathering dust - but the inverter will do anything.
Be wary of trying anything remotely near the stated wattage though.
Small chargers should be OK.
The bestek ones are a bit more substantial without being too big.
https://www.amazon.co.uk/BESTEK-inverter-Power-Inverter-MRI2013U/dp/B00ALRM4RY/
Aff
PostPosted: 20:44 - 16 Mar 2015    Post subject: Reply with quote
What camera?
Electric Bike Project
ninjabob
PostPosted: 21:01 - 16 Mar 2015    Post subject: Reply with quote
Going to draw too much current for a bike battery to be happy with. Go for a 12v solution if possible.
charliefirpo
PostPosted: 21:14 - 16 Mar 2015    Post subject: Reply with quote
Thanks doggone, I saw that one too and thought it would probably be better. I'll get that one if I go that rout.
Aff, I have a Canon 7D.
ninjabob, I was afraid somebody would say that. I have no idea unfortunately how all this electrical gear really works in detail and naturally I don't want to end up with an empty battery.
So a 12V solution you say? But that is exactly the problem, isn't it?
My camera has this charger:
https://ibay365-goodsimg.s3.amazonaws.com/5426/20141124/20141124161956-365ff.jpg
I just found this thing here which is for 7D batteries:
https://i00.i.aliimg.com/wsphoto/v1/751438114/Battery-AC-Car-Charger-for-Canon-LP-E6-EOS-5D-font-b-7D-b-font-font.jpg
But does that indicate that with this I would not have any strange middle conversion going on and I'd pretty much use it the same way as charging my phone via USB?
If so then I'd certainly get this thing instead.
doggone
PostPosted: 21:17 - 16 Mar 2015    Post subject: Reply with quote
It will depend what you plug in.
The inverter doesn't draw 120w itself, the charger will be well under 50w probably more like 20w at most.
It would easily cope when the engine is running and for a short while when not.
andy_uk
PostPosted: 21:23 - 16 Mar 2015    Post subject: Reply with quote
Yes, that's the one you want!
I use one similar to it for my 700D
Basically you'd fit a cigarette lighter style socket on the bike and plug it straight in to that Smile
charliefirpo
PostPosted: 21:35 - 16 Mar 2015    Post subject: Reply with quote
great!
What would the inverter come in handy for on a tour? Is there any other device you guys have in mind that I would use if I had an inverter with me? I can't actually think of anything. I mean it's definitely good to have the opportunity on a long tour, you never know when you might need it but right off the bat I can't really think of anything I would need except being able to charge a phone, GPS and camera.
ferrisio
PostPosted: 21:47 - 16 Mar 2015    Post subject: Reply with quote
Rapidly flattening your battery.
BMW R1100R
ocatoro
PostPosted: 05:05 - 18 Mar 2015    Post subject: Reply with quote
if that's something that's a problem for the type of travelling you do. have you considered changing to pentax? they've traditionally been used by travel photographers, and as such listened to their main users and changed their battery system to double a's.... which are available cheaply all over the globe. something to consider...
CBT - 17/09/12 * Theory - 23/10/12 * Mod1 - 05/03/13 * Mod2 - 25/03/13 * BOSH!
Current - None Sad but shed project H100 (first bike Smile )
Past - ER5, '93 ZZR600, '92 CB400 SF, ZZR600 (again), yellow Monster 620, Blackbird - black Monster 620ie - '96 ZZR600
wots
PostPosted: 08:58 - 18 Mar 2015    Post subject: Reply with quote
Suggesting a pentax over a Canon SLR? Rolling Eyes
Inverter is great in a car, just get the 12V charger. Also good, particularly for touring, are those cheap little led volt meters. Then you can see what is going on. It won't tell you actual draw, but it will show you that you are maintaining the right sort of voltage. Added bonus, you can see impending reg/rec implosion.
FlightRisk
PostPosted: 09:14 - 18 Mar 2015    Post subject: Reply with quote
Someone I know had a Canon battery grip that could take 6 AA batteries. I presume there'll be one for the 7D, just another option to think about.
Agree Pentax make very good kit but since OP already has the 7D...
If you used an inverter I presume it's something you'd only want to use while riding. You'd kill a little bike battery fairly quickly if you used it while stopped.
Honda CB500S
Northern Monkey
If you're going away for 2 or 3 days, just take a few more camera batteries with you. Less pissing about, and less bulky than recharging on the go
davebike
PostPosted: 09:31 - 18 Mar 2015    Post subject: Reply with quote
I carry and use a simple USB charger that plugs into a USB socket in the top box to charge batteries for my Nikon DSLR
I bet there are Canon usb chargers for you camera
going via 240v is never going to be good and the USB system is used while on the move and the bike is charging
Lots of 12v to USB units on Ebay
Dave
NC750Xdct + others at work !
[email protected]
doggone
PostPosted: 10:47 - 18 Mar 2015    Post subject: Reply with quote
I'd agree with that, however an inverter is a useful thing to have for about £20.
I use mine during power cuts to run a router (for laptop) as we don't have any mobile signal here - and in cars for being able to charge things on longer days without buying additional 12V chargers for everything.
USB charging is a relatively new thing - since smartphones! - but does help a lot.
PostPosted: 12:01 - 18 Mar 2015    Post subject: Reply with quote
I have one on my 50D, 6aa's last 200/300 shots.
2 normal batteries (2 fit in the grip) lasted me 2000 shots a few weekends ago.
This, Canon quote the 7d as having a 640 shot life, same as my 50D however I have noticed this is bollocks. I got 2000 shots out of 2 batteries a while ago, and the meter still said the batteries were at max.
Buy a few more and you'll be fine.
FlightRisk
PostPosted: 13:03 - 18 Mar 2015    Post subject: Reply with quote
Is that just normal disposable AA? I'd say you'd get much better with decent NiMH rechargeables or there's Lithium AA either. Lots of options with the grip anyway.
Honda CB500S
weasley
PostPosted: 13:08 - 18 Mar 2015    Post subject: Reply with quote
Canon make a 12v charger for the LP-E6 battery. It's not cheap, but it is designed for the job. Canon CBC-E6.
https://www.wexphotographic.com/webcontent/product_images/large/37/1028675.jpg
PostPosted: 13:12 - 18 Mar 2015    Post subject: Reply with quote
That was with the batteries I use for my flash gun, expensive 2600mah NiMh'd.
The whole point of it is to use disposable batteries, when you have nothing charged and the local area only sells standard batteries. No point taking expensive rechargeable AA's when a 'proper' battery is much better. The AA carrier is for 'Emergencies' not for practical use.
Peirre oBollox
PostPosted: 14:35 - 18 Mar 2015    Post subject: Reply with quote
And possibly letting the smoke genies out of your bike
c-m
PostPosted: 14:49 - 18 Mar 2015    Post subject: Reply with quote
For practically every make of camera, Nikon, Canon, Sony (especially), Fuji, Panasonic you can get a usb external charger from ebay.
You're bike has a 400w generator so no problem running a camera, GPS, mobile phone, heated grips and a heated vest all at one.
ocatoro
PostPosted: 19:06 - 18 Mar 2015    Post subject: Reply with quote
following the crowd into servitude.... Rolling Eyes
not really the place for it. but market share doesn't equate to quality.
the reason for my suggestion was obvious. it's for travel. and that's the main focus of the pentax slr market. hence why they changed their battery game to aa's. for worldwide ease of availability.
tools for jobs. use a canon and need inverter to drain a battery whist in remote locations. or use something more suited, and pick up a handful of aa's at any petrol station in the country... if you fail to see the good logic, you might need a carer buddy.
The last post was made 11 years, 196 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.48 Sec - Server Load: 1.34 - MySQL Queries: 13 - Page Size: 120.1 Kb
